Page 1 of 3 1 2 3
Clearance oil pickup 4.5 stroke Hemi #3263212
10/10/24 11:24 AM
10/10/24 11:24 AM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
Back on the Hemi project. 4.5 stroke and Callie’s Compstar 2.200 rods. BMP thought it wouldn’t be an issue, but it is. Anyone here done this? After grinding the pickup adaptor I think I might have enough clearance on that, but the pickup tube is the real issue. How much do I need to be safe what would be the thinnest I can have on the pickup tube wall thickness. Trying to make enough clearance without getting too thin on the tube wall. Any ideas?
Re: Clearance oil pickup 4.5 stroke Hemi [Re: mopar dave] #3263240
10/10/24 12:50 PM
10/10/24 12:50 PM
Savoy_Ahoy Offline
Savoy_Ahoy  Offline
Eeek that's tight. Is moving to an external pickup an option?
Re: Clearance oil pickup 4.5 stroke Hemi [Re: Savoy_Ahoy] #3263245
10/10/24 01:46 PM
10/10/24 01:46 PM
Mt Morris Michigan
Mt Morris Michigan
That was my original plan, but with all the reports on losing prime after setting, I decided internal would be better since it will be primarily a street car.
Re: Clearance oil pickup 4.5 stroke Hemi [Re: mopar dave] #3263249
10/10/24 02:03 PM
10/10/24 02:03 PM
an8sec70cuda Offline
I'd be concerned about the tube cracking. twocents
CHIP
'69 road runner, 440-6, 4 speed, Dana 60
'71 Demon 340, no drivetrain, on blocks behind the barn
'06 GMC 2500HD LBZ Duramax
Re: Clearance oil pickup 4.5 stroke Hemi [Re: mopar dave] #3263250
10/10/24 02:03 PM
10/10/24 02:03 PM
Benton, IL.
DaveRS23 Online rolleyes
Master of nothing...
DaveRS23  Online Rolleyes
Benton, IL.
Have you thought about using an Accusump for priming? Since my car can sit for a month at a time, I use one as a primer. Fully oiled before I hit the key. In your case, it would kill two birds with one stone. Priming the pump AND the entire engine.
Just a thought.
Master, again and still
Re: Clearance oil pickup 4.5 stroke Hemi [Re: DaveRS23] #3263257
10/10/24 02:50 PM
10/10/24 02:50 PM
Mt Morris Michigan
Mt Morris Michigan
No, never gave that a thought. Sounds like a good option. Really want to keep things simple with the inter oiling.
Re: Clearance oil pickup 4.5 stroke Hemi [Re: mopar dave] #3263259
10/10/24 02:57 PM
10/10/24 02:57 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I'd fab a different adapter with the threaded hole pointing towards the skirt of the block. Then put a bend in the tube. This would allow the tube to hug the inside of the block skirting.
Doug
Re: Clearance oil pickup 4.5 stroke Hemi [Re: dvw] #3263269
10/10/24 04:20 PM
10/10/24 04:20 PM
Mt Morris Michigan
Mt Morris Michigan
Yes, I called Bill Mitchell and asked him if he had a different adaptor. He does not. Where do I look?
Re: Clearance oil pickup 4.5 stroke Hemi [Re: mopar dave] #3263275
10/10/24 04:42 PM
10/10/24 04:42 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
I like your original plan better. It is a 4.5" stroke and probably a big powerful motor. Go external like you planned on and quit thinking about losing prime. Hemi's have been using external pickups for over 50 years. Do you know why every Hemi Super Stocker in the country had external 50 years ago? It's because they had big powerful engines (not as powerful as yours) and they wanted it to have good oiling. BMP sells a block-off plate.
2011 Drag Pak Challenger
Re: Clearance oil pickup 4.5 stroke Hemi [Re: rickseeman] #3263280
10/10/24 05:31 PM
10/10/24 05:31 PM
fredericksburg,va
cudaman1969 Offline
Itch Nutz
cudaman1969  Offline
Itch Nutz
fredericksburg,va
The right pump doesn’t need the block off (no hole in pump body) loop the external line higher behind the pump so there’s always oil laying in it when engine is not running. My first system I made in the early 70s was a static single line that ran behind the deep pan sump, took awhile to prime till I put the line up under header( above pump) instant prime after that. I also used the big Teflon lined line (same size as the rubber line 14?)
Re: Clearance oil pickup 4.5 stroke Hemi [Re: rickseeman] #3263283
10/10/24 05:42 PM
10/10/24 05:42 PM
gregsdart Offline
gregsdart  Offline
After having another episode of no prime, after custom clearanncing my oil pump to minimum specs, i am thinking of a way to put vacuum draw on the inlet side of the oil pump pickup, right up by the pump. If i could draw oil up by the pump, it should then prime quickly. I have an accusump, and despite a full pre oil, it refused to prime. So if this idea has merit, you might be able to use it on your Hemi.
I am tired of pulling the distributor and gear on my motor, as at times it has taken a lot of trys to get the pump gear to go back in. So drilling and tapping a 1/8 pipe plug port , and using a small vacuum pump to pull oil is what i am considering. If my idea works it would save me a lot of messing around. One of those tire deflater things comes to mind, since i have a compresser in my race trailer. My last fail to pull prime was on a cold morning at the track.
8.582, 160.18 mph best, 2905 lbs 549, indy 572-13, alky
Re: Clearance oil pickup 4.5 stroke Hemi [Re: mopar dave] #3263298
10/10/24 08:31 PM
10/10/24 08:31 PM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
HI
my 4.5 in stroke hemi has stock type internal oiling . miladon pan
never a oiling issue , been together sense 2012
should have app .060 clearance .
get out the tourch and heat it red and put a small dent for clearance at closest point . done !
Re: Clearance oil pickup 4.5 stroke Hemi [Re: calrobb2000] #3263309
10/10/24 09:52 PM
10/10/24 09:52 PM
fredericksburg,va
cudaman1969 Offline
Itch Nutz
cudaman1969  Offline
Itch Nutz
fredericksburg,va
Think about this, internal pipe is below pump same as external so inside I’ve never heard of a priming problem, why is external NOT priming? I’m sure the oil drains back into sump with internal pipe. Sounds like it’s sucking air at some place
Re: Clearance oil pickup 4.5 stroke Hemi [Re: calrobb2000] #3263310
10/10/24 09:55 PM
10/10/24 09:55 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
I have heated and dinged the pick up tubes also in the past also. However, I am currently running the dual line external system on the street with no lose of prime issues with a slight loop. Here is the loop in the picture.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Clearance oil pickup 4.5 stroke Hemi [Re: cudaman1969] #3263312
10/10/24 10:01 PM
10/10/24 10:01 PM
gregsdart Offline
gregsdart  Offline
Inabiliy to prime comes from the pump clearances hindering the pump to pull oil, the volume of the system, viscosity and temp of oil. At somewhere around 50 degrees temp with 20w50 oil and an external pickup,(big volume from oil to pump in the external line) the pump has to spin a ton of rpm to pull oil, and for more time than you dare run without pressure.
Re: Clearance oil pickup 4.5 stroke Hemi [Re: mopar dave] #3263314
10/10/24 10:11 PM
10/10/24 10:11 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
What block is that? Wonder if a 528 crank would be that bad? I'm thinking about a 4.50 stroke and I don't like the looks of that on the street.
Re: Clearance oil pickup 4.5 stroke Hemi [Re: mopar dave] #3263356
10/11/24 07:13 AM
10/11/24 07:13 AM
A shed in England
Tig Offline
Tig  Offline
A shed in England
I always used to prime my engine with an electric drill if the car had been standing for any length of time, (it would hold prime for a week or so). It always took a couple of seconds before you could feel the oil pressure load the drill. I switched to a 3 qt Canton accusump when the car started to do big wheelstands and now just use that. I can leave the car for months with the accusump pressurized, pull the release cable and the engine is primed. I've done it whilst under the car, you can hear the oil flooding the engine and draining back to the sump. There is a technique to re-filling the accusump when the engine is started, I shut the accusump off and gently open it to allow the oil to re-fill it, while watching the oil pressure gauge. Fill it too quickly and you can see the oil pressure drop excessively.
Re: Clearance oil pickup 4.5 stroke Hemi [Re: Tig] #3263359
10/11/24 08:10 AM
10/11/24 08:10 AM
Deep DEEP SOUTH
LAD 524 Offline
LAD 524  Offline
Deep DEEP SOUTH
If the pickup clearance issue and the fragility of the tube has you worried, just go external oilingand run one of these. Granted not the cheapest way but work like a charm.
Pre oil your engine before every fire up.
Done.
Re: Clearance oil pickup 4.5 stroke Hemi [Re: cudaman1969] #3263361
10/11/24 08:19 AM
10/11/24 08:19 AM
Mt Morris Michigan
Mt Morris Michigan
I had a Milodon aluminum pump on my wedge. It would loose prime every time i changed the oil. The air leak was on the snout of the pump at the oil ring. A little rtv fixed it, but maybe a gob of grease would be better. If you use too much rtv, a wad of it can fall off and get into the pump and shear the oil pump shaft. Ask me how i know.
Re: Clearance oil pickup 4.5 stroke Hemi [Re: LAD 524] #3263363
10/11/24 08:24 AM
10/11/24 08:24 AM
Mt Morris Michigan
Mt Morris Michigan
I do appreciate your options and may have to use one, but i'm set on internal oiling this thing if i can make it happen. It will never see over 7000rpm. I want as little hassles as possible, just easy start up and drive away.
Page 1 of 3 1 2 3
