Re: 727 sfi case
[Re: racerx]
#3265084
10/19/24 06:25 AM
10/19/24 06:25 AM
Posts: 3,001 A shed in England
Tig
A shed in England
Wondering if it will fit in a stock tunnel ...Looks beefy and pricy. Looks unlikely that it will fit on a E Body without raising and/or widening the tunnel. I know a couple of guys who have swapped to TH400 types (B bodies) and they had to modify the tunnels any way. I'm going to go with some sort of aftermarket gearbox before we run the 655 with N2O so it's an option if it will take a lot of tq but at the rate we are progressing that's a long way off
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
Re: 727 sfi case
[Re: dvw]
#3265099
10/19/24 09:35 AM
10/19/24 09:35 AM
Tig
A shed in England
If a car has enough power to need an SFI case retaining the stock tunnel isn't much of a stumbling block. Doug Agreed but what is the max a stock 727 case will take ? I was told around 1000lb/ft or 1200hp with an all out build but this was quite a few years ago. We'll be 1750 ish when the N2O is on.
Re: 727 sfi case
[Re: Tig]
#3265146
10/19/24 01:25 PM
10/19/24 01:25 PM
Posts: 209 Connellsville
71Demon528
Connellsville
If a car has enough power to need an SFI case retaining the stock tunnel isn't much of a stumbling block. Doug Agreed but what is the max a stock 727 case will take ? I was told around 1000lb/ft or 1200hp with an all out build but this was quite a few years ago. We'll be 1750 ish when the N2O is on. 727 cases don't "fail" unless something inside fails and exits the case. There are currently people out there 1600-1700hp in a 727. Stock case obviously. Once you get above that level, the converter core becomes the issue. You need a big enough converter to handle that high of power level (upwards of 2,000hp), and without a 5/8-3/4" mid plate, you cannot get a big enough converter core for a 727 without the use of the thick mid plate, which most people can't run, especially in a unibody with a stock crossmember location. This SFI 727 case and bell housing was produced by FI performance years ago. In 2019, A&A was approached by FI performance about investing in the case, and selling the case for FI. The problem was, the case did not fit into a car with a stock floor and firewall. They showed FI that and in turn, would not invest or sell the case unless the issue was corrected. It does not appear they corrected the issue as you can tell from the video, the case is extremely thick and bulky. I highly doubt this will fit in anyone's unibody car without serious modification to the floor and firewall. I caution anyone who wants to buy one of these until there is some feedback that it is working well for others. Just my opinion.
Re: 727 sfi case
[Re: 71Demon528]
#3265220
10/19/24 08:12 PM
10/19/24 08:12 PM
Posts: 4,648 Motor City
6PKRTSE
Motor City
I just have an SFI bell and I still had to enlarge my tunnel to make it fit.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
