Gen 2 Hemi Intake alternatives?
#3264417
10/16/24 07:37 AM
10/16/24 07:37 AM
Posts: 113 NO
cudaerik
NO
I'm looking for advice to the best inline quad carb intake for my 505 Hemi with the Indy 426-1R legend heads.
The engine will see 7000rpm with a solid roller 263/269 @ .050" Camshaft. I'm planning on using two Edelbrock AVS 2 800cfm carburetors.
The intake alternatives that I'm currently looking at are: Edelbrock Performer RPM Dual quad (#7524). INDY Mod Man intake and the Stage V 2-4BBL manifold (not available at the moment from Tim@FHO)
Please let me know what you guys think.
1970 Plymouth Cuda, 512cid on 230 400 block, 5 speed manual.(TKO 600) 1970 Dodge Charger 500, 446cid, 5speed manual.(TKO 600) 1969 Plymouth Roadrunner, 383cid, 5speed manual (Tremec TKX)
Re: Gen 2 Hemi Intake alternatives?
[Re: cudaerik]
#3264425
10/16/24 08:29 AM
10/16/24 08:29 AM
Posts: 13,516 Marion, South Carolina [><]
an8sec70cuda
I haven't used them, but from what I've seen, the Stage V inline manifold would be my choice.
CHIP '70 hemicuda, 575" Hemi, 727, Dana 60 '69 road runner, 440-6, 4 speed, Dana 60 '71 Demon 340, no drivetrain, on blocks behind the barn '73 Chrysler New Yorker, 440, 727, 8.75 '90 Chevy 454SS Silverado, 476" BBC, TH400, 14 bolt '06 GMC 2500HD LBZ Duramax
[Re: an8sec70cuda]
#3264432
10/16/24 09:20 AM
10/16/24 09:20 AM
Posts: 113 NO
cudaerik
NO
I haven't used them, but from what I've seen, the Stage V inline manifold would be my choice. Unfortunately not available at the moment. Tim@FHO said he was focusing on ramping up the production of Stage V heads before he gets on to the intakes.
[Re: cudaerik]
#3264435
10/16/24 09:35 AM
10/16/24 09:35 AM
Posts: 2,742 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
If you want a Stage V you'll have to find one, I'm sure it will be awhile before he gets around to making those if ever. There is some of the old KB knock offs around on ebay sometimes. The great thing about the Edelbrock is it checks all the boxes. Street Hemi height and spacing for carbs and cold air systems. No other intake does that. EFI ready is available. Fuel rails etc is available. Takes Street Hemi air cleaner. Power, RPM's, fit, chrome dome, shaker hood, air grabber, complete EFI system available, it does it all. Wouldn't take me long to decide.
2011 Drag Pak Challenger
[Re: cudaerik]
#3264444
10/16/24 10:04 AM
10/16/24 10:04 AM
Posts: 18,038 S.E. Michigan
ZIPPY
S.E. Michigan
How soon do you need it?
If "pretty soon" is the answer then I'd probably get the edelbrock, it shows in stock RN.
Rich H.
Esse Quam Videri
[Re: rickseeman]
#3264462
10/16/24 10:46 AM
10/16/24 10:46 AM
Posts: 723 Lake Villa Il
INTMD8
Lake Villa Il
I wouldn't use the indy intake.
I use the Edelbrock but I think the Stage 5 would flow better even just due to runner angle.
For whatever reason the Edelbrock runners are flat and does not match intake port angle. I had to do a lot of porting to try and match it (not so much size but matching angle at the flange)
[Re: cudaerik]
#3264480
10/16/24 11:46 AM
10/16/24 11:46 AM
an8sec70cuda
I haven't used them, but from what I've seen, the Stage V inline manifold would be my choice. Unfortunately not available at the moment. Tim@FHO said he was focusing on ramping up the production of Stage V heads before he gets on to the intakes. They pop up for sale every now and then. Gotta keep an eye out for one. Facebook marketplace.
[Re: an8sec70cuda]
#3264500
10/16/24 12:18 PM
10/16/24 12:18 PM
rickseeman
Stuttgart, Arkansas
The Stage V is a knockoff of the KB Marine intake manifold except in single plane. Mopar also repoped the KB intake. There is one of the Mopar repops on ebay. https://www.ebay.com/itm/156012103598? The seller claims it's an original but I'm sure you can figure that one out. The seller doesn't accept returns if that tells you anything.
[Re: cudaerik]
#3264565
10/16/24 03:43 PM
10/16/24 03:43 PM
Posts: 12,933 Benton, IL.
DaveRS23
Master of nothing...
Benton, IL.
You can decide if this is relevant or not to your situation, but I will relate my intake experience: My Hemi is a 540, similar cam specs to yours with MCH ported Eddy heads. The biggest difference is that I went with a single 4500. I talked to the guys at Indy Cylinder Heads as to which intake would be best for this primarily street driven combo. Coming from wedges, I assumed they would surely recommend a single plane for this engine which peaks at 6,800. But nope, they recommended the dual plane. Being suspicious, I actually bought both and when I broke the engine in on the dyno, I tested both intakes back to back. SURPRISE to me! The dual plane only gave up a dozen ponies or so up top, but picked up 30+ lb ft of torque. Now the 540 really doesn't need much in the way of more torque, but I suspect the driveability is a bit better, too. But I haven't ran the open on the street to prove that. Just my . And it's more money, but you could just pick up the intake that is readily available and have it ported. Surely, that would bring even the second choice intake into competition with the best. At least I think it would.
Master, again and still
[Re: DaveRS23]
#3264575
10/16/24 04:42 PM
10/16/24 04:42 PM
rickseeman
Stuttgart, Arkansas
I'm not really interested in trading but since you want a Stage V and since the theme of my test stand engine is Keith Black, I would swap you for a perfect KB Marine intake. When I asked how many he made he said he really didn't remember, but he thought it was 75. So they are out there. I've had more than one. I put the Stage V intake on my test stand new less than a year ago and it still looks new. You pay all the freight.
[Re: rickseeman]
#3264602
10/16/24 06:58 PM
10/16/24 06:58 PM
Posts: 4,649 Motor City
6PKRTSE
Motor City
I have a couple of each manifold and both perform well with some work and port matching. However, my tunnel ram picked up way more horsepower over any of the other dual four combo's obviously by design.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: cudaerik]
#3264634
10/16/24 11:24 PM
10/16/24 11:24 PM
Posts: 43,838 Bend,OR USA
Cab_Burge
[Re: Cab_Burge]
#3264649
10/17/24 03:49 AM
10/17/24 03:49 AM
Posts: 113 NO
cudaerik
NO
Thanks a lot guys for contribution to my gen II hemi intake quest. based on this information and the availability I'm leaning towards the Edelbrock intake.
[Re: quickd100]
#3264749
10/17/24 02:05 PM
10/17/24 02:05 PM
Posts: 444 montana
BANDIT
montana
I have 2 of the older Wieand tunnel rams for sale, if your interested. Jim.
64 Dodge Coronet 440. In progress 1998. Dodge Avenger. 8.35@165. 4400 DA 1980 Plymouth Arrow 572 Hemi. 242" Mullis Dragster. 6.90@ 200mph
[Re: BANDIT]
#3264852
10/18/24 02:42 AM
10/18/24 02:42 AM
Posts: 113 NO
cudaerik
NO
I have 2 of the older Wieand tunnel rams for sale, if your interested. Jim. I got an older nicely ported Weiand tunnel ram on the engine now but I want to keep everything underneath the hood.
[Re: cudaerik]
#3265015
10/18/24 06:35 PM
10/18/24 06:35 PM
6PKRTSE
Motor City
My Indy tunnel ram does stick through the hood. I just made the scoop to accommodate the tunnel ram.
[Re: 6PKRTSE]
#3265136
10/19/24 12:28 PM
10/19/24 12:28 PM
Posts: 1,750 central il.
second 70
central il.
The Stage V is a little taller than a factory manifold but still fits under the hood on my Cuda The shaker sits up a little higher out of the hood than factory. I have a marine manifolds also. The nice thing is it has the same carb spacing as the stage V so the same shaker base works with either.
[Re: cudaerik]
#3266061
10/23/24 04:02 PM
10/23/24 04:02 PM
Posts: 444 montana
BANDIT
montana
One of the intakes looks just like the one you have, the other, also a Wieand, is roughly an inch shorter.
