Hemi carb questions please #3268332
11/05/24 03:46 PM
11/05/24 03:46 PM
Enjoy life today, It has an ex...
gtx6970 Offline OP
gtx6970  Offline OP
I'm having some major carb flooding issues. Actually leaking out and causing puddles on the intake.
This is in my front carb only
Can someone confirm if I have the secondary boosters in the correct sides?
Correct gaskets ?
Just ckign I have it assembled correctly while I have it opened up cking floats and levels
Enjoy life today, It has an expiration date
Re: Hemi carb questions please [Re: gtx6970] #3268383
11/05/24 07:10 PM
11/05/24 07:10 PM
The stock secondary boosters will only go in one way due to the machine notches in them and the cast protrusion made for those notches.
That being said your rear booster don't match each other exactly, I wonder if one of them got replaced along the way before you getting those carbs work confused
What say you street hemi guys? help
2nd look, remove that gasket and see if they are alike after all wrench scope
Re: Hemi carb questions please [Re: Cab_Burge] #3268406
11/05/24 08:58 PM
11/05/24 08:58 PM
fredericksburg,va
cudaman1969 Offline
Itch Nutz
cudaman1969  Offline
Itch Nutz
fredericksburg,va
What year carbs?
