Page 5 of 5 1 2 3 4 5
Re: 71 Cuda Paint Job Project [Re: modelmakerinc] #3276428
12/16/24 07:12 AM
12/16/24 07:12 AM
west palm beach, florida
modelmakerinc Offline OP
reinstalled the door, aligned and gapped. It will come off again when the car comes apart for color
Exceptional Architectural, Yacht and Automotive scale models. e-mail modelmakerinc@att.net for a portfolio review. www.modelmakerinc.com
Re: 71 Cuda Paint Job Project [Re: modelmakerinc] #3276430
12/16/24 07:22 AM
12/16/24 07:22 AM
Moved to the pass side and tore into lower A-pillar. Found a little rot, much more solid than drivers side. CUT, BLAST,FAB,PREP,WELD,GRIND,SAND, DONE, NEXT....
Re: 71 Cuda Paint Job Project [Re: modelmakerinc] #3276431
12/16/24 07:28 AM
12/16/24 07:28 AM
Back to the pass side lower front quarter rocker area, I left primer off of the area knowing I would be cutting this out, The straight edge shows how much of a warp bulge they put into the panel. the red square shows how flat it became once the panel was cut and relieved.
Re: 71 Cuda Paint Job Project [Re: modelmakerinc] #3276432
12/16/24 07:39 AM
12/16/24 07:39 AM
Doner panel from a goodmark skin. Really helpful having a panel already close to shape. But the details are just CRAP. The rocker flange is inadequate, the drain is non existent, the folds at the door and at the fender were very soft (rounded over) so plenty of hammer dolly to tighten them up. Overall it saves plenty of time but these panels all need plenty of touch time.
Re: 71 Cuda Paint Job Project [Re: modelmakerinc] #3276433
12/16/24 07:54 AM
12/16/24 07:54 AM
Welded a bead across the gap left by the lead removal along the rocker, patch panel installed and straight. almost zero deflection at the weld seam, the wheel lip is wonky cause in its previous life someone cut and hammered the flange up. tsk
Re: 71 Cuda Paint Job Project [Re: modelmakerinc] #3276434
12/16/24 07:57 AM
12/16/24 07:57 AM
Last few pics for a couple months. Merry Christmas everybody
Re: 71 Cuda Paint Job Project [Re: modelmakerinc] #3280887
01/06/25 10:28 AM
01/06/25 10:28 AM
Did a little over the Christmas break, I have a contract for a model yacht due in March so little to no update till then after today.
Stripped the gallons of filler off the door to find (not surprisingly) poor patches and hidden rot, the door is much better than so many original units that are available so I will be repairing this one unless a good one turns up.
Re: 71 Cuda Paint Job Project [Re: modelmakerinc] #3280888
01/06/25 10:30 AM
01/06/25 10:30 AM
The lower front inner corner looked like gobs of bubble gum eekwhen i stripped the paint off. The door skin has a bunch of high spots (dings) made from inside, and plenty of areas that will need attention.
Re: 71 Cuda Paint Job Project [Re: modelmakerinc] #3280894
01/06/25 10:42 AM
01/06/25 10:42 AM
Put the driver door, Passenger jamb and rocker repairs in Epoxy and High Build. The repair fab work is nearing its end and I will get into filler, blocking and prep for base coat very soon grin
Re: 71 Cuda Paint Job Project [Re: modelmakerinc] #3280897
01/06/25 10:52 AM
01/06/25 10:52 AM
Then I find the next surprise. whiney not really too bad, I will cut out some of the inner structure to access the backside of these areas and repair accordingly. The structure will be welded back into position. I am getting excited to move into the body work phase to really get a good look at a fresh straight and proper base for painting.
Re: 71 Cuda Paint Job Project [Re: modelmakerinc] #3285145
01/26/25 05:45 PM
01/26/25 05:45 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I would expect that when the weight pf the glass, regulators, & etc are added to the doors that they'll hang lower at the rear.
You may have already checked and/or accounted for that, just thought I'd mention it.
Re: 71 Cuda Paint Job Project [Re: topside] #3285269
01/27/25 08:21 AM
01/27/25 08:21 AM
Yep, But complete or empty the door has to be exactly where it is when finished. When the door has all the parts in it, it will need to be adjusted/ aligned again. When the car has its final prime, the engine compartment, trunk and glass channels will have color it will go to the owners shop for some sub assemblies to be installed. I expect it to come back as a roller with all the glass installed for final fitting of sheetmetal, blocking and paint.
