Re: Crack repair
[Re: A727Tflite]
#3261176
10/01/24 10:23 AM
10/01/24 10:23 AM
Posts: 20,277 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Any of you guys have suggestions/experiences of repairing a small weeping crack in a cast iron cylinder head? Been welded already but chasing the weld.
JB Weld Iron putty, etc,? Intake or exhaust port???
1970 Duster Edelbrock headed 408 5.984@112.52 422 Indy headed small block 5.982@112.56 mph 9.38@138.67
Re: Crack repair
[Re: pittsburghracer]
#3261270
10/01/24 04:10 PM
10/01/24 04:10 PM
Posts: 3,185 Michigan
A727Tflite
JB Weld Iron putty, etc,? Intake or exhaust port??? It’s a Hemi. Internal crack at the top of the ledge between a spark plug and a stand boss.
Re: Crack repair
[Re: B1MAXX]
#3261358
10/01/24 10:41 PM
10/01/24 10:41 PM
A727Tflite
under the valve cover is still exterrnal to me. Into water? loc-n-stich is still the right fix. lets see it. I was made aware of stitching over 50 years ago. I was asking for suggestions using epoxy, etc. Thanks.
Re: Crack repair
[Re: jwb123]
#3261446
10/02/24 01:55 PM
10/02/24 01:55 PM
Posts: 43,764 Bend,OR USA
Cab_Burge
Re: Crack repair
[Re: Cab_Burge]
#3261462
10/02/24 02:45 PM
10/02/24 02:45 PM
Posts: 13,498 Marion, South Carolina [><]
an8sec70cuda
Since it's been welded already and leaking through the weld, I think some sort of epoxy is your only option. I don't know what to suggest b/c I've had zero luck w/ welded cast iron holding water.
CHIP '70 hemicuda, 575" Hemi, 727, Dana 60 '69 road runner, 440-6, 4 speed, Dana 60 '71 Demon 340, no drivetrain, on blocks behind the barn '73 Chrysler New Yorker, 440, 727, 8.75 '90 Chevy 454SS Silverado, 476" BBC, TH400, 14 bolt '06 GMC 2500HD LBZ Duramax
Re: Crack repair
[Re: varunner]
#3261533
10/02/24 08:24 PM
10/02/24 08:24 PM
Posts: 3,031 NY
B1duster
NY
Have you thought about trying head gasket sealer ? Blue Devil sealer works. I found it lasts 4-6 months of daily use. You pour it in with engine cold, start and idle for 50 mins. Done I kept a car going for a couple of years with it.
BlueDevil's Head Gasket Sealer is a permanent seal that can repair and seal leaks in cracked heads, warped heads, blown head gaskets, heater cores, and freeze plugs. It's compatible with diesel and gasoline engines and can bond to aluminum, cast, alloy, metal, or plastic. It's safe to use and won't clog or harm your engine because it doesn't contain any solid or particulate matter.
