Re: flat top or dish pistons
[Re: kingfish#2]
#3264128
10/14/24 07:23 PM
10/14/24 07:23 PM
Posts: 10,618 Rittman Ohio
fourgearsavoy
Rittman Ohio
Depends on the chamber of the cylinder head. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: fourgearsavoy]
#3264133
10/14/24 07:44 PM
10/14/24 07:44 PM
Posts: 9 Ripley, New York
kingfish#2
Ripley, New York
Either a 62 or 65 cc chamber. I can mill the deck, go 63 or 65cc chamber, (not much difference) and a thicker or thinner head gasket. If I can get the same compression of 10.5:1 with either piston, does one make more power?
[Re: rickseeman]
#3264146
10/14/24 08:23 PM
10/14/24 08:23 PM
kingfish#2
Ripley, New York
That's what I thought but before going that route, I wanted to make my best choice but can't find the actual difference. If a few horse no big deal, if 20-30 or more, then I will go with flat tops. Wanted to buy a rotating assembley from cnc motorsports but they do not have my comp. ratio so was wondering if it went with the next best piston choice in a flat top then deck, and gasket accordingly.
[Re: kingfish#2]
#3264151
10/14/24 08:47 PM
10/14/24 08:47 PM
Posts: 5,014 WI
Dcuda69
WI
I did a 470 low deck with Diamond pistons. They did a small dish that mirrored the chamber shape of my Edelbrock heads(instead of a dish across the whole top of the piston) to put my comp ratio at 10.2:1. If I did a flattop I would have had to go to a bigger chamber head....not really sure which would be better but I'm very happy with the combo I chose. Runs great on just about any fuel I put in it.
[Re: rickseeman]
#3264156
10/14/24 09:13 PM
10/14/24 09:13 PM
Posts: 23,360 Here
jcc
Here
I thought everyone wanted a flat top. I believe number one after CR, you want squish, no matter how you get it, is better than none. ,040" being the normal goal?
"When one’s appeal is emotional, it does not matter if there is no substance."
[Re: kingfish#2]
#3264165
10/14/24 10:15 PM
10/14/24 10:15 PM
Posts: 21,320 Eagle, Idaho
Neil
The Doctor is in.
The Doctor is in.
Eagle, Idaho
Play with an online compression ratio calculator if you have not already to see the CR difference between flat tops and dished. My memory is dished is more for the 9:1 or so range, and flat tops with two valve or four reliefs will get you to around 10:1 or a little over depending on gasket thickness. I would not zero deck a block. Better to leave a small amount on top that way the block has some material for future machine work next time it gets rebuilt.
[Re: kingfish#2]
#3264254
10/15/24 12:00 PM
10/15/24 12:00 PM
Posts: 6,043 Salem
Grizzly
Moparts Proctologist
Salem
Either a 62 or 65 cc chamber. I can mill the deck, go 63 or 65cc chamber, (not much difference) and a thicker or thinner head gasket. If I can get the same compression of 10.5:1 with either piston, does one make more power? If your cylinder head has a quench pad, use it. 0.037 to 0.039 is supposedly optimal piston to quench pad clearance. Some of the info gathered over the years points to a dished piston allows a centralized combustion and less power loss to the outside cylinder wall. Makes sense.
Mo' Farts
Moderated by "tbagger".
[Re: kingfish#2]
#3264535
10/16/24 01:57 PM
10/16/24 01:57 PM
Posts: 12,486 Kalispell Mt.
HotRodDave
Kalispell Mt.
A dish piston is almost always a compromise weather it is a mirror of the chamber or not. A flat top is almost always best. I ran a 410 stroker SB with flat tops and iron magnum heads, unshrouded the 2.02 valves to the bore wall to open up the chamber a tiny bit .030 quench, rounded off the sharp edges on the piston to about 1/4 inch radius, and it ran crazy good no detonation on 91 octane and still got good MPG. 220@.050 .575 lift hydro roller.
[Re: kingfish#2]
#3264631
10/16/24 11:12 PM
10/16/24 11:12 PM
Posts: 23,360 Here
jcc
Here
I didn't finish the whole video yet, but my biggest takeaway that I haven't heard before is the need and maximum benefit from having quench on opposite sides, that effectively attacks each other, and those are my words.
