Re: Time to rewire my racecar? Show me what you have?
[Re: cl440]
#3264727
10/17/24 12:10 PM
10/17/24 12:10 PM
Posts: 19,586 Las Vegas
Al_Alguire
Las Vegas
FWIW we have been grounded EVERYTHING to the battery(floating)for a few years and will never go back to chassis grounds again.
I have used K&R panels many times. It is a good budget option.
[Re: Al_Alguire]
#3264735
10/17/24 12:32 PM
10/17/24 12:32 PM
Posts: 10,141 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Al, not fully understanding your comment on grounding. I definately want to get that right. My battery is in front of the radiater. So my guess is, with less distance to all componants, that may work better than a rear mount battery? Still, i want to go direct, and i want to understand how to avoid problems with poor grounds.
8.582, 160.18 mph best, 2905 lbs 549, indy 572-13, alky
[Re: gregsdart]
#3264745
10/17/24 01:56 PM
10/17/24 01:56 PM
Posts: 3,004 A shed in England
Tig
A shed in England
I did the same as Al and ran an open "Horseshoe" of 8mm square ground cables, from the trunk mounted batteries to 5 ground "Bars" in the car. One in the trunk, two under the dash (L&R) and 2 up front near the headlights, again left and right hand side. Each bar has about 10 connection points. I also run a filter capacitor on the data logger supply AND the MSD Grid supply. Doing this ensures an equal ground for everything (within reason) without the potential ( see what I did there ) for the voltage to differ between sub systems. Sure it's heavier and uses more wire but it reduces the risk of any that issues that can be caused caused by the above, especially on Data loggers and ign systems. Heads have an earth cable to the block and another thing I did was run a separate earth cable for the starter (welding cable), that made a noticeable difference. The batteries are still earthed to the chassis as well but the chassis isn't used as the ground for any circuit. HTH's
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: cl440]
#3264761
10/17/24 02:41 PM
10/17/24 02:41 PM
Posts: 6,409 Heaven
EvilB1Dart
Heaven
I dont have any pics but the ARC 8000 kit was very easy to install and is a very neat and clean set up. I have had the same unit in 2 different cars and it has been rock solid reliable. I wouldn't hesitate to buy another if needed. Same kit I purchased for my son’s Coupe. Nice piece and heard good things about the touch control system.
"Any fool can know. The point is to understand"
- A. Einstein
[Re: gregsdart]
#3264780
10/17/24 04:26 PM
10/17/24 04:26 PM
Al_Alguire
Las Vegas
Al, not fully understanding your comment on grounding. I definately want to get that right. My battery is in front of the radiater. So my guess is, with less distance to all componants, that may work better than a rear mount battery? Still, i want to go direct, and i want to understand how to avoid problems with poor grounds. Everyhting in the car ground directly to the battery. Mostly through bulkhead connectors or distribution blocks that go directly to the battery. Every component is grounded that way. No cables on heads, no cable on starter. Just every wire for every relay or switch in the car is grounded directly the battery. The igniton and racepak stuff is as well both receive direct battery voltage and grounds from the battery. Rahter than relying on the chassis engine etc. You wont see near the voltage drop this way.
[Re: EvilB1Dart]
#3264787
10/17/24 05:37 PM
10/17/24 05:37 PM
Posts: 1,127 Massillon, Ohio
cudatom
Massillon, Ohio
I dont have any pics but the ARC 8000 kit was very easy to install and is a very neat and clean set up. I have had the same unit in 2 different cars and it has been rock solid reliable. I wouldn't hesitate to buy another if needed. Same kit I purchased for my son’s Coupe. Might be selling it and going back to their old school switch panel. Been trying to sell the old one cheap and no takers. Might as well use it. I ranan arc panel for about 20yrs. I really liked there kit. It just didn't have what I wanted this time around.
Ok
[Re: cudatom]
#3264790
10/17/24 06:10 PM
10/17/24 06:10 PM
Posts: 6,177 Melbourne , Australia
LA360
A friend recommended the Leash Electronics ( https://www.leashelectronics.com/) stuff to me to do my own car, it's something I'll be looking at in the new year. I'm just posting so I can follow along, electricity is witchcraft as far as I'm concerned :-D
Alan Jones
[Re: Al_Alguire]
#3264860
10/18/24 07:36 AM
10/18/24 07:36 AM
Posts: 209 Connellsville
71Demon528
Connellsville
I have used K&R panels many times. It is a good budget option. Agree with the floating ground.
[Re: 71Demon528]
#3264868
10/18/24 08:26 AM
10/18/24 08:26 AM
gregsdart
Well, i am commited. Just ordered a K&R kit and six fused relays. Grounding wire will be fine braided welding cable and terminals by the battery and in the footwell area of rhe passenger side. The only ground i will leave on the chassis is for the primer plus pump, which is not critical. I am thinking a dialectric Loctite of some sort might be a good idea ? Thanks Doug (DVW) for the excellent photos and info, and thanks to all that have contributed. Now the fun begins. I will take pictures of my current mess and will be looking for sugestions of where to put switch panel and fuse block, etc
[Re: gregsdart]
#3264869
10/18/24 08:31 AM
10/18/24 08:31 AM
Posts: 694 COLUMBUS, OH
Whompin_Wedge
COLUMBUS, OH
Well, i am commited. Just ordered a K&R kit and six fused relays. Grounding wire will be fine braided welding cable and terminals by the battery and in the footwell area of rhe passenger side. The only ground i will leave on the chassis is for the primer plus pump, which is not critical. I am thinking a dialectric Loctite of some sort might be a good idea ? Thanks Doug (DVW) for the excellent photos and info, and thanks to all that have contributed. Now the fun begins. I will take pictures of my current mess and will be looking for sugestions of where to put switch panel and fuse block, etc Greg, I run the K&R stuff in both of my cars. Love it. Super simple to install. Thanks, Casey FJ
[Re: gregsdart]
#3264912
10/18/24 11:54 AM
10/18/24 11:54 AM
Posts: 20,419 north of coder
moparx
AHHHHHHHHHHHHHH !!!!!!!!!!!!!!!!!!!! not as bad as some i have seen and straightened out. it will be work for sure, but just take your time, use quality crimping tools, and you will be pleased and proud of what you will accomplish. if you don't own quality crimping tools, you should buy or borrow some before you start.
[Re: gregsdart]
#3264940
10/18/24 01:06 PM
10/18/24 01:06 PM
Posts: 7,541 Minnesota
Hemi_Joel
Minnesota
I feel your pain.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: Hemi_Joel]
#3265014
10/18/24 06:27 PM
10/18/24 06:27 PM
Posts: 4,649 Motor City
6PKRTSE
Motor City
,I guess I like everything tiddy.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
