Page 23 of 74 1 2 21 22 23 24 25 73 74
Re 1970 440-6 engine complete [Re: HemidaveZ] #3284
04/06/09 11:48 AM
04/06/09 11:48 AM
HemidaveZ Offline
HemidaveZ  Offline
I have a 440-6 engine OB228453 Let me know if the numbers on this engine are yours. davezeiser@yahoo.com
Re: 1971 340 [Re: HemidaveZ] #3285
04/06/09 11:52 AM
04/06/09 11:52 AM
HemidaveZ Offline
HemidaveZ  Offline
I have a 1971 340 IB328641. Let me know if these numbers are for your car. davezeiser@yahoo.com
1969 E 440 HP2 [Re: HemidaveZ] #3286
04/06/09 01:02 PM
04/06/09 01:02 PM
State of Corruption
camdog440 Offline
camdog440  Offline
State of Corruption
This is my spare block...
1969 E 440 HP2
cast 1/18/1969
9G233296
Re: 1969 E 440 HP2 [Re: camdog440] #3287
04/07/09 11:53 AM
04/07/09 11:53 AM
Olympia, Washington
tallzag Offline
tallzag  Offline
Olympia, Washington
Found - 18 Spline 4 Speed - 8G270071
Tom Hergert
Rocket Restorations
Rocket Restorations
Re: Engine and Trans Lost & Found #3288
04/11/09 12:53 PM
04/11/09 12:53 PM
Maryland, USA,
satgtx Offline
satgtx  Offline
Maryland, USA,
i have the engine & trans from this car #'s match WP27H9G134828. i heard the car was destroyed but you never know. In the MD area around 20 years ago. 383 4 speed 69 coronet 500 converible
69 GTX engine & 18 spline trans [Re: satgtx] #3289
04/11/09 01:53 PM
04/11/09 01:53 PM
Maryland, USA,
satgtx Offline
satgtx  Offline
Maryland, USA,
looking for 69 GTX 440 and 18 spline trans LA142656. The trans was stolen by Donald Anthony Barnes in 1999 and supposedly purchased by someone to put in a 69 coronet or super bee to sell.
Re: Engine and Trans Lost & Found [Re: 3_RTs] #3290
04/18/09 07:53 PM
04/18/09 07:53 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
I have a bare 727 big block case. Pan #2801541 and the # on the bellhousing is 8B 264725.
This is a 67 440 HP or early 68 383/440 HP case.
I'm into small blocks so I don't have much use for it. I would prefer that it find it's way back to the original car or at least a correct car.
Re: Engine and Trans Lost & Found [Re: Neil] #3291
04/24/09 07:39 PM
04/24/09 07:39 PM
Found: 1969 383 HP
9B27900 Stamped December of 1968.
Re: Engine and Trans Lost & Found #3292
04/27/09 06:45 AM
04/27/09 06:45 AM
sw pa
AirGrabber1 Offline
AirGrabber1  Offline
sw pa
I'll repost this again. Maybee someone knows this person.
***FOUND***XS29L9B251529***4SPD*** I have this trans and someone from canada that posted in the b body l/f build sheet section in april 04 owns the car, and no longer has a username. I got no reply back from the email link in his/her post. I figured I would give him/her one last try before it gets put back to its intended purpose
Re: Engine and Trans Lost & Found [Re: AirGrabber1] #3293
04/27/09 08:59 PM
04/27/09 08:59 PM
NY
70440+6bbl Offline
70440+6bbl  Offline
NY
Looking for '71 440 HP block 1G161385
From my '71 GTX U-code 4-spd that spent most, if not all of it's life in the northern VA/Wash DC area.
Also, still looking for '70 440 HP block for 0B179158. From '70 V-code 'Cuda FK5 burnt orange 4-spd gator top car out of the Buffalo, NY area
Looking for Hemi 4-Speed [Re: Alaskan_TA] #3294
05/01/09 01:07 AM
05/01/09 01:07 AM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
Looking for Hemi 4 speed 0B146642.
Please PM
Looking for Hemi Block [Re: Snoopy] #3295
05/01/09 01:10 AM
05/01/09 01:10 AM
Snoopy Offline
Snoopy  Offline
Looking for Hemi Block 0B146642.
Please PM
1970 440 HP2 block found [Re: Snoopy] #3296
05/05/09 10:10 PM
05/05/09 10:10 PM
tennessee,usa
mattsmopars Offline
mattsmopars  Offline
tennessee,usa
FOUND: I have a 70 440 HP2 block that i would like to see get between the fenders of its original car. The last of the VIN is OA168296.
If you have this car contact me at mattsmopars@frontiernet.net or PM me on this board.
Matt
1970 GTX [Re: mattsmopars] #3297
05/10/09 04:15 PM
05/10/09 04:15 PM
Lac Du Bonnet, Manitoba
lo234me Offline
lo234me  Offline
Hello looking for motor, tranny, fender tag, and broadcast sheet for my 1970 GTX, vin RS23U0E116681. Let me know if you have any info on this car??
lo
Please I'm me.
Re: Engine and Trans Lost & Found [Re: Alaskan_TA] #3298
05/11/09 10:32 PM
05/11/09 10:32 PM
USA
big-block-dave Offline
USA
Hi, looking for lost '69 440 HP motor and auto trans 9B272278 Car was new in Washington then to WIS, MN, ILL areas. Thanks, Dave
I'm the CARETAKER of Weinstats '69 440 'cuda registry and have 104 of the 360 cars to date. 84 fastbacks/20 coupes. Always looking for new(REAL M-code) '69 440 'cudas to add to the registry so drop me a note if any are found or known. This isn't a publicly released registry. Thanks, Dave
Engine and Trans Lost & Found [Re: big-block-dave] #3299
05/19/09 10:16 PM
05/19/09 10:16 PM
California
darkrider2 Offline
darkrider2  Offline
California
Found a 1970 383 HP Block, E.I.N is NOE121111, so 383 4 barrel, 1970,Los Angeles CA, 121111'th built. Just thermal cleaned the block and it looks like it is barely broken in.
Re: Engine and Trans Lost & Found [Re: darkrider2] #3300
05/20/09 01:21 PM
05/20/09 01:21 PM
CENTRAL MINN
1965_PLYMOUTH Offline
CENTRAL MINN
still desperately seeking a 440HP motor from the old 69 charger R/T 4 speed. L9G112792. the car was purchased around the Maple Lake, Minnesota area in 1979 with the incorrect motor then already. thank's for the ad Moparts.
Re: Engine and Trans Lost & Found [Re: 1965_PLYMOUTH] #3301
05/20/09 07:28 PM
05/20/09 07:28 PM
Deland, Florida
biff426 Offline
biff426  Offline
Deland, Florida
I have a 70 440 7/23/69 vin 0B15948 let me know if you have the car dwmotorsports@comcast.net
71 340 engine block [Re: biff426] #3302
05/23/09 03:10 PM
05/23/09 03:10 PM
oberlin, Ohio
Rapid340 Offline
Rapid340  Offline
oberlin, Ohio
Let me know if this is for your car.
340
Cast 1/18/71
serial number 438614
jeffpatterson@copper.net
1971 Factory Appearing Duster 340 11.000 @ 122 mph
70 340 Block [Re: Rapid340] #3303
05/23/09 03:11 PM
05/23/09 03:11 PM
oberlin, Ohio
Rapid340 Offline
Rapid340  Offline
oberlin, Ohio
70 340
Cast 5/27/69
serial number 415653
