2012 ram MDS delete thoughts on this kit #3260968
09/30/24 03:57 PM
09/30/24 03:57 PM
Enjoy life today, It has an ex...
gtx6970 Offline OP
gtx6970  Offline OP
Looks like everything I need.to make the change , Tuner is included so i can turn the MDS off in the ecm
Make idle adjustments etc etc
Free shipping so $1525 plus tax delivered to my door , other than oil it looks like everything I need to do this MDS delete update
He recommends at a bare minimum cleaning / inspecting or replacing the oil pump and maybe even the VVT solenoid
Thoughts ?
https://www.amsracing.net/collectio...5-7l-hemi-engines?variant=11532742557732
Enjoy life today, It has an expiration date
Re: 2012 ram MDS delete thoughts on this kit [Re: gtx6970] #3261062
09/30/24 08:18 PM
09/30/24 08:18 PM
Central NY
GarageDodge Offline
GarageDodge  Offline
Central NY
what cam? I would replace timing set&oil pump,flush out all the oil passages,as they will have metal in them from the lifter&cam.
Re: 2012 ram MDS delete thoughts on this kit [Re: GarageDodge] #3261082
09/30/24 09:20 PM
09/30/24 09:20 PM
gtx6970 Offline OP
gtx6970  Offline OP
Stock grind 5.7 cam , just non MDS specs
Im planning to change oil pump. VVT solenoid and timing set while its apart. As I really only want to do this once
Tuner has capabilities of several different tunes / programming settings
Re: 2012 ram MDS delete thoughts on this kit [Re: GarageDodge] #3261106
09/30/24 11:18 PM
09/30/24 11:18 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
The filter catches the metal before it goes into the passages unless you run Fram filters... in that case shame on you!
Re: 2012 ram MDS delete thoughts on this kit [Re: gtx6970] #3261107
09/30/24 11:19 PM
09/30/24 11:19 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Thoughts ?
The only reason to delete MDS is if your going to a bigger cam...
Re: 2012 ram MDS delete thoughts on this kit [Re: gtx6970] #3261110
09/30/24 11:29 PM
09/30/24 11:29 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Make sure that is an actual mopar cam not the Chinese copy for sale all over the place for dirt cheap, they are awful!
Re: 2012 ram MDS delete thoughts on this kit [Re: HotRodDave] #3261201
10/01/24 11:11 AM
10/01/24 11:11 AM
gtx6970 Offline OP
gtx6970  Offline OP
Thanks,
Its confirmed, A New Mopar non MDS cam , and new mopar Scat pack NON mds hemi lifters
I believe its this one https://www.summitracing.com/parts/mop-53022263af/make/ram/model/1500/year/2012#overview
Im after long term reliability . Not make it a race car . So stock is just fine
And it seems its overwhelming to delete the MDS system for long term life in one of these engines. Combined with a quality full synthetic oil and high quality filter
Its my daily driver and used to pull a trailer 2 or 3 times a year
Re: 2012 ram MDS delete thoughts on this kit [Re: gtx6970] #3261267
10/01/24 03:00 PM
10/01/24 03:00 PM
gtx6970 Offline OP
gtx6970  Offline OP
Brings up the question. If I delete the MDS.
Do I still keep using 5W20 oil. or switch to something a little heavier ?
Re: 2012 ram MDS delete thoughts on this kit [Re: gtx6970] #3261319
10/01/24 07:01 PM
10/01/24 07:01 PM
Central NY
GarageDodge Offline
GarageDodge  Offline
Central NY
Keep using 5-20,if you don't your ch engine will come on.I have delated mds on 7 vehicles everybody says no difference in fuel millage .
Re: 2012 ram MDS delete thoughts on this kit [Re: GarageDodge] #3261901
10/04/24 10:06 AM
10/04/24 10:06 AM
5thAve Offline
5thAve  Offline
There's no backing to the MDS causing issues claims. It was never an issue in the earlier new Hemis and both MDS and non MDS lifters can fail. But it's probably the route to go when you're already in there.
Re: 2012 ram MDS delete thoughts on this kit [Re: 5thAve] #3261944
10/04/24 11:25 AM
10/04/24 11:25 AM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
I agree, there is exactly zero evidence the MDS causes the lifter failure trouble. I do cams in manual cars and 5.7 ram 2500s all the time and the don't have MDS. The pre 2009 engines had MDS with basically zero lifter and cam failure and ironically they had an even lower volume oil pump so that theory goes out the window also. I have done enough cams in these to build a log cabin with them and never had to do one before 2009. I actually see less MDS lifters go bad than non MDS lifters in engines that have both, perhaps because the lifter is not experiencing high spring pressure every other revolution... they only have installed spring pressure wearing out the roller when the system is engaged while the normal lifters are cycling thru low spring pressure and maximum spring pressure.
When the MDS solenoid is replaced with the plastic plug you get more oil to the lifter sides that is not useful and this in turn means less oil for rod and main bearings that is useful. Those MDS solenoids actually give the bottom end more oil when it is under a load and needs it the most.
Re: 2012 ram MDS delete thoughts on this kit [Re: HotRodDave] #3271310
11/19/24 03:36 PM
11/19/24 03:36 PM
gtx6970 Offline OP
gtx6970  Offline OP
Update, I have it opened up. Found a bad roller on the one lifter cyl #7
Cam is worn , but definitly not hatefull or as bad as a lot ive seen on the net
Anyone have pros or cons to go with all Melling parts versus all Mopar parts ?
Im on the fence to delete the MDS or not
If I do delete it, is there any pros or cons to leave the MDS solenoids in it or change them out to the kit supplied plugs ?
New timing set, New Valve springs , new HV oil pump and water pump will be part of the repair no matter which direction I go
Re: 2012 ram MDS delete thoughts on this kit [Re: gtx6970] #3271396
11/20/24 07:27 AM
11/20/24 07:27 AM
Quakertown PA
Tay Online content
Tay  Online Content
Quakertown PA
Delete MDS , install plugs Win Win. as for Pros/Cons , honestly I think it's all subjective , we've had customers say gas mileage was better when towing, ...went to crap when towing, I think some of it has to do with driver habits
for me, personally , I do a lot of short hop driving, 3 miles here, 10 miles there 90% suburbs , mileage went up by 2 , lost 2 on high way , my current daily is a 09 RCSB 4x2 , irony is I got it real cheap because it had a lifter issue
The Lifter issue is a combination of the VVT function, keep in mind certain scenarios the cam is being pulled away from the lifter or snapping back to lock position.
FCA had Comp cams and a private company run a test on a spintron to figure out the issue.
Re: 2012 ram MDS delete thoughts on this kit [Re: Tay] #3271495
11/20/24 04:22 PM
11/20/24 04:22 PM
gtx6970 Offline OP
gtx6970  Offline OP
decision made.
Ive ordered everything to retain the MDS,
Basically It came down to I did not want to have to deal with a tune or aftermkt reprogramer issues
New stock grind Melling cam, OEM updated lifters , head bolts, Timing set, Hellcat oil pump ( will swap out high pressure relief spring with my stock pump to avoid oil pressures faults in the system) new valve springs, water pump, etc etc etc
Not cheap. BUT it is what it is
Re: 2012 ram MDS delete thoughts on this kit [Re: gtx6970] #3271576
11/20/24 10:04 PM
11/20/24 10:04 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
If you leave MDS solenoids in you will get more oil to the crankshaft bearings otherwise you have 16 big leaks under full oil pump pressure at all times, with MDS in and functioning they only do that under very light loads. MDS does not hurt the cam, if it does then someone needs to explain why the earlier engines didn't have this problem.
You made the right decision, deleting MDS on a basically stock engine is dumb.
Re: 2012 ram MDS delete thoughts on this kit [Re: gtx6970] #3271578
11/20/24 10:07 PM
11/20/24 10:07 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
the pressure relief spring only does its thing under high oil pressure conditions like high RPM or cold starts. The hellcat pump will make more pressure at lower RPM and set check engine lights on some vehicles. I've never seen a stock pump make less than 20 PSI hot idle... more than enough and it's still more volume than the earlier engines that didn't have this problem.
Re: 2012 ram MDS delete thoughts on this kit [Re: Tay] #3271579
11/20/24 10:10 PM
11/20/24 10:10 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
I would love to see any evidence to back that claim up, i seriously doubt it has anything to do with VVT, it is just advancing and retarding it, same thing as increasing or decreasing RPM.
Re: 2012 ram MDS delete thoughts on this kit [Re: HotRodDave] #3271596
11/20/24 11:35 PM
11/20/24 11:35 PM
gtx6970 Offline OP
gtx6970  Offline OP
In tests I've seen ,,,,. And Ive been deep into that rabbit hole many times the past few weeks . Researching this and that to no end.
I felt the deleting of the MDS with its associated possible issues. Both mechanically and electronically / software . Was not something I felt like taking the chance on .
The hellcat pump makes more pressure via more volume
And installing the stock relief spring only lowers top end / blow off / max pressure. Yet Retains the lower end volume and pressure .
That with the upgraded lifters, More oil is a good thing, So It should live long and prosper ( fingers crossed )
There was no way I was not going to put a pump in this while its apart. So the upgrade seemed like a no brainer
With the costs of the tuners to basically do nothing but delete the MDS and a few software changes then get stuffed in the tool box to never see light again felt like a waste to me. As once connected to the Vin they are tied to it and it alone
As i have zero interest trying to get more power out of it , Power costs money, Power uses fuel , power breaks parts. None of which I felt the need for. The truck does EVERYTHING I need it to do when I need it, . So, stock seemed like the right way to go
I decided to spend the money on upgrading hard parts. As all in this ordeal is going to costs me in the neighborhood of $2500 before Im done. And thats ME doing all the work , Aint retired life grand LoL
I like my truck , everything about it . But the truck has about 155k miles on it . And I have serious doubts I'll put even close to another 100K . So fix it and drive on was a no brainer.
Re: 2012 ram MDS delete thoughts on this kit [Re: HotRodDave] #3271619
11/21/24 07:57 AM
11/21/24 07:57 AM
Quakertown PA
Tay Online content
Tay  Online Content
Quakertown PA
Common sense alone should tell you VVT has something to do with it,....G3 never had a MDS lifter issue before VVT, but after VVT it does,
One of the things discovered during the spintron testing was that when the VVT SNAPS the cam back to lock position there is roughly 3x load on the Camshaft lobe. When retarding the cam they found that in certain situations the plunger in the lifter expands to the point where the contact pressure on the lobe decreases by 50-60% then valve spring pressure takes up that "slack" which creates a bounce
you don't need a masters in Automotive Engineering from University of Wisconsin and 6 years experience working for Stellantis to be able to grasp the root cause.
