Re: Sketchy fuel gauge [Re: TJP] #3263146
10/09/24 11:03 PM
10/09/24 11:03 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Why would the weight make any difference? they both will raise and drop with the fuel level. I doubt one will drop further than the other both being hollow floats.
Re: Sketchy fuel gauge [Re: stumpy] #3263177
10/10/24 07:28 AM
10/10/24 07:28 AM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Google displacement
A heavier float, though it may float, will sit lower making the gauge read low. Now I don't know if the difference between the two matters enough to notice here. Then there is the dampening effect of the heavier vs lighter float.
The float in my 51 a a cork.
Re: Sketchy fuel gauge [Re: Sniper] #3263251
10/10/24 01:23 PM
10/10/24 01:23 PM
Tucson, AZ
Ramrod39 Offline
My New Title
Ramrod39  Offline
My New Title
Tucson, AZ
Google displacement
So if he plane exceeds the speed of the conveyor belt but there is a slight tailwind... whistling
Re: Sketchy fuel gauge [Re: Ramrod39] #3263357
10/11/24 06:47 AM
10/11/24 06:47 AM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Google displacement
Yet another concept that eludes your grasp. What makes a plane fly is the speed of the air across the wing. the wheels have no bearing on that.
Re: Sketchy fuel gauge [Re: Sniper] #3263473
10/11/24 02:57 PM
10/11/24 02:57 PM
Tucson, AZ
Ramrod39 Offline
My New Title
Ramrod39  Offline
My New Title
Tucson, AZ
[quote=stumpy]Why would the weight make any difference? they both will raise and drop with the fuel level. I doubt one will drop further than the other both being hollow floats.
Google displacement
Yet another concept that eludes your grasp. What makes a plane fly is the speed of the air across the wing. the wheels have no bearing on that. [/quote}
Tell you what, how about you attempt to broaden your grasp on humor? That was simply a reference to a similar thread/ debate that went around here and was fun to watch. Just a reminder of some of the things that were said. Jeeze, you need a full disclaimer these days or some keyboard cowboy will find a way to twist your statement and attack...
Re: Sketchy fuel gauge [Re: Sniper] #3263477
10/11/24 03:27 PM
10/11/24 03:27 PM
Irving, TX
feets Offline OP
Senior Management
feets  Offline OP
Senior Management
Irving, TX
Google displacement
Yes, one floats higher.
Quantify that.
They're on a float arm on top of the liquid. What would the difference be?
1/8 inch?
1/4 inch?
A tiny fraction of the total swing of the float arm on a relatively inaccurate gauge designed to give you a rough idea of remaining volume.
It would not make a notable difference.
- Stu Harmon
Re: Sketchy fuel gauge [Re: feets] #3263489
10/11/24 05:06 PM
10/11/24 05:06 PM
Kirkland, Washington
Pacnorthcuda Offline
Google displacement
Quantify that.
1/8 inch?
1/4 inch?
Then neither would weight, as both factor into the reading. Both make a difference, whether itโ€™s notable or not?
Re: Sketchy fuel gauge [Re: Pacnorthcuda] #3263510
10/11/24 07:41 PM
10/11/24 07:41 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Only difference I can think of would be the gauge stays on full a bit longer, or drops off full a bit sooner. The other extreme would be on the empty side. A heavy float sitting deeper in the fuel, could make contact with the bottom of the tank faster and may still read there is still fuel there.
Back when I worked at the Chrysler dealership, we had a lady that ran out of gas in her new car 3 times and had it dragged back to the shop because it would run. Her old car would run a long time when the gauge read empty, but this one was actually out of gas when the gauge read empty. I fixed the problem for her. I bent the float arm so the gauge was reading empty when there was still a 1/4 tank of gas. It dropped off of full pretty fast, but she didn't run out of gas again.
The point is, the float arm can be bent to give you a gauge that reads the way you like it to.
Re: Sketchy fuel gauge [Re: stumpy] #3263530
10/11/24 09:52 PM
10/11/24 09:52 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
the weight of the arm and effort required to overcome any resistance to moving can be affected by too small of a float. Think of an empty 55 gallon drum in water. It will float of course. Now take that same drum and fill it half way with gravel.
Put it back in the water, it will still float but sit lower in the water by X amount as its surface area remains the same but the weight changes.
A larger surface area would support the weight with less displacement of the water.
The size of the float has to overcome the weight of itself, the arm and any resistance it may have to moving. beer
Re: Sketchy fuel gauge [Re: TJP] #3263637
10/12/24 11:50 AM
10/12/24 11:50 AM
moparx Offline
moparx  Offline
my old man always "tried" to run out of gas because he always was "gonna get some gas" when the gauge got to empty, but for some unexplainable reason, he never ran out !
on the other hand, my brother ran around with a guy back in his school dayz, and slightly afterward, that thought when you get gas, you only put in a buck or two.........
many times, my little brother had to help push his buddy's car to the gas pumps, or walk to the gas station with a can and walk back when his buddy ran out !
one instance comes to mind...........
little bro, and his buddy were out with their girlfriends one night, running around consuming "adult beverages" in his buddy's car, and coming down the street past my house, they ran out of gas. [gee........what a surprise !........imagine that.........]
luckily, there is a little corner station about 100 feet from the light at end of the street [at that time, if i remember right, it was a 7-11], however, it's an uphill push !
so little brother and his buddy's girl friend get the "pleasure" of helping his buddy push his car up to the gas pumps.
at that time, little brother was dating a preacher's daughter. he was always called "Preacher Bob". [and yes, it seems all the stories you have heard about preacher's daughters are true, at least in this instance it was..... biggrin] she didn't help push, as she was "resting" in the back seat.
so his buddy puts in 2 bucks worth, and off to take the girls home..........
after that exertion of pushing the car to the gas pumps, little brother feels kind of nauseous........
when they get to the preacher's house, he gets his date out of the car, walks her up to the front door, props her against the house, rings the bell, barfs in the bushes and leaves ! ............
not sure how many dates they had later, but the story continues.............
many years later, after little brother earns a degree in business administration, plus degrees in both mechanical and electrical engineering, he lands a job with GE in erie, pennsylvania, at the locomotive building plant complex.
on one weekend, he was in town visiting, and my old man had taken his car to the local shop for a state inspection and dropped it off the day before.
since the car was ready, and little bro was staying at my place for the weekend, we hopped in my car, picked up the old man, and off to the shop we went to get the old man's car.
when we arrived, upon entering, we discovered "Preacher Bob" was there as well..........
"Preacher Bob" had warm greetings, saying : "hi Eric ! [me], hi Jim ! [the old man] but just had a perfect GLARE for my brother !
glancing sideways at my little brother, i could see he was doing his very BEST to conceal a HUGE laugh !
after the old man paid his bill, and a general BS session was done between me, the old man, the shop owner, and "Preacher Bob", we left..........[as expected, my brother didn't partake in the exchanged pleasantries]
as soon as we got outside, and away from the shop entrance enough distance we were sure nothing we said could be heard, little bro burst out laughing, and said : "wonder if ol' Preacher Bob" remember the night i barfed in his bushes ?"
we all had a huge laugh about that, and THAT story STILL brings huge laughter today when brought up with the few remaining family members ! laugh2
beer
Re: Sketchy fuel gauge [Re: moparx] #3263640
10/12/24 12:02 PM
10/12/24 12:02 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
My ex- BIL said my sister could drive cross country on empty. But as soon as he would take the car it would run out of gas 1/2 way to the nearest gas station about 2 miles away ๐Ÿคฃ๐Ÿคฃ๐Ÿคฃ๐Ÿป
Re: Sketchy fuel gauge [Re: TJP] #3263699
10/12/24 04:13 PM
10/12/24 04:13 PM
ohio
ruderunner Online content
ruderunner  Online Content
ohio
Ah the internet.
About the only place a conversation about an inoperable fuel gauge turns to puking in the bushes.
Not that I've never puked in the bushes.
Angry white pureblood male
Re: Sketchy fuel gauge [Re: ruderunner] #3263824
10/13/24 10:25 AM
10/13/24 10:25 AM
moparx Offline
moparx  Offline
Originally Posted by ruderunner
Ah the internet.
are you suggesting there is a story to be told ? whistling biggrin boogie
beer
Re: Sketchy fuel gauge [Re: moparx] #3263849
10/13/24 12:50 PM
10/13/24 12:50 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Ah the internet.
beer
I can tell you why the toilet and sink are sometimes close to each other.
But the news years eve party punch appeared and tasted harmless ๐Ÿ˜ฑ๐Ÿ‘Ž๐Ÿ’ฅ๐ŸŽ†๐Ÿคฎ๐Ÿคฎ๐Ÿคข๐Ÿคข๐Ÿ˜ต๐Ÿ˜ต
Re: Sketchy fuel gauge [Re: moparx] #3263875
10/13/24 03:28 PM
10/13/24 03:28 PM
ohio
ohio
Ah the internet.
beer
I don't remember much of it but it involved finishing off bottles of wine at a wedding reception.
Re: Sketchy fuel gauge [Re: ruderunner] #3263883
10/13/24 04:37 PM
10/13/24 04:37 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Back when we were dirt track racing, I remember a few problems associated with the annual points award banquets. All of those were held at the same location. Since that was the only times I had those problems, I'm blaming the location. whistling I have not been at that location since that last banquet I attended, and haven't had those problems since. I also quit drinking at about the same time, but that couldn't have had any effect on that....
Some how, this post has got to be related to a sketchy fuel gauge, but I'm not sure how. I know it has to be, I was responding to the discussion and on Moparts, the topics never venture off course.
Re: Sketchy fuel gauge [Re: poorboy] #3264252
10/15/24 10:53 AM
10/15/24 10:53 AM
moparx Offline
moparx  Offline
" I was responding to the discussion and on Moparts, the topics never venture off course."
haha haha haha haha haha haha
beer
