Re: 66 Belvedere in SoCal
[Re: not_a_charger]
#3265083
10/19/24 05:58 AM
10/19/24 05:58 AM
Posts: 823 Eastern WA
ProStock1320
Eastern WA
FWIW, I would seriously question what's hiding under all that blue paint. My guess is, based on the laziness not to at least mask things off (see door latch assembly for example), any repair work attempted underneath the paint will be equally soddy. It needs a thorough in person inspection. If the only flaws are those in the pics, $22K might be a good starting point for the seller but I'll bet you could get it for $15-16K (if not less) if you show up with cash and a trailer.
[Re: IROC78]
#3265117
10/19/24 11:29 AM
10/19/24 11:29 AM
Posts: 5,336 Star Idaho
67vertman
Star Idaho
Could those exhaust tip protrude any further form the bummer They are a real leg burner.
My Monster are real!
Living within your means makes life pretty easy.
[Re: ProStock1320]
#3265119
10/19/24 11:34 AM
10/19/24 11:34 AM
Posts: 20,424 Puttin' on the foil in Charles...
not_a_charger
Mr. Big Shot Moparts Moderator
FWIW, I would seriously question what's hiding under all that blue paint. My guess is, based on the laziness not to at least mask things off (see door latch assembly for example), any repair work attempted underneath the paint will be equally soddy. 100%. Also necessary to question the judgement of anyone driving around with a floor jack just rolling around in the trunk too.
Earning every penny of that moderator paycheck.
DBAP
"They don't think it be like it is, but it do." - Oscar Gamble
[Re: ProStock1320]
#3265262
10/20/24 01:00 AM
10/20/24 01:00 AM
Posts: 1,031 Colorado
dssaa
Colorado
Guy (Luis) says he 'thinks' there is a 742 8 3/4 underneath. Doesn't know if it is a sure grip or what the gearing is. He said I should call him so he can describe how it drives. Sketchy answers to go along with a sketchy car. No thank you; I'm out. HIgh hopes, but I am out too....
