Slant 6 OEM Alum bellhousing for sale
[Re: moparts]
#3268100
11/04/24 04:35 PM
11/04/24 04:35 PM
Posts: 23,533 Here
jcc
Here
In very good used condition, as pictured $95 OBO plus shipping PM
"When one’s appeal is emotional, it does not matter if there is no substance."
SB Lakewood Scattershield For Sale
[Re: moparts]
#3268140
11/04/24 06:43 PM
11/04/24 06:43 PM
Posts: 23,533 Here
jcc
Here
Like new, never mounted, as is. Unfortunately, at this time, the whereabouts of the 1/8"? steel block shield is unknown, Will be forwarded if ever found. $350, plus shipping PM
4Spd 833 style Alum OD Trans For Sale
[Re: jcc]
#3268143
11/04/24 06:55 PM
11/04/24 06:55 PM
Posts: 23,533 Here
jcc
Here
1"-23 Alum OD 4 speed, As is Other than it turns freely, I know little about the unit. I bought it as it sits $350, plus shipping, might be able to deliver east of Mississippi for reasonable agreed upon fee, PM
CSI Mopar Transmission Shield For Sale
[Re: moparts]
#3268157
11/04/24 07:37 PM
11/04/24 07:37 PM
Posts: 23,533 Here
jcc
Here
CSI Auto trans composite Shield New, never mounted, as Is, past it's 5-year certification Believe this is a small block shield but unsure if for 727 or 904 $350 OBO plus shipping PM
Sale Pending
Re: CSI Mopar Transmission Shield For Sale
[Re: sixty9redgtx]
#3269927
11/11/24 07:46 PM
11/11/24 07:46 PM
Posts: 10 Austin, TX
vrenlos
Austin, TX
John Cope Pro Street Auto Shift Small Block 727 Transmission
Purchased new from CRT in 2020 and went a different direction with my swap. These are no longer built/offered by Cope. Details from catalog included below, good for 500+ HP. Normal/forward auto valve body. Never used or installed and still in the plastic wrap!
727 Pro Street Automatic shift Includes CRT automatic shift valve body with a performance shift kit, red clutches 5 in the front drum, kolene steels, red lined bands, Teflon rings, low/reverse billet servo, 4.2 lever, thick 2nd gear band strut, 3 pinion planets, CRTs deep aluminum pan with billet filter extension, bolt-in sprag, This transmission does require kick-down linkage
Can provide pics on request, but it's not much to look at as it's still in plastic. Has been garage stored and never mounted/opened/etc. asking what I'm into it for: $2600 - located in Austin TX.
