For Sale/ Wanted - Big Block Engine - 4th Quarter #3260990
09/30/24 06:37 PM
09/30/24 06:37 PM
Norwich CT USA
moparts Offline OP
moparts  Offline OP
Norwich CT USA
Holley 12-846 HP Billet Fuel Pressure Regulator "NEW" [Re: moparts] #3261024
09/30/24 07:52 PM
09/30/24 07:52 PM
Northwest Indiana
19Coronet66 Offline
19Coronet66  Offline
Northwest Indiana
For sale is a "NEW" in the box Holley HP Billet adjustable fuel pressure regulator. Part number 12-846. EFI applications. Bypass style. Adjustable from 15-65 PSI. -8AN o-ring inlet. -8 o-ring outlet. -6AN o-ring return. $160 shipped in the 48 states. PM if interested.
https://www.jegs.com/i/Holley/510/12-846/10002/-1
Re: For Sale/ Wanted - Big Block Engine - 4th Quarter [Re: moparts] #3261071
09/30/24 09:42 PM
09/30/24 09:42 PM
Greensburg, Pa
Mpetros Offline
Mpetros  Offline
Greensburg, Pa
Wanted 572 or bigger B-1 Engine.
724-433-0527
Re: For Sale/ Wanted - Big Block Engine - 4th Quarter [Re: moparts] #3261140
10/01/24 07:39 AM
10/01/24 07:39 AM
Detroit area
6PAX Offline
6PAX  Offline
Detroit area
70 B-body voltage regulator mounting bracket. $15
New chrome coil cover & coil mounting bracket. $20
New factory type big block spark plug wire separator kit. Some surface rust from humidity on a couple of them. $50
NOS big block heat riser kit #3420046. $225
NOS Cal Custom chrome radiator cap. $20
NOS Cal Custom chrome battery hold down. $25
Four new extra wide chrome valve cover hold down clamps. $10 for the set
NOS Cal Custom polished big block valve covers. $450
New exhaust manifold heat stove to air cleaner hose. $20
NOS fan clutch 3769614 for 1974 all V-8 engines. $100
New big block chrome valley pan hold down rails & bolts. $30
Gauge type oil pressure sending unit. $20
Vintage Cal Custom 14" finned aluminum air cleaner with filter. $100
New Mopar Performance chrome big block distributor hold down. $20
New 12" long oval 4 barrel aluminum air cleaner with filter. It measures 12" L x 8 1/4" W x 3" H and has a 5 1/8" carb opening. $55
New Mopar Performance chrome water neck. Was bolted on an engine but then taken back off before the engine was ran. $10
NOS Direct Connection big block double roller timing chain #P4120264. $75
New Mr. Gasket chrome oil filter cover. $15
MP big block high volume oil pump P4286590. This was new when I tried it on my motor but it was too much pressure so I switched to a stock pump. $80
9 Chrome t-handle valve cover bolts. $10
Factory starter, part/casting #3755259. This came off of my Dart about 10 years ago. Worked fine then, been sitting on a shelf ever since. $40
NOS Cal Custom chrome dagger dipstick handle. $25
Mopar Performance 5 blade radiator fan and clutch. $100
1972 400 spark plug shields $10 pair
Factory warning light type oil pressure sending unit. $10
Chrome big block timing tab. $5
Chrome single groove alternator pulley. $15
New Mopar Performance big block 8 qt. oil pan with new pick-up. $200
1971 Charger big block throttle cable. $40
New AR Engineering big block lightweight alternator kit with 60 amp Denso alternator. I mounted this on my engine on the stand but ended up using a factory alternator. $175
Original 2 piece heat stove from 1970 440 exhaust manifold. Good condition. $125
1975 Date coded alternator. Part #3874271. $25
Pioneer Automotive cylinder head dowel pins. 21 pieces 1/4" x 5/8". $10
1967 4bbl intake manifold part# 2806178. Sandblasted and primed. $100
Rev-n-nator Coil and programmable ICU. $200
Vintage Cal Custom scoop style air cleaner. Very nice condition. Includes often missing matching wingnut. $300
New in boxes QTP 2 1/2" electric exhaust cutouts #QTEC50, stainless y-pipes #10250 and remote controller #10900. $654 total price at Summit. $500
Prices do not include shipping. No Paypal
gt340 @ yahoo.com
Sold [Re: 6PAX] #3261365
10/01/24 11:44 PM
10/01/24 11:44 PM
Baton Rouge, LA
SethJof Offline
SethJof  Offline
Baton Rouge, LA
Sold
440 Six Pack Center Carb 4144-1 - reconditioned [Re: Mpetros] #3262328
10/06/24 03:43 PM
10/06/24 03:43 PM
CT
Rocket Offline
Rocket  Offline
CT
I have a 440 six pack center carb part # 4144-1 that was factory reconditioned by Holley. Has not been run since reconditioned.
$750 shipped in the lower 48 states. I will ship internationally for the added cost.
Email me at procketrichard@hotmail.com for more pictures or any questions.
Re: 440 Six Pack Center Carb 4144-1 - reconditioned [Re: Rocket] #3262820
10/08/24 02:51 PM
10/08/24 02:51 PM
motor city
sixty9redgtx Offline
motor city
1963 Maxie rods set of five (5) for 413, 426 maxwedge ramcharger.
P/n 2406395 stamped on each one.
Ms3049 also stamped on each one.
Been wrapped in newspaper from June 69'.
Look in excellent condition, most likely never ran.
Any questions, just ask. Thanks
$375.00 + shipping
