Re: ...progress...
[Re: poorboy]
#3260059
09/25/24 05:01 PM
09/25/24 05:01 PM
Posts: 281 Falcon, CO
Mad-Max
Falcon, CO
...thanks, and yah I'll definitely keep going - I've wanted a bigger silly abusable 4-door version of my dad's 52 Willys M-38 for years, and this is it, both in form and primitive function, and to achieve that goal I'm trying really hard to have the custom parts look more like decent fabrication and less like fabricobble...fortunately thick paint helps a lot
71 Demon (project): 318, A-833od, 8-3/4, 3.23's 14 Wrangler JKU M-380 "Kilroy" (under construction): Magnum 360, 46rh, Atlas4, D60/14b-5.38s-Grizzlys, 40s 07 Ram 3500 MegaDually 4x4 "Big Mack": 5.9 6BT, G56 'Toy Hauler' 52 Willys M-38 "Poncho"
Re: '14 JKU M-380 - "Kilroy"
[Re: Mad-Max]
#3261427
10/02/24 12:51 PM
10/02/24 12:51 PM
Mad-Max
Falcon, CO
[Re: Mad-Max]
#3261500
10/02/24 06:30 PM
10/02/24 06:30 PM
Mad-Max
Falcon, CO
[Re: moparx]
#3261703
10/03/24 01:19 PM
10/03/24 01:19 PM
Mad-Max
Falcon, CO
...oh I dunno - maybe 150-200 lbs or so - I still have to bolt up the rock sliders, armored fenders, and corner armor. And yah the playground out back is way more funerer now
[Re: Mad-Max]
#3261739
10/03/24 02:59 PM
10/03/24 02:59 PM
Mad-Max
Falcon, CO
[Re: poorboy]
#3261774
10/03/24 05:38 PM
10/03/24 05:38 PM
Mad-Max
Falcon, CO
yep understand, and that's why I post up my progress - to get second opinions and/or other recommendations, and based on another thread the build is on I ordered the two below fittings - I'll know soon how well it fits on a JK sending unit - https://www.amazon.com/gp/product/B07GB2R77C/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1https://www.amazon.com/gp/product/B09494FV4N/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&th=1
[Re: Mad-Max]
#3262470
10/07/24 12:06 PM
10/07/24 12:06 PM
Mad-Max
Falcon, CO
...so again, one of the main reasons I post up the many steps of what I'm doing is to enable the opportunity for others to provide feedback on better ways to do a thing, a perfect example being this really slick aluminum fuel fitting that replaces (in this case) the OE plastic wrangler gas tank sending unit fitting the gas tank sending unit. A guy on Irate made me aware of these and I already have it installed. This is an aluminum, internal double o-ring fuel fitting which appears to be a specific replacement for the weak OE plastic fittings - Evil Energy 6an - 3/8 fuel fitting - https://www.amazon.com/dp/B07GB2R77C?ref=ppx_yo2ov_dt_b_fed_asin_title&th=1Evil Energy 6an - 5/16 hose fitting - https://www.amazon.com/dp/B09494FV4N?ref=ppx_yo2ov_dt_b_fed_asin_titleAs far as I can tell this fitting attaches to the plastic output tube on my 2014 Wrangler gas tank perfectly - secures nice and tight to the stop lip - and with these upgraded fittings in place the fuel system is 'done'. I did slightly 'scar' the plastic output tube with my exacto knife trying to get the 5/16 rubber hose off (that didn't make me happy) so I had to lightly sand the edge down for the o-ring to seal up clean; I was planning to fill the tank completely to make sure the float and return line seals don't leak, and while I'm at it I'll energize the pump and pressurize the lines and check for leaks.
[Re: moparx]
#3262773
10/08/24 11:55 AM
10/08/24 11:55 AM
Mad-Max
Falcon, CO
I finally got the coils mounted. It took forever because I wanted upper and lower isolators for both the front and rear coils to the axles...but to my continued disbelief I could not find a source for a Wrangler JK/U rear coil spring lower isolator...at least not for the Iron rock coils in my kit that fit flat on the 14b perch. The coils have a 2" i.d. at the base, and I needed a polyurethane bushing that would both fit the 2" hole just a bit tight and have an i.d. that would allow for a decently thick post to center on. After several rounds on Amazon of buy/return I finally found bushings that fit the bill perfectly...in the form of Kenworth motor mounts . Get the mounts, pound out the sleeves, shave off the dome (that rests on the axle perch), cut about 1/2" off the length. Then a friend machined me a set of 1" x 1.5" steel posts with 1/2-13 internal thread, welded the posts to the perches...and the bushings fits my rear coils perfectly - I used a wood rasp on my drill press to make a perfect chamfer to clear the welds - Fits the coil base perfectly - steel alignment posts - After I bolted them in place I noticed the coils have a bit of 'bend' to them - due to the angle I have my 14b at to center the pinion joint - not really awesome, so I'm likely going to modify the coil base to zero out the bend...
[Re: Mad-Max]
#3262774
10/08/24 11:59 AM
10/08/24 11:59 AM
Mad-Max
Falcon, CO
[Re: Mad-Max]
#3264776
10/17/24 03:29 PM
10/17/24 03:29 PM
Mad-Max
Falcon, CO
Built a bracket to angle up the rear coil base mount - works great - squares up the coil nicely - before... ...after - And thanks to a big beefy Artec bracket the rear track bar is in - Front is in work, long with shock mount adjustments...
