Page 3 of 3 1 2 3
Re: Time to rewire my racecar? Show me what you have? [Re: Cab_Burge] #3265193
10/19/24 03:58 PM
10/19/24 03:58 PM
moparx Offline
moparx  Offline
for whatever it's worth, i have started to use marine grade heat shrink with the glue inside for all my wiring chores over the last couple of years.
i think it's just a little more protection from whatever moisture may find it's way in and around any terminal connections.
is it really necessary ? who knows ? shruggy
but it makes me feel a little better......... i guess.............
beer
Re: Time to rewire my racecar? Show me what you have? [Re: Cab_Burge] #3265272
10/20/24 02:35 AM
10/20/24 02:35 AM
gregsdart Offline OP
Originally Posted by Cab_Burge
Originally Posted by gregsdart
Last one
YAAH eek work
looks like a snakes din to me whiney whistling
Twenty eight years and some add ons will create issues, also i recently had to track down a dead short in the starter circuit, and the whole harness got opened up to figure it out. Turned out to be a braided steel presure line got too close to the engine compartment starter switch.
8.582, 160.18 mph best, 2905 lbs 549, indy 572-13, alky
Re: Time to rewire my racecar? Show me what you have? [Re: cl440] #3265298
10/20/24 09:53 AM
10/20/24 09:53 AM
PA
moparacer Offline
moparacer  Offline
PA
Originally Posted by cl440
I dont have any pics but the ARC 8000 kit was very easy to install and is a very neat and clean set up. I have had the same unit in 2 different cars and it has been rock solid reliable. I wouldn't hesitate to buy another if needed.
I love my ARC 8000. Been in the car for 15 years.
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 5.44-126
414 cid SB Dragster 7.65-174
Re: Time to rewire my racecar? Show me what you have? [Re: moparacer] #3265789
10/22/24 09:49 AM
10/22/24 09:49 AM
Ordered the top of the line K&R delay box last night . At a total of $1220 so far this is costing more than i figured in,,,,,,
Question, what are you guys mounting tour fuse panels on?
Re: Time to rewire my racecar? Show me what you have? [Re: gregsdart] #3273783
12/02/24 11:53 PM
12/02/24 11:53 PM
Pictures of the new switch/delaybox panel and fuse panel locations. Used Lexan for rhe fuse panel, some circuits will be fused on a seperate block ,like the drivers fan, so it is independant of the K&R fuse block. Haven't started to route the wires yet, but have all tagged with destination. Next, bundle them up, do my best to make it look neat.
Page 3 of 3 1 2 3
