Re: Dim dash lights
[Re: cudaman1969]
#3270616
11/15/24 01:02 PM
11/15/24 01:02 PM
Posts: 5,504 Star Idaho
67vertman
Star Idaho
Ground first. then switch. how are the other lights?
My Monster are real!
Living within your means makes life pretty easy.
Re: Dim dash lights
[Re: 67vertman]
#3270644
11/15/24 04:14 PM
11/15/24 04:14 PM
Posts: 8,833 fredericksburg,va
cudaman1969
Itch Nutz
Itch Nutz
fredericksburg,va
Ground first. then switch. how are the other lights? The AC-heat cluster is bright, not sure if hooked to the light switch, now that i think about it that light comes on when light switch is pulled.
