Re: 70 b body braking issues
[Re: fastmark]
#3270969
11/17/24 05:12 PM
11/17/24 05:12 PM
CrazyD
anything interfering with pedal movement?
[Re: CrazyD]
#3270973
11/17/24 05:42 PM
11/17/24 05:42 PM
Posts: 6,640 Abilene, Texas
fastmark
Abilene, Texas
anything interfering with pedal movement? No. When you take off the master cly and depress the pedal, it goes all the way to the floor with no interference. With the MC on it stops about 2” off the floor.
[Re: fastmark]
#3271006
11/17/24 10:28 PM
11/17/24 10:28 PM
Posts: 16,039 Omaha Ne
TJP
Omaha Ne
is the pedal Hard or spongy? Can you see the hoses deflecting when STANDING on the pedal? I'm assuming the rears and the E brake are adjusted properly
Another thing you can try is with the engine off, pump the pedal several times to get rid of any vacuum in the booster. Then apply a steady pressure to the pedal and start the car, IF the booster is working properly the pedal should drop with the vacuum.
[Re: Sniper]
#3271029
11/18/24 05:39 AM
11/18/24 05:39 AM
fastmark
Abilene, Texas
I looked in my 70 FSM, didn't see any spec for M/C stroke.
I would be tearing down the M/C and looking for issues as well as measuring the stroke. I’ve done that on two MC. The reproduction A1 Cardone number13-1475 and the NOS oem 2944477 are exactly the same. The secondary piston is about .020 shorter on the reproduction, but that does not make a difference. They both have a 1” stroke.
[Re: TJP]
#3271030
11/18/24 05:45 AM
11/18/24 05:45 AM
fastmark
Abilene, Texas
Another thing you can try is with the engine off, pump the pedal several times to get rid of any vacuum in the booster. Then apply a steady pressure to the pedal and start the car, IF the booster is working properly the pedal should drop with the vacuum. The pedal is not hard or overly spongy. I’ll check the rears again for proper adjustments. I’ll need help to check the hoses under pressure. I thought about that yesterday. I’ll try the procedure with the engine off.
[Re: fastmark]
#3271053
11/18/24 10:03 AM
11/18/24 10:03 AM
Posts: 1,398 VA
dragon slayer
VA
Mark, 2 inch travel seems like it would be enough. Have the meter valve and proportioning valve? You could measure the piston travel in the MC to bottom with the one you removed. Also there is a gap setting between rod and MC piston.
[Re: moparx]
#3271370
11/19/24 10:26 PM
11/19/24 10:26 PM
TJP
Omaha Ne
As previously mentioned, have you verified the clearance between the PB pushrod and piston inner bore. Should be ~ .020 -.030 clearance. too much will limit MC output Too little will cause the brakes to drag. It is something that should ALWAYS be checked when changing MC's or Boosters as things can vary between suppliers
[Re: fastmark]
#3271563
11/20/24 08:55 PM
11/20/24 08:55 PM
TJP
Omaha Ne
DVW brought up an interesting point that I previously thought of but did not mention as you said they were NOS parts I think . regardless it is always a good idea to Verify the piston sizes as parts can get swapped between boxes and with rebuilt or replacement parts things can vary. I've chased my tail on many brake issues. one that always come to mind is a low pedal but working well on a 75 or so Corvette. Finally found an old GM parts guy on a Corvette forum that said somewhere around 74 or so, GM changed the power brake booster to M/C pushrod length but did not change the part # as they were only sold as a unit by GM. NICE!!!!! Fast forward 45 years and you have the replacement parts industry totally confused as there are now booster and masters available individually that are listed for 68-80 IIRC but may or may not interchange. I should mention the car came in we did an inspection and we wound up doing the brakes. We did not however measure and record the pedal height while doing the inspection's. Doing so was added to the list and we did from this point forward 🙄 One of the other clues was I had a 69 at the time and the brake pedal was noticeably higher and above the acc. pedal. This by design was to prevent one from hitting the accelerator while braking This fiasco cost about 40 hours
[Re: TJP]
#3271614
11/21/24 07:12 AM
11/21/24 07:12 AM
fastmark
Abilene, Texas
To address the brake lines, they are not NOS but new ones from inline tube. They did not flex when I had a Freind step on the brakes.
Also. I rebuilt the entire brakes system as part of a mechanical restoration on the car. It was parked since 1979 and just used the original booster, linkage, safety valve , proportioning combination valve. The mc had already been replace with an aftermarket one with the provision for the lines on either side and was stuck. So I did not want to use it.
I’ve got some time before I head to the shop and try something this morning so here’s what I’ve found. George( dragon slayer) sent me publication for a master tech service conference book for 1970 brakes system. It was very informative. I think it’s available at the ebodies.org site, too. I’ll post some pictures from my phone but I may have found one problem with the aftermarket master cly I was using at first. It’s Cardone unit 13-1475 with engine side outlets. They don’t sell it anymore. In reading about the original factory master cly, it explain the relationship of the pistons to a “ compensating port”. The cups on both primary and secondary pistons are set slightly exposing the port to the reservoir. It’s about .025”. The main function is to bleed air or excess pressure back into the reservoir when the piston is at the rear most position. So. It this adjustment that is critical on the installation procedure.
I think I will head to the shop and take some more pictures to explain this problem. The internet is full of this “ adjust the pushrod” instructions but this mc is a horse of a different color and pictures will explain better.
I have verified that my booster is probably not the problem even though it leaks slightly from around the pushrod seal. I had a short, rude conversation with a booster rebuilder who told me my problem was that I had not adjusted the pushrod and hung up. I’ll just conclude that he knows a lot of general information on brakes and boosters but this is an odd duck that even some mopar guys don’t understand. There is absolutely nothing in any service manual about adjusting the booster to the master cly on a disc brake application. The only reference is on a Midland- Ross drum brake setup and this is completely different. I’ll take pictures and explain later.
