Kick panel insulatiion #3260060
09/25/24 05:19 PM
09/25/24 05:19 PM
tboomer Online content OP
tboomer  Online Content OP
Who is a good source for kick panel insulation? I took one out of my GTS and replaced it with one purchased from a member here. Thanks Jon! The old insulation was junk but I put the panel in anyhow. I wonder if I even need the insulation as the car isn't driven in cold weather?? work
Re: Kick panel insulatiion [Re: tboomer] #3260073
09/25/24 06:56 PM
09/25/24 06:56 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I've never noticed a difference with/without.
Re: Kick panel insulatiion [Re: topside] #3260094
09/25/24 09:27 PM
09/25/24 09:27 PM
Thanks for the reply! up
Re: Kick panel insulatiion [Re: tboomer] #3260109
09/25/24 10:10 PM
09/25/24 10:10 PM
Warren, MI
71TA Offline
71TA  Offline
Warren, MI
The original insulation was for sound deadening. It had about a 3/16" layer of heavy tar paper that worked like a primative version of Dynamat. Even the original trunk mats were made from a primative material calledf MLV (Mass Loaded Vinyl). Basically black PVC vinyl mixed with metal and stone "dust" to make it heavier. Again, for sound deadening. Yep, even the hood insulation. Sound deadening. I hear such crazy ideas of what the hood insulation is for smile
www.DetroitMuscleTechnologies.com Mopar body and heater box restoration gaskets
Re: Kick panel insulatiion [Re: 71TA] #3260126
09/26/24 01:55 AM
09/26/24 01:55 AM
On the run…
BloFish Offline
BloFish  Offline
On the run…
Yup
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: Kick panel insulatiion [Re: BloFish] #3260174
09/26/24 11:08 AM
09/26/24 11:08 AM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
Not needed anymore, they make good houses for mice though...
JB Rhinehart, Realist
A-Body's RULE!
Re: Kick panel insulatiion [Re: Rhinodart] #3260286
09/26/24 06:26 PM
09/26/24 06:26 PM
Yeah...I don't need any mouses in my cars... beer
Re: Kick panel insulatiion [Re: tboomer] #3262837
10/08/24 03:30 PM
10/08/24 03:30 PM
NJ
EV2RTSE Offline
EV2RTSE  Offline
NJ
I just did the firewall insulation / cowl shoddy pad / kick panel insulation on my car over the weekend, used everything 71TA sells, great stuff as always. Firewall insulation nails popped right in, everything just fits like it should. I'm adding Kilmat to the roof before the headliner goes in and also to the floor under the carpet. And the doors as well. When used as a whole it makes a significant difference in noise reduction.
