'70 Duster V-8 fan shroud number #3262120
10/05/24 11:12 AM
10/05/24 11:12 AM
mississippi
lostdog Offline OP
lostdog  Offline OP
mississippi
Can someone share the part number or a link to where I can find it? - hopefully going to pick up a fan shroud Monday for the '70 Duster. The guy has lots of parts so I want to make sure I am getting the right thing.
The car is originally a /6 but I am putting a magnum 360 in it with aftermarket V-8 radiator. I know I will have to do some minor mods for the larger rad and maybe shroud
Thanks guys !
Re: '70 Duster V-8 fan shroud number [Re: lostdog] #3262200
10/05/24 06:41 PM
10/05/24 06:41 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
1970-72 A-Body 22" V-8 radiator fan shroud. Original part number 2998 325
Look for xxxxx 325 part # molded into one of the ears. They did make repro's at on time that were not good. I think new repro's are better. So be careful someone isn't dumping on of those 1st run bad repro's on you.
Fall Fling 28 October 19, 2024 at Woodley Park, Van Nuys CA
300+ Mopars, 125+ swap, midway, Friday Malibu cruise,
