Page 1 of 3 1 2 3
For Sale/ Wanted - Big Block Engine - 4th Quarter #3260990
09/30/24 05:37 PM
09/30/24 05:37 PM
Norwich CT USA
moparts Offline OP
moparts  Offline OP
Norwich CT USA
Holley 12-846 HP Billet Fuel Pressure Regulator "NEW" [Re: moparts] #3261024
09/30/24 06:52 PM
09/30/24 06:52 PM
Northwest Indiana
19Coronet66 Offline
19Coronet66  Offline
Northwest Indiana
For sale is a "NEW" in the box Holley HP Billet adjustable fuel pressure regulator. Part number 12-846. EFI applications. Bypass style. Adjustable from 15-65 PSI. -8AN o-ring inlet. -8 o-ring outlet. -6AN o-ring return. $160 shipped in the 48 states. PM if interested.
https://www.jegs.com/i/Holley/510/12-846/10002/-1
Re: For Sale/ Wanted - Big Block Engine - 4th Quarter [Re: moparts] #3261071
09/30/24 08:42 PM
09/30/24 08:42 PM
Greensburg, Pa
Mpetros Offline
Mpetros  Offline
Greensburg, Pa
Wanted 572 or bigger B-1 Engine.
724-433-0527
Re: For Sale/ Wanted - Big Block Engine - 4th Quarter [Re: moparts] #3261140
10/01/24 06:39 AM
10/01/24 06:39 AM
Detroit area
6PAX Offline
6PAX  Offline
Detroit area
70 B-body voltage regulator mounting bracket. $15
New chrome coil cover & coil mounting bracket. $20
New factory type big block spark plug wire separator kit. Some surface rust from humidity on a couple of them. $50
NOS big block heat riser kit #3420046. $225
NOS Cal Custom chrome radiator cap. $20
NOS Cal Custom chrome battery hold down. $25
Four new extra wide chrome valve cover hold down clamps. $10 for the set
NOS Cal Custom polished big block valve covers. $450
New exhaust manifold heat stove to air cleaner hose. $20
NOS fan clutch 3769614 for 1974 all V-8 engines. $100
New big block chrome valley pan hold down rails & bolts. $30
Gauge type oil pressure sending unit. $20
Vintage Cal Custom 14" finned aluminum air cleaner with filter. $100
New Mopar Performance chrome big block distributor hold down. $20
New 12" long oval 4 barrel aluminum air cleaner with filter. It measures 12" L x 8 1/4" W x 3" H and has a 5 1/8" carb opening. $55
New Mopar Performance chrome water neck. Was bolted on an engine but then taken back off before the engine was ran. $10
NOS Direct Connection big block double roller timing chain #P4120264. $75
New Mr. Gasket chrome oil filter cover. $15
MP big block high volume oil pump P4286590. This was new when I tried it on my motor but it was too much pressure so I switched to a stock pump. $80
9 Chrome t-handle valve cover bolts. $10
Factory starter, part/casting #3755259. This came off of my Dart about 10 years ago. Worked fine then, been sitting on a shelf ever since. $40
NOS Cal Custom chrome dagger dipstick handle. $25
Mopar Performance 5 blade radiator fan and clutch. $100
1972 400 spark plug shields $10 pair
Factory warning light type oil pressure sending unit. $10
Chrome big block timing tab. $5
Chrome single groove alternator pulley. $15
New Mopar Performance big block 8 qt. oil pan with new pick-up. $200
1971 Charger big block throttle cable. $40
New AR Engineering big block lightweight alternator kit with 60 amp Denso alternator. I mounted this on my engine on the stand but ended up using a factory alternator. $175
Original 2 piece heat stove from 1970 440 exhaust manifold. Good condition. $125
1975 Date coded alternator. Part #3874271. $25
Pioneer Automotive cylinder head dowel pins. 21 pieces 1/4" x 5/8". $10
1967 4bbl intake manifold part# 2806178. Sandblasted and primed. $100
Rev-n-nator Coil and programmable ICU. $200
Vintage Cal Custom scoop style air cleaner. Very nice condition. Includes often missing matching wingnut. $300
New in boxes QTP 2 1/2" electric exhaust cutouts #QTEC50, stainless y-pipes #10250 and remote controller #10900. $654 total price at Summit. $500
Prices do not include shipping. No Paypal
gt340 @ yahoo.com
Sold [Re: 6PAX] #3261365
10/01/24 10:44 PM
10/01/24 10:44 PM
Baton Rouge, LA
SethJof Offline
SethJof  Offline
Baton Rouge, LA
Sold
440 Six Pack Center Carb 4144-1 - reconditioned [Re: Mpetros] #3262328
10/06/24 02:43 PM
10/06/24 02:43 PM
CT
Rocket Offline
Rocket  Offline
CT
I have a 440 six pack center carb part # 4144-1 that was factory reconditioned by Holley. Has not been run since reconditioned.
$750 shipped in the lower 48 states. I will ship internationally for the added cost.
Email me at procketrichard@hotmail.com for more pictures or any questions.
Re: 440 Six Pack Center Carb 4144-1 - reconditioned [Re: Rocket] #3262820
10/08/24 01:51 PM
10/08/24 01:51 PM
motor city
sixty9redgtx Offline
motor city
1963 Maxie rods set of five (5) for 413, 426 maxwedge ramcharger.
P/n 2406395 stamped on each one.
Ms3049 also stamped on each one.
Been wrapped in newspaper from June 69'.
Look in excellent condition, most likely never ran.
Any questions, just ask. Thanks
$375.00 + shipping
Clearing out parts that I collected over the years [Re: moparts] #3263754
10/12/24 10:29 PM
10/12/24 10:29 PM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
Google Drive Picture Link
ARE281 50.00
ARE224 350.00
Cloyes Quick Adjust Timing Chain Set NS1, 150.00
Comp Cams 614-16 valvbe locks for 11/32 valves +.050" height 30.00
99378-16 Crane Cams - Hi Intensity Hydraulic Lifters 100.00
Summit oil pan gasket 30.00
90425 exhaust gaskets 10.00
REM Sun visors 66-68 A and B bodies 120.00
Hood Insert gaskets, 10.00
Superformance M1 tunnel Ram gaskets 25.00 or buy the B engine manifold to go with them for 500
Proform spring tester 100.00
KEM fuel pump 25.00 NOS
Superformance timing chain gasket kit 40.00
New HD Ford trans cooler 20.00
727 Dipstick tube 10.00
440 Source crank pully spacers both for 25.00
Comp Cams Tool Steel retainers 200.00
Comp Cams 929-16 valve springs 180.00
Comp Cams 23-228-4 Hot Street hyd cam 240.00
Crane H-302 cam, never ran, just put in block 232-242 .504/.528 112 CL 150.00
Lunati Street solid roller 40230733 looks like Lunati is going the way of the dodo
"Excellent cam for street/strip applications. Has good mid range and excellent upper RPM, torque and HP. Needs 3500 RPM stall converter or 4/5 speed transmission, headers, 10.5:1+ compression ratio and 4.56 gearing. Rough idle.
3000 7000 RPM Operating Range
249/255 Duration at .050". 110 Degree Lobe Separation Angle
0.585"/0.600" Valve Lift Made in USA" 500.00
Comp Cams solid Roller 23-741-9 243/243 .550/.550 110 CL 450.00
Shumacher Torque Strap 125.00
Dynamic 9-1/2" converter, bought after refresh, no miles since 700.00
Doctor Diff rotors, no miles 150.00 per pair.
Eldebrock Torker bbm, B engine 150.00 No machining, stripped holes
Weiand B engine tunnel rams, 500 each No machining, stripped holes
Torker 340 125.00 No machining, stripped holes
Offy RB tunnel ram, with the "turbo-thrust IR adapters" 350.00 No machining, stripped holes
73-76 glass front bumper 50.00
Repro MP A body front and rear spoilers, rear needs minor repair 200.00 for both Fits Duster and Dart Sport
Firm Feel Stage 2 steering box, pump hoses and I'll throw in the PB bellcrank, 300.00
Carter Strip kits x 2 with the book, everything in there is labeled, take it all for 100.00
One set of Comp solid roller lifters no pushrod oiling, no offset- roll smooth no scuffing 250.00
One set of Comp soild roller lifters with pushrod oiling and offset roll smooth, no scuffing 300.00
MP .920 a body tortion bars, 150.00
Addco sway bars 1" front, 3/4" rear for A body, front bar is for the spool mount '73-'76 K member, 100.00
Edlebrock AIC shock front and rear 40.00 were on my 68 Cuda, should fit all 67-up A bodies.
I'll listen to offers, but this isn't a fire sale, and most of this stuff is new, in box.
Shipping is not included, will be actual cost. Cash, US Postal M.O. PayPal is accepted, Friends and Family ONLY. US Dollars.
I'll have all this and more at the CPW Fall fling on Oct 19. Contact me by PM, Thanks for the AD Tom!
Big Block Throttle Cable Bracket [Re: moparts] #3263764
10/13/24 01:50 AM
10/13/24 01:50 AM
Fenton, MI
Memongo Offline
Parts peddler
Memongo  Offline
Parts peddler
Fenton, MI
Big Block Throttle Cable Bracket. Used, $30 + Shipping. Payment via US Postal Money Order Only! Shipping: US Address Only!
Call Steve 810-629-1097
383-400 Big Block A/C Brackets [Re: Memongo] #3263765
10/13/24 01:51 AM
10/13/24 01:51 AM
Fenton, MI
Memongo Offline
Parts peddler
Memongo  Offline
Parts peddler
Fenton, MI
383-400 Big Block A/C Brackets, Used, $75 + Shipping. Payment via US Postal Money Order. Shipping: US Address Only!
Big Block Distributor Hold Down Bracket [Re: Memongo] #3263766
10/13/24 01:53 AM
10/13/24 01:53 AM
Fenton, MI
Memongo Offline
Parts peddler
Memongo  Offline
Parts peddler
Fenton, MI
Big Block Distributor Hold Down Bracket. Used, $20 + Shipping. Payment via US Postal Money Order. Shipping: US Address Only!
Big Block Spark Plug Wire Brackets [Re: Memongo] #3263767
10/13/24 01:56 AM
10/13/24 01:56 AM
Fenton, MI
Memongo Offline
Parts peddler
Memongo  Offline
Parts peddler
Fenton, MI
Big Block Spark Plug Wire Brackets. Used, Payment via US Postal Money Order Only!. Shipping: US Address Only!
Photo 1. $10 + Shipping
Photo 2. $20 + Shipping
Photo 3. $10 + Shipping
Wire Loom Brackets 1.jpg (1206 downloads)
Wire Loom Brackets 2.jpg (1204 downloads)
Wire Loom Brackets 3.jpg (1205 downloads)
Big Block Timing Chain Cover [Re: Memongo] #3263768
10/13/24 01:57 AM
10/13/24 01:57 AM
Fenton, MI
Memongo Offline
Parts peddler
Memongo  Offline
Parts peddler
Fenton, MI
Big Block Timing Chain Cover. Used, $35 + Shipping. Payment via US Postal Money Order Only!. Shipping: US Address Only!
Big Block Water Pump With Water Pump Housing [Re: Memongo] #3263769
10/13/24 01:58 AM
10/13/24 01:58 AM
Fenton, MI
Memongo Offline
Parts peddler
Memongo  Offline
Parts peddler
Fenton, MI
Big Block Water Pump With Water Pump Housing. Used, $100 + Shipping. Payment via US Postal Money Order Only!. Shipping: US Address Only!
Note: Came off a 1970 383 motor
Water Pump with Housing.jpg (1205 downloads)
Holley 4749 Carburetor Factory 383-440 [Re: Memongo] #3263770
10/13/24 01:59 AM
10/13/24 01:59 AM
Fenton, MI
Memongo Offline
Parts peddler
Memongo  Offline
Parts peddler
Fenton, MI
Holley 4749 Carburetor Factory 383-440. Used, $125 + Shipping. Payment via US Postal Money Order. Shipping: US Address Only!
Note: Came off a 70 383 Challenger
Factory Valve Cover Breather [Re: Memongo] #3263771
10/13/24 02:01 AM
10/13/24 02:01 AM
Fenton, MI
Memongo Offline
Parts peddler
Memongo  Offline
Parts peddler
Fenton, MI
Factory Valve Cover Breather. Used, $15 + Shipping. Payment via US Postal Money Order Only! Shipping: US Address Only!
Small Block Breather 1.jpg (1198 downloads)
Small Block Breather 2.jpg (1201 downloads)
Valve Cover Oil Fill Caps [Re: Memongo] #3263772
10/13/24 02:04 AM
10/13/24 02:04 AM
Fenton, MI
Memongo Offline
Parts peddler
Memongo  Offline
Parts peddler
Fenton, MI
Valve Cover Oil Fill Caps. Used, $10 Each + Shipping. Payment via US Postal Money Order Only! Shipping: US Address Only!
1. Not sure!
2. 73-74 model (came of my 73 Cuda)
3. Mopar Preformance Chrome New!
Note: Pick the one you want by photo 1-3
Oil Cap 2.jpg (1197 downloads)
Oil Cap 3.jpg (1197 downloads)
Oil Cap Chrome.jpg (1198 downloads)
73-74 Electric Choke #3656730 All Models [Re: Memongo] #3263773
10/13/24 02:05 AM
10/13/24 02:05 AM
Fenton, MI
Memongo Offline
Parts peddler
Memongo  Offline
Parts peddler
Fenton, MI
73-74 Electric Choke #3656730 All Models, Used, $30 + Shipping. Payment via US Postal Money Order. Shipping: US Address Only!
Fram CA160 Air Filter [Re: Memongo] #3263774
10/13/24 02:07 AM
10/13/24 02:07 AM
Fenton, MI
Memongo Offline
Parts peddler
Memongo  Offline
Parts peddler
Fenton, MI
Fram CA160 Air Filter. New, $5 + Shipping. Payment via US Postal Money Order Only!. Shipping: US Address Only!
Note: Used On Any 2bl Motor, See Photo 2 For Application!
Fram CA160 Air Filter 1.jpg (1199 downloads)
Fram CA160 Air Filter 2.jpg (1194 downloads)
Temperature Sending Unit / Oil Pressure Sending Unit [Re: Memongo] #3263775
10/13/24 02:08 AM
10/13/24 02:08 AM
Fenton, MI
Memongo Offline
Parts peddler
Memongo  Offline
Parts peddler
Fenton, MI
63-76 Temperature Sending Switch #2426458 Used $7.50 + Shipping
62-80 Oil Pressure Sending Unit For Models With Warning Light. Used, $7.50 + Shipping.
Page 1 of 3 1 2 3
