Re: Won KOS at MIR Saturday!
[Re: Dragula]
#3265437
10/20/24 09:32 PM
10/20/24 09:32 PM
Posts: 7,541 Minnesota
Hemi_Joel
Minnesota
Wow, congrats! How about a play-by-play?
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: dvw]
#3265489
10/21/24 09:45 AM
10/21/24 09:45 AM
Posts: 2,551 PA
moparacer
PA
Congrats! Really gratifying when all the hard work pays off! Saturday was a great day to be a Mopar fan! I won Super ET at the SBRA Bracket Finals at Mason Dixon too.
67 Barracuda street/bracket car 11.27-119 68 Dart 502 BB 5.46-125 414 cid SB Dragster 7.65-174
[Re: Hemi_Joel]
#3265496
10/21/24 10:42 AM
10/21/24 10:42 AM
Posts: 4,760 On the parachute mount
n20mstr
Wow, congrats! How about a play-by-play? It was pretty hectic for sure. We left late friday , did not get there until 11:30pm friday night Had to sleep in the truck at the gate. Sat am had to run the valves and check the springs real quick. Made the first test hit, car went right down on a soft tuneup because i had changed the nitrous jets to try and clean up the fuel a little. Next test hit we added some timing after 1.03 sec, but it spun because the track was not consistent from the first test hit SO we knew that we would be hit or miss on the track prep. For first round i took out some timing in the begining to make sure it went down. ALso loosened the front shock just a little . First round i drew Leon, not an easy draw for sure. We went right down even though the track was marginal. I cant say the times because its a NO time race. Second round i drew Dan Vanhorn, challenger with a gen 3 hemi. It was going to be a very close race as we pretty much run identical ets. However Dan had a problem and i had a competition bye. I had added some timing from 1.03 on and it really woke the car up, we picked up 3.6 mph . Third round i drew the bye Final round i had to run a Duster , and honestly dont know the combo, but i won that, even though i spun down track Data log showed the driveshaft and rpm shot up at 3.3 sec into the run. The RPM spiked from 7200 to 7800, i lifted and put it in neutral, clicked it off and coasted through for the win. It was tough all day because you didnt know what surface you were getting, sometimes they did a full out prep with the rotator and sprayed it, some rounds they just dragged it. Really had to leave soft , although we did manage a best 60 of 1.12 and the slowest was 1.15
....BAD A$$ STREET CAR.....
[Re: n20mstr]
#3265613
10/21/24 04:22 PM
10/21/24 04:22 PM
Posts: 4,821 Wichita
GY3
Wichita
that 7/16 been getting used a little lately Lol! Mine too! We were all primed to go to a radial prep test and tune on Friday night and maybe get that 9.7x.. Truck, trailer all ready and the car decides to spring a leak on the upper tank of the radiator just before loading...
'63 Dodge 330
11.19 @ 121 mph Pump gas, n/a, through the mufflers on street tires with 3.54's. 3,600 lbs.
9.92 @ 135mph with a 350 shot of nitrous and 93 octane pump. 1.43 60 ft. 3,750 lbs.
[Re: GY3]
#3265634
10/21/24 05:45 PM
10/21/24 05:45 PM
Posts: 5,036 new jersey usa
11secdart
new jersey usa
Congrats Tony !!! good job !!
[Re: GY3]
#3265637
10/21/24 05:48 PM
10/21/24 05:48 PM
Posts: 732 NY
XXHEMI
NY
[Re: n20mstr]
#3265643
10/21/24 06:10 PM
10/21/24 06:10 PM
Posts: 1,554 baldwinsville new york
a493demon
Wow, congrats! How about a play-by-play? It was pretty hectic for sure. We left late friday , did not get there until 11:30pm friday night Had to sleep in the truck at the gate. Sat am had to run the valves and check the springs real quick. Made the first test hit, car went right down on a soft tuneup because i had changed the nitrous jets to try and clean up the fuel a little. Next test hit we added some timing after 1.03 sec, but it spun because the track was not consistent from the first test hit SO we knew that we would be hit or miss on the track prep. For first round i took out some timing in the begining to make sure it went down. ALso loosened the front shock just a little . First round i drew Leon, not an easy draw for sure. We went right down even though the track was marginal. I cant say the times because its a NO time race. Second round i drew Dan Vanhorn, challenger with a gen 3 hemi. It was going to be a very close race as we pretty much run identical ets. However Dan had a problem and i had a competition bye. I had added some timing from 1.03 on and it really woke the car up, we picked up 3.6 mph . Third round i drew the bye Final round i had to run a Duster , and honestly dont know the combo, but i won that, even though i spun down track Data log showed the driveshaft and rpm shot up at 3.3 sec into the run. The RPM spiked from 7200 to 7800, i lifted and put it in neutral, clicked it off and coasted through for the win. It was tough all day because you didnt know what surface you were getting, sometimes they did a full out prep with the rotator and sprayed it, some rounds they just dragged it. Really had to leave soft , although we did manage a best 60 of 1.12 and the slowest was 1.15 You forgot about the turtle
[Re: HardcoreB]
#3265721
10/21/24 10:12 PM
10/21/24 10:12 PM
n20mstr
Very well-earned...congrats!!! Are you going back for WCF next weekend? Any classes that cross-over to your combo? "Wild-street?" Not going to that
[Re: a493demon]
#3265722
10/21/24 10:15 PM
10/21/24 10:15 PM
n20mstr
Wow, congrats! How about a play-by-play? It was pretty hectic for sure. We left late friday , did not get there until 11:30pm friday night Had to sleep in the truck at the gate. Sat am had to run the valves and check the springs real quick. Made the first test hit, car went right down on a soft tuneup because i had changed the nitrous jets to try and clean up the fuel a little. Next test hit we added some timing after 1.03 sec, but it spun because the track was not consistent from the first test hit SO we knew that we would be hit or miss on the track prep. For first round i took out some timing in the begining to make sure it went down. ALso loosened the front shock just a little . First round i drew Leon, not an easy draw for sure. We went right down even though the track was marginal. I cant say the times because its a NO time race. Second round i drew Dan Vanhorn, challenger with a gen 3 hemi. It was going to be a very close race as we pretty much run identical ets. However Dan had a problem and i had a competition bye. I had added some timing from 1.03 on and it really woke the car up, we picked up 3.6 mph . Third round i drew the bye Final round i had to run a Duster , and honestly dont know the combo, but i won that, even though i spun down track Data log showed the driveshaft and rpm shot up at 3.3 sec into the run. The RPM spiked from 7200 to 7800, i lifted and put it in neutral, clicked it off and coasted through for the win. It was tough all day because you didnt know what surface you were getting, sometimes they did a full out prep with the rotator and sprayed it, some rounds they just dragged it. Really had to leave soft , although we did manage a best 60 of 1.12 and the slowest was 1.15 You forgot about the turtle Here’s the poor turtle that was trying to cross the track , I dragged him pretty far , then when I turned off he slid to the side . Poor guy was minding his business
[Re: n20mstr]
#3265764
10/22/24 07:31 AM
10/22/24 07:31 AM
Posts: 8,237 Plymouth, MI
Blusmbl
Plymouth, MI
Awesome job!!! Congrats!!! Did you drag the turtle with your chutes??
[Re: n20mstr]
#3265985
10/23/24 09:54 AM
10/23/24 09:54 AM
Posts: 1,351 Loudoun County, VA
Brad_Haak
Loudoun County, VA
2021 Challenger 6.4L Scat Pack 1320 100% stock: 1.680, 11.894 at 113.75 (DA 175 ft) weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008] pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
[Re: Brad_Haak]
#3266069
10/23/24 04:46 PM
10/23/24 04:46 PM
Posts: 2,499 Sydney,Australia
tex013
Sydney,Australia
well done . cant imagine how more difficult that style of racing is
Tex
New best ET 10.259@129.65 . New best MPH 130.94 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
