Re: 727 sfi case
[Re: racerx]
#3265084
10/19/24 06:25 AM
10/19/24 06:25 AM
Posts: 3,001 A shed in England
Tig
A shed in England
Wondering if it will fit in a stock tunnel ...Looks beefy and pricy. Looks unlikely that it will fit on a E Body without raising and/or widening the tunnel. I know a couple of guys who have swapped to TH400 types (B bodies) and they had to modify the tunnels any way. I'm going to go with some sort of aftermarket gearbox before we run the 655 with N2O so it's an option if it will take a lot of tq but at the rate we are progressing that's a long way off
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
Re: 727 sfi case
[Re: dvw]
#3265099
10/19/24 09:35 AM
10/19/24 09:35 AM
Tig
A shed in England
If a car has enough power to need an SFI case retaining the stock tunnel isn't much of a stumbling block. Doug Agreed but what is the max a stock 727 case will take ? I was told around 1000lb/ft or 1200hp with an all out build but this was quite a few years ago. We'll be 1750 ish when the N2O is on.
