1996 Cadillac El Camino
#3270544
11/14/24 11:07 PM
11/14/24 11:07 PM
Posts: 21,459 Eagle, Idaho
Neil
The Doctor is in.
The Doctor is in.
Eagle, Idaho
Re: 1996 Cadillac El Camino
[Re: Neil]
#3270551
11/15/24 12:54 AM
11/15/24 12:54 AM
Posts: 1,054 Colorado
dssaa
Colorado
[Re: dssaa]
#3270565
11/15/24 09:00 AM
11/15/24 09:00 AM
Posts: 20,468 Puttin' on the foil in Charles...
not_a_charger
Mr. Big Shot Moparts Moderator
If you’ve ever wondered what a more modern el Camino would be like No one has ever wondered this.
Earning every penny of that moderator paycheck.
DBAP
"They don't think it be like it is, but it do." - Oscar Gamble
[Re: not_a_charger]
#3270573
11/15/24 09:34 AM
11/15/24 09:34 AM
Posts: 5,504 Star Idaho
67vertman
Star Idaho
$7900 for a clapped out POS! Nothing on that car was done right. The only use would be a demolition derby car.
My Monster are real!
Living within your means makes life pretty easy.
[Re: 67vertman]
#3270592
11/15/24 11:42 AM
11/15/24 11:42 AM
Posts: 16,673 On the run…
BloFish
On the run…
$7900 for a clapped out POS! Nothing on that car was done right. The only use would be a demolition derby car. And that’s a maybe.
It really doesn't matter whether you win or lose… as long as you look good doing it!
‘65 A100 ‘69 ‘Cuda ‘73 Vega GT ‘06 Mega Cab ‘14 Mercedes SLK
[Re: BloFish]
#3270618
11/15/24 01:05 PM
11/15/24 01:05 PM
67vertman
Star Idaho
$7900 for a clapped out POS! Nothing on that car was done right. The only use would be a demolition derby car. And that’s a maybe. Yep, the way they cut the roof off, and probably didn't add any supports, the first hit and it would fold in half.
[Re: redraptor]
#3270636
11/15/24 02:28 PM
11/15/24 02:28 PM
Posts: 4,852 Wichita
GY3
Wichita
I've seen some very well done "flower car" Cadillacs done for funeral homes.
This is obviously not one of them.
'63 Dodge 330
11.19 @ 121 mph Pump gas, n/a, through the mufflers on street tires with 3.54's. 3,600 lbs.
9.92 @ 135mph with a 350 shot of nitrous and 93 octane pump. 1.43 60 ft. 3,750 lbs.
[Re: 67vertman]
#3270646
11/15/24 04:22 PM
11/15/24 04:22 PM
Posts: 1,086 Central Michigan
nuthinbutmopar
Central Michigan
$7900 for a clapped out POS! Nothing on that car was done right. The only use would be a demolition derby car. Demolition derbies specifically bar hearses, limousines, and other non-factory customizations. Take it straight to the crusher.
[Re: nuthinbutmopar]
#3270651
11/15/24 04:42 PM
11/15/24 04:42 PM
not_a_charger
$7900 for a clapped out POS! Nothing on that car was done right. The only use would be a demolition derby car. Demolition derbies specifically bar hearses, limousines, and other non-factory customizations. Take it straight to the crusher. Because they are death traps built by hacks.
DBAP
[Re: not_a_charger]
#3270680
11/15/24 10:52 PM
11/15/24 10:52 PM
Posts: 16,934 Between Houston & Galveston TX
SattyNoCar
This thing is so bad, it's an obvious hack job. Compared to an 'actual' flower car, this thing is nothing more than a hearse with part of the roof whacked off. Maybe the Funeral Home did it rather than buy a new dedicated car? Who knows. A 'real' flower car......
John
