Re: 71 Cuda Paint Job Project
[Re: modelmakerinc]
#3271243
11/19/24 09:56 AM
11/19/24 09:56 AM
Posts: 2,412 west palm beach, florida
modelmakerinc
passenger side WORSE Bad Patch warped the [censored] out of the panel, Again they had tons of filler to make it SEEM straight. hard to make out in the pic but the warp is about 5/16 to 3/8 at its worst. welded and plastered over Just so bothersome. I am looking for a partial quarter skin, a few inches below the beltline from the door to the wheelwell. if anyone has this either OG or repop Plase PM me here.
[Re: modelmakerinc]
#3271288
11/19/24 12:47 PM
11/19/24 12:47 PM
modelmakerinc
Within the window for chem adhesion I went ahead and did the first coat of 2K. This will allow me to continue with all the other fab and repair needed elsewhere on the car. With a 120 scuff and a clean surface, the filler I use will have an excellent adhesion and the layers below my work are sealed.
Cant see in these pics but I masked off the areas that still need fab. The trunk jamb, Dutchman, Sail panels and Tail panel will only need blocking before final prime/seal.
[Re: modelmakerinc]
#3271291
11/19/24 12:53 PM
11/19/24 12:53 PM
modelmakerinc
Dutchman to quarter panel seam and drip rail, corner detail, trunk jamb all worked and good to go. Just the beginning of knocking areas off the "Things To Do" list
