Re: 727 sfi case
[Re: racerx]
#3265084
10/19/24 06:25 AM
10/19/24 06:25 AM
Posts: 3,004 A shed in England
Tig
A shed in England
Wondering if it will fit in a stock tunnel ...Looks beefy and pricy. Looks unlikely that it will fit on a E Body without raising and/or widening the tunnel. I know a couple of guys who have swapped to TH400 types (B bodies) and they had to modify the tunnels any way. I'm going to go with some sort of aftermarket gearbox before we run the 655 with N2O so it's an option if it will take a lot of tq but at the rate we are progressing that's a long way off
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
Re: 727 sfi case
[Re: dvw]
#3265099
10/19/24 09:35 AM
10/19/24 09:35 AM
Tig
A shed in England
If a car has enough power to need an SFI case retaining the stock tunnel isn't much of a stumbling block. Doug Agreed but what is the max a stock 727 case will take ? I was told around 1000lb/ft or 1200hp with an all out build but this was quite a few years ago. We'll be 1750 ish when the N2O is on.
Re: 727 sfi case
[Re: Tig]
#3265146
10/19/24 01:25 PM
10/19/24 01:25 PM
Posts: 209 Connellsville
71Demon528
Connellsville
If a car has enough power to need an SFI case retaining the stock tunnel isn't much of a stumbling block. Doug Agreed but what is the max a stock 727 case will take ? I was told around 1000lb/ft or 1200hp with an all out build but this was quite a few years ago. We'll be 1750 ish when the N2O is on. 727 cases don't "fail" unless something inside fails and exits the case. There are currently people out there 1600-1700hp in a 727. Stock case obviously. Once you get above that level, the converter core becomes the issue. You need a big enough converter to handle that high of power level (upwards of 2,000hp), and without a 5/8-3/4" mid plate, you cannot get a big enough converter core for a 727 without the use of the thick mid plate, which most people can't run, especially in a unibody with a stock crossmember location. This SFI 727 case and bell housing was produced by FI performance years ago. In 2019, A&A was approached by FI performance about investing in the case, and selling the case for FI. The problem was, the case did not fit into a car with a stock floor and firewall. They showed FI that and in turn, would not invest or sell the case unless the issue was corrected. It does not appear they corrected the issue as you can tell from the video, the case is extremely thick and bulky. I highly doubt this will fit in anyone's unibody car without serious modification to the floor and firewall. I caution anyone who wants to buy one of these until there is some feedback that it is working well for others. Just my opinion.
Re: 727 sfi case
[Re: 71Demon528]
#3265220
10/19/24 08:12 PM
10/19/24 08:12 PM
Posts: 4,649 Motor City
6PKRTSE
Motor City
I just have an SFI bell and I still had to enlarge my tunnel to make it fit.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
Re: 727 sfi case
[Re: Dragula]
#3265418
10/20/24 08:39 PM
10/20/24 08:39 PM
Posts: 6,177 Melbourne , Australia
LA360
Is it me, or does it look like it was built for the diesel world? Its not just you, it seems to be rather obvious I would have thought.
Alan Jones
Re: 727 sfi case
[Re: LA360]
#3265435
10/20/24 09:27 PM
10/20/24 09:27 PM
Posts: 12,486 Taxes & Virus's R-US, NY
Dragula
Is it me, or does it look like it was built for the diesel world? Its not just you, it seems to be rather obvious I would have thought. Pretty sure that's not going to fit a stock tunnel on a race car....
Re: 727 sfi case
[Re: Dragula]
#3265442
10/20/24 09:41 PM
10/20/24 09:41 PM
Posts: 4,152 Mo.
racerx
Mo.
Is it me, or does it look like it was built for the diesel world? If I remember correctly cope did say something about being cast on the 46 series plate form.
Re: 727 sfi case
[Re: dodger mope]
#3265503
10/21/24 11:02 AM
10/21/24 11:02 AM
Posts: 13,516 Marion, South Carolina [><]
an8sec70cuda
Looks like a waste of money. If a drum explosion will still go right through it and the stock case really isn't a weak point...what's the point? I'm sure the diesel guys making a gazillion ft. lbs. of torque can use it, but for most car guys... Having to cut the car up to fit it ruins it for me, but I know I'm in the minority as far as that goes. Before I spent that kind of money on a 727, I'd use a different transmission w/ better options.
CHIP '70 hemicuda, 575" Hemi, 727, Dana 60 '69 road runner, 440-6, 4 speed, Dana 60 '71 Demon 340, no drivetrain, on blocks behind the barn '73 Chrysler New Yorker, 440, 727, 8.75 '90 Chevy 454SS Silverado, 476" BBC, TH400, 14 bolt '06 GMC 2500HD LBZ Duramax
Re: 727 sfi case
[Re: an8sec70cuda]
#3265506
10/21/24 11:13 AM
10/21/24 11:13 AM
Posts: 7,541 Minnesota
Hemi_Joel
Minnesota
Considering the huge opportunities for the aftermarket on the late model stuff, it's nice to see new products hit the market for these dinosaurs that we love.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
Re: 727 sfi case
[Re: DoubleD]
#3265548
10/21/24 12:28 PM
10/21/24 12:28 PM
Posts: 2,139 Byron, NY
W.I.N. Racing
Byron, NY
You would really have to have your heart set on running a 727 to buy one of those cases. I appreciate that there are companies making parts for our beloved MOPARS but a 727 is not the most practical transmission for racing especially at that (projected) cost. In order to be SFI certified it must pass a High gear drum failure and meet certain criteria for object penetration. SFI test requirements It does not specify a (material, mfg or date of mfg) drum so it must pass with any commercially available drum (stock to Billet steel/alum). But if you have to use a case that (looks like it) weighs more than a stock case and then but a shield of some type around it what's the point? As a more robust case for the Big HP/torque diesel guys, looks like a great product. with all the different converter drives out there today there are many bullet proof, non-HP robbing alternative's if you're making the kind of power where case distortion/breaking is one of your issues.
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: 727 sfi case
[Re: DoubleD]
#3265555
10/21/24 12:33 PM
10/21/24 12:33 PM
Dragula
It does really look like a diesel trans, but I think they missed the mark on the design...If they ARE trying to contain the aforementioned drum explosion. They should have built in a steel sleeve or band in there somewhere. I do not think the design they have will do that. If they had sleeved it under all that extra reinforcement, with a steel band, then I think it would send it out the bottom which would be safer than into the drivers compartment.
My car was the victim of an exploding drum on the launch, although I was not the driver that day. The guy that was, was lucky to still have a foot. Broke two bones in his foot, and threw the shifter into the back of the car and pepper the interior like it was shot up with buck shot. I had chunks of the housing in the car, and a bunch of the rollers from the sprag, plus a bunch of the hot fluid. Was a real scary mess.
Re: 727 sfi case
[Re: AndyF]
#3265592
10/21/24 03:06 PM
10/21/24 03:06 PM
Posts: 19,586 Las Vegas
Al_Alguire
Las Vegas
It is a tough sell for the aftermarket. The PG and TH have become so popular that it is hard to compete with them. The 727 doesn't really do anything super special, and they are expensive to build for high powered cars. Gear selection is the reason people choose to run a TF.
Re: 727 sfi case
[Re: Dragula]
#3265779
10/22/24 09:46 AM
10/22/24 09:46 AM
Posts: 75,306 A gulag near you.
JohnRR
A gulag near you.
My car was the victim of an exploding drum on the launch, although I was not the driver that day. The guy that was, was lucky to still have a foot. Broke two bones in his foot, and threw the shifter into the back of the car and pepper the interior like it was shot up with buck shot. I had chunks of the housing in the car, and a bunch of the rollers from the sprag, plus a bunch of the hot fluid. Was a real scary mess. Were you running a stock drum in that trans ? To me for the cost of that case, and having to cut the car up to use it, I would just buy a billet drum, a super sprag, and put a shield or blanket over the trans if It's required , the drum and sprag would be more than enough for the power level of my junk.
Mainstream Media is the new Pravda
Re: 727 sfi case
[Re: JohnRR]
#3265811
10/22/24 12:32 PM
10/22/24 12:32 PM
Dragula
My car was the victim of an exploding drum on the launch, although I was not the driver that day. The guy that was, was lucky to still have a foot. Broke two bones in his foot, and threw the shifter into the back of the car and pepper the interior like it was shot up with buck shot. I had chunks of the housing in the car, and a bunch of the rollers from the sprag, plus a bunch of the hot fluid. Was a real scary mess. Were you running a stock drum in that trans ? To me for the cost of that case, and having to cut the car up to use it, I would just buy a billet drum, a super sprag, and put a shield or blanket over the trans if It's required , the drum and sparg would be more than enough for the power level of my junk. At the time, I do believe the drum was stock with good clutches and a RMVB. The drum in it now is A&A. To give you an idea how bad it was, we didn't find a good portion of the trans, it was just gone.
