Re: Low buck 360 stroker - anybody done this? [Re: gregsdart] #3266036
10/23/24 01:41 PM
10/23/24 01:41 PM
Weddington, N.C.
Streetwize Offline OP
Weddington, N.C.
I like the Idea, I'm only aware of a 5.7 and 6.0" rod for a SBC below/ = 6.00"
I know the factory 400 SBC ran something like a 5.565" rod for the 3.75 stroke in a 9.02" deck.
I know a lot of LS guys actually prefer the 3.9" stroke to the 4.00" so maybe if I (hopefully never) spin a rod bearing I'll destroke it slightly.
500 Duster,
Maybe that was a 372 which is a 360 3.58" with the mains cut down and stuck in a 340 block?
WIZE
In Car:
Re: Low buck 360 stroker - anybody done this? [Re: Streetwize] #3266145
10/23/24 11:36 PM
10/23/24 11:36 PM
Melbourne , Australia
LA360 Offline
LA360  Offline
Originally Posted by Streetwize
LA360 I was calculating about .090 from the .125 difference in throw and that was based on what the late Paul Savadin (Paul’s crank shop) told me was possible on a cast steel crank mainly because you don’t have the fillet radius (like a forging) to contend with… so you can go out closer to the max offset and you really only need about .0015-002 to clean up the journal. Maybe most shops can’t take one out that far. He was considered by most of his peers to be the best in the business.
I'm a visual person, so I drew it up in CAD to see the difference. We don't work in Units of Freedom down here, so the picture is in millimeters.
Alan Jones
