Re: 440 stroker short block assembly.
[Re: 70RT Charger]
#3271435
11/20/24 11:13 AM
11/20/24 11:13 AM
Posts: 2,925 Pattison Texas
CSK
Pattison Texas
I'll build you one, & I will guaranty it,,, might not leak.
[Re: moparx]
#3271436
11/20/24 11:16 AM
11/20/24 11:16 AM
Posts: 744 eastern,Ky
70RT Charger
eastern,Ky
wondering out loud here, but how many performance engines/race engines suffering from rear main seal leaks are running a properly functioning PVC system, utilizing one of those adjustable billet PVC valves ? of course a vacuum pump is a good item as well. Im running a sniper 1000cfm x-Flo. No PVC, just a dual catch can set up on it now. The 1st set up was a carb with pvc but leaked on initial start up. I changed to the sniper after I thought I had it fixed with the rope seal.
[Re: 70RT Charger]
#3271445
11/20/24 12:39 PM
11/20/24 12:39 PM
Posts: 75,329 A gulag near you.
JohnRR
A gulag near you.
wondering out loud here, but how many performance engines/race engines suffering from rear main seal leaks are running a properly functioning PVC system, utilizing one of those adjustable billet PVC valves ? of course a vacuum pump is a good item as well. Im running a sniper 1000cfm x-Flo. No PVC, just a dual catch can set up on it now. The 1st set up was a carb with pvc but leaked on initial start up. I changed to the sniper after I thought I had it fixed with the rope seal. What rope seal did you use ? Fel pro , those are garbage . I used the best gasket #5279 with success . Best Rope Seals
Mainstream Media is the new Pravda
[Re: JohnRR]
#3271449
11/20/24 01:03 PM
11/20/24 01:03 PM
70RT Charger
eastern,Ky
wondering out loud here, but how many performance engines/race engines suffering from rear main seal leaks are running a properly functioning PVC system, utilizing one of those adjustable billet PVC valves ? of course a vacuum pump is a good item as well. Im running a sniper 1000cfm x-Flo. No PVC, just a dual catch can set up on it now. The 1st set up was a carb with pvc but leaked on initial start up. I changed to the sniper after I thought I had it fixed with the rope seal. What rope seal did you use ? Fel pro , those are garbage . I used the best gasket #5279 with success . Best Rope SealsI used an old NOS Rope seal on it because everyone was complaining about the felpros, which I couldn’t even find and all of the new graphite ones leaking. Like I said, dry as a bone about the 1st 1000 miles then one day she started leaking again .
[Re: CSK]
#3271611
11/21/24 05:47 AM
11/21/24 05:47 AM
70RT Charger
eastern,Ky
I'll build you one, & I will guaranty it,,, might not leak. Best offer so far lol
[Re: Thelma133]
#3271831
11/22/24 08:51 AM
11/22/24 08:51 AM
Posts: 2,559 PA
moparacer
PA
I must be the second luckiest person in the world because I have never had a rear main seal leak on a big block or small block either. All with aftermarket cranks. I use Ultra Grey and put a thin coating on the outside of seal. Clock it 1/4 inch offset to the retainer cap, put a thin coating on the cap, tighten it down and fill cavity on retainer and outside channel with ultra grey. Done. All with Felpro seals and factory retainer cap. Maybe I should branch off into the Mopar rear main seal replacement industry.
67 Barracuda street/bracket car 11.27-119 68 Dart 502 BB 5.44-126 414 cid SB Dragster 7.65-174
[Re: moparacer]
#3271836
11/22/24 09:36 AM
11/22/24 09:36 AM
70RT Charger
eastern,Ky
I must be the second luckiest person in the world because I have never had a rear main seal leak on a big block or small block either. All with aftermarket cranks. I use Ultra Grey and put a thin coating on the outside of seal. Clock it 1/4 inch offset to the retainer cap, put a thin coating on the cap, tighten it down and fill cavity on retainer and outside channel with ultra grey. Done. All with Felpro seals and factory retainer cap. Maybe I should branch off into the Mopar rear main seal replacement industry. Wait a minute. Andy F just said they all leaked, especially the aftermarket stuff. You need a job?
