Holley 4150 wet carb base gasket
#3265189
10/19/24 04:26 PM
10/19/24 04:26 PM
Posts: 1,373 Costa Mesa, CA
chache876
Costa Mesa, CA
I posted this on another forum but I wanted to get some more opinions.
I rebuilt my holley 650cfm double pumper carburetor (List 4777-5) and after reinstalling it, the engine had a high idle and unresponsive idle adjustment and idle mixture screws. I pulled the carb to verify the transfer slots on the primaries and secondaries were not over exposed and I noticed that the base gasket was wet. I did torque the carb to I think 75 or 80 in lbs per holley's website. The transfer slots looked ok so I am hoping this might be related.
The image shows what the gasket looked like after about 15 minutes of run time. There were no external fuel leaks. What would normally cause this? Warped baseplate?
Re: Holley 4150 wet carb base gasket
[Re: chache876]
#3265222
10/19/24 08:23 PM
10/19/24 08:23 PM
Posts: 10,622 Rittman Ohio
fourgearsavoy
Rittman Ohio
You could put a straight edge across it and you would know for sure. Looks almost like it might be pulling fuel from the power valve. There is so much fuel in the intake floor it's pulling it from somewhere. Double check the gasket under the power valve because sometimes they can get off center when you install the valve. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
