Re: new cheap magnum spring upgrade for moderate cams [Re: patrick] #32708
12/23/06 09:10 AM
12/23/06 09:10 AM
Grand Haven, MI
patrick Offline OP
patrick  Offline OP
Grand Haven, MI
close up of GM springs on the head
2017 Grand Cherokee Overland
Re: new cheap magnum spring upgrade for moderate cams [Re: patrick] #32709
12/23/06 09:13 AM
12/23/06 09:13 AM
Grand Haven, MI
patrick Offline OP
patrick  Offline OP
Grand Haven, MI
close up of mag spring and GM spring on the head
Re: new cheap magnum spring upgrade for moderate cams [Re: patrick] #32710
12/23/06 01:51 PM
12/23/06 01:51 PM
Tri-Cities, Washington
V
VITC_GTX Online content
VITC_GTX  Online Content
V
Patrick-
Scott Brown sent me the MP high-lift springs (P4876062) for my Magnum heads to work with his cam (.520 lift). I was looking to get the retainers (P4452032) for them, but like you said they are like $9 each. Can I get an OEM set off of a 2.2 or 2.5 from a jy that will work instead?
Re: new cheap magnum spring upgrade for moderate cams [Re: VITC_GTX] #32711
12/25/06 02:08 PM
12/25/06 02:08 PM
Grand Haven, MI
patrick Offline OP
patrick  Offline OP
Grand Haven, MI
they should (2.2L/2.5L retainers). I'd love to see some spring rate and coil bind height info on those MP springs...
Re: new cheap magnum spring upgrade for moderate cams [Re: patrick] #32712
12/25/06 04:37 PM
12/25/06 04:37 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Took my computer like an hour to down load them but looks like what I been doing. Glad to here I wasn't off my rocker about this. 2 motors and soon a third running around here set up like this.
Re: new cheap magnum spring upgrade for moderate cams [Re: patrick] #32713
12/25/06 10:02 PM
12/25/06 10:02 PM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
Yeah, its kind of odd that they don't publish any of the specs on their Mag springs... you have to dig even to find the installed height. Don't know what they are thinking, but I don't like it.
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
Re: new cheap magnum spring upgrade for moderate cams [Re: HotRodDave] #32714
12/30/06 10:04 AM
12/30/06 10:04 AM
Grand Haven, MI
patrick Offline OP
patrick  Offline OP
Grand Haven, MI
what cams are you running with these springs, out of curiousity. I'm planning on swapping the mag heads on my XE262 shortblock, which will yield like .493/.501 lift, which from my measurements, look marginal, unless I sink the valves about .030 or so.....
for someone currently running a .440-.450 lift cam (which turn into a .470-.480 lift cam) these would be the cat's meow...
Re: new cheap magnum spring upgrade for moderate cams [Re: VITC_GTX] #32715
12/30/06 10:17 AM
12/30/06 10:17 AM
Mass
dgc333 Offline
dgc333  Offline
Mass
Patrick-
I am using 2.2/2.5 retainers with the MP springs and they work out just fine. You do need to use the locks from the magnum retainers though. The 2.2/2.5 uses a multi-groove lock where the magnum is a single groove.
Dave Clement Pembroke, MA 03 PT Cruiser GT Turbo 99 Dakota SLT+ CC 4x4 68 Barracuda sport coupe http://home.comcast.net/~dgc333/
Re: new cheap magnum spring upgrade for moderate cams [Re: dgc333] #32716
01/23/07 09:35 PM
01/23/07 09:35 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Patrick did you find out any more, like preasure on the seat and mabey .500 lift?
Re: new cheap magnum spring upgrade for moderate cams [Re: HotRodDave] #32717
01/24/07 05:34 PM
01/24/07 05:34 PM
Grand Haven, MI
patrick Offline OP
patrick  Offline OP
Grand Haven, MI
should be able to calculate that out by looking at the free length and spring rate.
"blueprint" specs were free length of 1.94", and spring rate of 365lb/in, so with the 1.6" IH I measured with the 3100 retainers, that would yield a seat pressure of 124lb, and a .5" lift pressure of 306lb.
the springs I had tested were 1.875" free length, 330lb/in, and the installed height (on my heads) will be ~1.6". so seat pressure should be .275*330, or 91 lbs, and .5" lift will be .775*330, or 256lb.
remember, coil bind was measured at .81" lift on those springs, (1.065") so .5" lift with my measured IH would only leave you .035" before coil bind. I think I'll probably use these springs, but I'll see about sinking the valves .030" or so (to gain IH), which will leave me ~.060 before coil bind with my cam. This seems like the most cost effective way, since I plan on getting a VJ done on them anyway, and I'll probably get a 5 angle 75/60/45/30/15 so sinking them shouldn't hurt flow as much with the 15 degree cut...I'd wager it'll add a CC or two to my combustion chamber, though.
Re: new cheap magnum spring upgrade for moderate cams [Re: patrick] #32718
02/08/07 01:01 AM
02/08/07 01:01 AM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Could this go to the archives for future referance? Lots of goo info here, Thanks Patrick!!
Re: new cheap magnum spring upgrade for moderate cams [Re: GO_Fish] #32719
09/18/07 01:44 PM
09/18/07 01:44 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
P5249464 116lbs @ 1.625, 251lbs @ 1.125
P4876062 131 @ 1.625, 305 @ 1.125
Rec'd installed height of 1.64 for both, can't find coil bind height for either one.
