Re: Clearance oil pickup 4.5 stroke Hemi
[Re: mopar dave]
#3263370
10/11/24 08:47 AM
10/11/24 08:47 AM
Posts: 8,752 fredericksburg,va
cudaman1969
Itch Nutz
Itch Nutz
fredericksburg,va
Not many options here, i understand, but once i dent the tube, i lose the benefit of the 1/2" tube. Don’t just dent the pipe, make oval shape, a press or vice will work, heat to cherry red then squeeze it. An oval or squareish pipe will flow same as a round one
[Re: cudaman1969]
#3263400
10/11/24 10:34 AM
10/11/24 10:34 AM
Posts: 4,649 Motor City
6PKRTSE
Motor City
Not many options here, i understand, but once i dent the tube, i lose the benefit of the 1/2" tube. Don’t just dent the pipe, make oval shape, a press or vice will work, heat to cherry red then squeeze it. An oval or squareish pipe will flow same as a round one Come to think of it. That is what I did was oval the tube in a bench vise while cherry red. I didn't just ding the tube.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: mopar dave]
#3263645
10/12/24 01:14 PM
10/12/24 01:14 PM
Posts: 1,750 central il.
second 70
central il.
No kidding, it cracked on the thread? That is the thicker part of the tube. Yes
[Re: mopar dave]
#3263880
10/13/24 04:46 PM
10/13/24 04:46 PM
Posts: 2,499 Sydney,Australia
tex013
Sydney,Australia
with my Milodon pickup I actually used a taper die to recut the thread as it wouldnt go more than about 1 1/2 turns . Once recut went in a lot further . Did this on 2 different road race pan pickups . One went into my World block one into a stock block . Almost seemed like it was cut parrallel thread .
Tex
New best ET 10.259@129.65 . New best MPH 130.94 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: an8sec70cuda]
#3263888
10/13/24 06:15 PM
10/13/24 06:15 PM
Posts: 8,237 Plymouth, MI
Blusmbl
Plymouth, MI
I'd be concerned about the tube cracking. x2. I'd have no problems denting one but I wouldn't want to grind it in an area where it has the potential to crack. That's a lot of leverage from the end of the pickup to the threads for it to crack over time due to vibration.
