Page 2 of 3 1 2 3
Re: Clearance oil pickup 4.5 stroke Hemi [Re: 6PKRTSE] #3263365
10/11/24 08:28 AM
10/11/24 08:28 AM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
Not many options here, i understand, but once i dent the tube, i lose the benefit of the 1/2" tube.
Re: Clearance oil pickup 4.5 stroke Hemi [Re: mopar dave] #3263369
10/11/24 08:46 AM
10/11/24 08:46 AM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
.060 is recommended but .020-.030 is fine.
Re: Clearance oil pickup 4.5 stroke Hemi [Re: mopar dave] #3263370
10/11/24 08:47 AM
10/11/24 08:47 AM
fredericksburg,va
cudaman1969 Offline
Itch Nutz
cudaman1969  Offline
Itch Nutz
fredericksburg,va
Don’t just dent the pipe, make oval shape, a press or vice will work, heat to cherry red then squeeze it. An oval or squareish pipe will flow same as a round one
Re: Clearance oil pickup 4.5 stroke Hemi [Re: cudaman1969] #3263371
10/11/24 08:49 AM
10/11/24 08:49 AM
Mt Morris Michigan
Mt Morris Michigan
Yes, was just thinking that. Like oval exhaust same area.
Re: Clearance oil pickup 4.5 stroke Hemi [Re: cudaman1969] #3263400
10/11/24 10:34 AM
10/11/24 10:34 AM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
Come to think of it. That is what I did was oval the tube in a bench vise while cherry red. I didn't just ding the tube.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Clearance oil pickup 4.5 stroke Hemi [Re: 6PKRTSE] #3263416
10/11/24 11:07 AM
10/11/24 11:07 AM
NC
440Jim Offline
440Jim  Offline
NC
Here is an idea to modify the factory Bill Mitchell part, so you can move it a little.
Use locktite on the bolt threads, and a touch of some sealant (not RTV) on the flat part after milling off the round part sticking out (into the block).
I might even be able to mill an O-ring recess after milling off that part, so sealant would not be needed.
Re: Clearance oil pickup 4.5 stroke Hemi [Re: 440Jim] #3263420
10/11/24 11:27 AM
10/11/24 11:27 AM
Mt Morris Michigan
Mt Morris Michigan
instead of milling that completely off, i could shave a little off one side and drill the holes bigger. I will have to contour the inside a bit for even flow. That might get me enough, if not, a little squeeze in the vise should do it. Thats.
Re: Clearance oil pickup 4.5 stroke Hemi [Re: an8sec70cuda] #3263428
10/11/24 12:03 PM
10/11/24 12:03 PM
central il.
second 70 Offline
second 70  Offline
central il.
Originally Posted by an8sec70cuda
I'd be concerned about the tube cracking. twocents
I agree don't grind it. Mine cracked after a few years in stock stroke and condition.
Re: Clearance oil pickup 4.5 stroke Hemi [Re: second 70] #3263433
10/11/24 12:19 PM
10/11/24 12:19 PM
Mt Morris Michigan
Mt Morris Michigan
No kidding, it cracked on the thread? That is the thicker part of the tube.
Re: Clearance oil pickup 4.5 stroke Hemi [Re: mopar dave] #3263448
10/11/24 01:59 PM
10/11/24 01:59 PM
NC
440Jim Offline
440Jim  Offline
NC
Finished. I will mail this today (Fri). Give it a try.
Re: Clearance oil pickup 4.5 stroke Hemi [Re: 440Jim] #3263450
10/11/24 02:15 PM
10/11/24 02:15 PM
BDW Offline
BDW  Offline
Any worries about it "sliding" over, now that there's nothing to register it?
Re: Clearance oil pickup 4.5 stroke Hemi [Re: 440Jim] #3263538
10/12/24 12:03 AM
10/12/24 12:03 AM
Mt Morris Michigan
Mt Morris Michigan
Thanks Jim, i will certainly give that a try. I think Indian Head gasket shellac would seal and hold that a long time.
Re: Clearance oil pickup 4.5 stroke Hemi [Re: mopar dave] #3263539
10/12/24 12:26 AM
10/12/24 12:26 AM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
hi,
you are over thinking it if you dimple the tube .060" there should be plenty of oil still .
i have 1 449 that the owner has ran with a stock street hemi oil pan 3/8 tube for 7 years without any refrish of engine .
verry consistant 10,40 1/4 mile .
my hemi runs 60 /65 psi hot 10/30 valaoline .
Re: Clearance oil pickup 4.5 stroke Hemi [Re: calrobb2000] #3263601
10/12/24 08:29 AM
10/12/24 08:29 AM
Mt Morris Michigan
Mt Morris Michigan
New adaptor on the way by 440Jim. No dimpling required.
Re: Clearance oil pickup 4.5 stroke Hemi [Re: mopar dave] #3263645
10/12/24 01:14 PM
10/12/24 01:14 PM
central il.
second 70 Offline
second 70  Offline
central il.
Yes
Re: Clearance oil pickup 4.5 stroke Hemi [Re: second 70] #3263813
10/13/24 08:45 AM
10/13/24 08:45 AM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
They crack like that from not enough thread engagement . The pipe thread used is tapered when you just grab 3-4 threads your sill on the part of the tube that is on the minor dia of the thread die, so its cut deeper into the tube, you need to open up the thread in the block with a tap to get more thread engagement.
Re: Clearance oil pickup 4.5 stroke Hemi [Re: B1MAXX] #3263821
10/13/24 11:01 AM
10/13/24 11:01 AM
Mt Morris Michigan
Mt Morris Michigan
Thanks for that a will do. Mine was only getting 4 threads.
Re: Clearance oil pickup 4.5 stroke Hemi [Re: mopar dave] #3263880
10/13/24 04:46 PM
10/13/24 04:46 PM
Sydney,Australia
tex013 Online content
tex013  Online Content
Sydney,Australia
with my Milodon pickup I actually used a taper die to recut the thread as it wouldnt go more than about 1 1/2 turns . Once recut went in a lot further . Did this on 2 different road race pan pickups . One went into my World block one into a stock block .
Almost seemed like it was cut parrallel thread .
Tex
New best ET 10.259@129.65 .
New best MPH 130.94
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: Clearance oil pickup 4.5 stroke Hemi [Re: tex013] #3263882
10/13/24 05:33 PM
10/13/24 05:33 PM
Mt Morris Michigan
Mt Morris Michigan
Will recut that adaptor when i get it.
Re: Clearance oil pickup 4.5 stroke Hemi [Re: an8sec70cuda] #3263888
10/13/24 06:15 PM
10/13/24 06:15 PM
Plymouth, MI
Blusmbl Offline
Blusmbl  Offline
Plymouth, MI
x2. I'd have no problems denting one but I wouldn't want to grind it in an area where it has the potential to crack. That's a lot of leverage from the end of the pickup to the threads for it to crack over time due to vibration.
Page 2 of 3 1 2 3
