Well. I spoke too soon. I’m sitting in front of the car, running, with the high beams on. These are two photos taken within seconds of each other. The problem is, I’m the only one in the shop. Off then on. This is crazy. You can hear the new relay clicking on then off. Maybe this is related to the headlight switch. Man I’m stumped. I’ll try the resistors thing next after I call someone that works with led headlights. I have not tried my incandescent bulbs on high to see it it does this.
