Re: 440 stroker short block assembly. [Re: 70RT Charger] #3271435
11/20/24 11:13 AM
11/20/24 11:13 AM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
I'll build you one, & I will guaranty it,,, might not leak.
Re: 440 stroker short block assembly. [Re: moparx] #3271436
11/20/24 11:16 AM
11/20/24 11:16 AM
eastern,Ky
70RT Charger Offline OP
eastern,Ky
Originally Posted by moparx
wondering out loud here, but how many performance engines/race engines suffering from rear main seal leaks are running a properly functioning PVC system, utilizing one of those adjustable billet PVC valves ?
of course a vacuum pump is a good item as well.
beer
Im running a sniper 1000cfm x-Flo. No PVC, just a dual catch can set up on it now. The 1st set up was a carb with pvc but leaked on initial start up. I changed to the sniper after I thought I had it fixed with the rope seal.
Re: 440 stroker short block assembly. [Re: 70RT Charger] #3271445
11/20/24 12:39 PM
11/20/24 12:39 PM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
beer
What rope seal did you use ? Fel pro , those are garbage .
I used the best gasket #5279 with success .
Best Rope Seals
Mainstream Media is the new Pravda
Re: 440 stroker short block assembly. [Re: JohnRR] #3271449
11/20/24 01:03 PM
11/20/24 01:03 PM
eastern,Ky
eastern,Ky
beer
Best Rope Seals
I used an old NOS Rope seal on it because everyone was complaining about the felpros, which I couldn’t even find and all of the new graphite ones leaking. Like I said, dry as a bone about the 1st 1000 miles then one day she started leaking again .
Re: 440 stroker short block assembly. [Re: 70RT Charger] #3271452
11/20/24 01:38 PM
11/20/24 01:38 PM
SW Ohio
cgall Offline
cgall  Offline
SW Ohio
I have a stock block and eagle crank and run a PVC valve, I think I got the retainer from Mancini many years ago. It will not leak normally but after a few 7200 RPM blasts on the quarter mile it will spit some oil into the transmission housing and will drip out onto the garage floor over time. I also have an '87 Wrangler with AMC 258 engine, needless to say both vehicles have cardboard underneath.
Re: 440 stroker short block assembly. [Re: CSK] #3271611
11/21/24 05:47 AM
11/21/24 05:47 AM
eastern,Ky
eastern,Ky
Best offer so far lol
Re: 440 stroker short block assembly. [Re: 70RT Charger] #3271776
11/21/24 09:08 PM
11/21/24 09:08 PM
Kansas
Thelma133 Offline
Thelma133  Offline
Kansas
Try O’Neill porting and machine, Benton, Ks. Karl will probably answer, 316-874-6648. He is building my 572, and then my low deck 499. Good people.
Re: 440 stroker short block assembly. [Re: Thelma133] #3271831
11/22/24 08:51 AM
11/22/24 08:51 AM
PA
moparacer Offline
moparacer  Offline
PA
I must be the second luckiest person in the world because I have never had a rear main seal leak on a big block or small block either. All with aftermarket cranks. I use Ultra Grey and put a thin coating on the outside of seal. Clock it 1/4 inch offset to the retainer cap, put a thin coating on the cap, tighten it down and fill cavity on retainer and outside channel with ultra grey. Done. All with Felpro seals and factory retainer cap.
Maybe I should branch off into the Mopar rear main seal replacement industry. laugh2
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 5.44-126
414 cid SB Dragster 7.65-174
Re: 440 stroker short block assembly. [Re: moparacer] #3271836
11/22/24 09:36 AM
11/22/24 09:36 AM
eastern,Ky
eastern,Ky
Wait a minute. Andy F just said they all leaked, especially the aftermarket stuff. You need a job?
Re: 440 stroker short block assembly. [Re: 70RT Charger] #3271902
11/22/24 07:20 PM
11/22/24 07:20 PM
Cab_Burge Online work
Cab_Burge  Online Work
you have a PM scope up work
