Page 1 of 3 1 2 3
For Sale/ Wanted - Small Block Engine - 4th Quarter #3260993
09/30/24 05:38 PM
09/30/24 05:38 PM
Norwich CT USA
moparts Online boogie OP
moparts  Online Boogie OP
Norwich CT USA
Holley 12-846 HP Billet Fuel Pressure Regulator "NEW" [Re: moparts] #3261026
09/30/24 06:54 PM
09/30/24 06:54 PM
Northwest Indiana
19Coronet66 Offline
19Coronet66  Offline
Northwest Indiana
For sale is a "NEW" in the box Holley HP Billet adjustable fuel pressure regulator. Part number 12-846. EFI applications. Bypass style. Adjustable from 15-65 PSI. -8AN o-ring inlet. -8 o-ring outlet. -6AN o-ring return. $160 shipped in the 48 states. PM if interested.
https://www.jegs.com/i/Holley/510/12-846/10002/-1
Re: For Sale/ Wanted - Small Block Engine - 4th Quarter [Re: moparts] #3261072
09/30/24 08:45 PM
09/30/24 08:45 PM
Greensburg, Pa
Mpetros Offline
Mpetros  Offline
Greensburg, Pa
Wanted 408 engine or bigger with Single 4 intake.
Mark 724-433-0527
Re: For Sale/ Wanted - Small Block Engine - 4th Quarter [Re: moparts] #3261141
10/01/24 06:41 AM
10/01/24 06:41 AM
Detroit area
6PAX Offline
6PAX  Offline
Detroit area
70 B-body voltage regulator mounting bracket. $15
New chrome coil cover & coil mounting bracket. $20
NOS Cal Custom chrome radiator cap. $20
NOS Cal Custom chrome battery hold down. $25
Four new extra wide chrome valve cover hold down clamps. $10 for the set
New exhaust manifold heat stove to air cleaner flexible hose. $20
NOS fan clutch 3769614 for 1974 all V-8 engines. $100
Factory warning light type oil pressure sending unit. $10
Gauge type oil pressure sending unit. $20
Vintage Cal Custom 14" finned aluminum air cleaner with filter. $100
New 12" oval 4 barrel finned aluminum air cleaner with filter. It measures 12" L x 8 1/4" W x 3" H and has a 5 1/8" carb opening. $55
New Mopar Performance chrome water neck. Was bolted on an engine but then taken back off before the engine was ran. $10
AC alternator bracket from a mid 70s 360. $10
New Mr. Gasket chrome oil filter cover. $15
9 Chrome t-handle valve cover bolts. $10
Factory starter, part/casting #3755259. This came off of my Dart about 10 years ago. Worked fine then, been sitting on a shelf ever since. $40
Two 318 driver side spool motor mounts pt#3642811. One is used and one is NOS. $20 for the used. $35 for the NOS.
Edelbrock Elite small block valve covers EDL-4295 with bolts, breather & PCV valve. Very nice condition. $200
NOS Cal Custom chrome dagger dipstick handle. $25
New Mopar Performance 5 blade radiator fan and clutch. $100
Pioneer Automotive cylinder head dowel pins. 21 pieces 1/4" x 5/8". $10
Howard's solid flat tappet cam for Mopar big blocks, part number CL722322-08. See links below for specifications. I bought this cam for my engine with the intention of taking the car to the track when the car was finished being restored along with the engine being built but I have changed my mind about racing the car and decided to go with a milder hydraulic cam instead. I had this cam installed in my engine on the engine stand only (engine is still on the stand) so it has never been run and is essentially new. $375
New set of COMP Cams 973-16 - Inner Valve Springs. $45
Chrome single groove alternator pulley. $15
1975 Date coded alternator. Part #3874271. $25
Rev-n-nator Coil and programmable ICU. $200
Vintage Cal Custom scoop style air cleaner. Includes often missing matching wingnut. $300
New in boxes QTP 2 1/2" electric exhaust cutouts #QTEC50, stainless y-pipes #10250 and remote controller #10900. $654 total price at Summit. $550
Prices do not include shipping. No Paypal
Email: gt340 @ yahoo.com
Re: For Sale/ Wanted - Small Block Engine - 4th Quarter [Re: moparts] #3261463
10/02/24 01:49 PM
10/02/24 01:49 PM
CA, Proprietor; The "PALOMINO"...
dynotune440 Offline
dynotune440  Offline
llooking for a new camshaft part number 2899205 , which is the 1968 340 manual transmission camshaft. Im out in california...dm me here...
Thanks for the ad.
Dinuba, California, Home of the PALOMINO ranch and 440 truck farm, where dodge trucks have a home. Have Four 1979 dodge PALOMINO trucks now.
Re: For Sale/ Wanted - Small Block Engine - 4th Quarter [Re: dynotune440] #3261780
10/03/24 05:28 PM
10/03/24 05:28 PM
Home of the Bluegrass
MoparJunkie Offline
MoparJunkie  Offline
Looking for '70 340 passenger valve cover that would be correct for a TA 340. Also wanting a 70 date coded alternator. PM me with what you have. TIA
"It takes a Mopar to catch a Mopar”
1970 Challenger T/A 4 speed EV2
New 360 & 5.9 Magnum Assembly-408” [Re: MoparJunkie] #3262292
10/06/24 11:42 AM
10/06/24 11:42 AM
CT
Rocket Offline
Rocket  Offline
CT
I have a new SCAT forged rotating assembly for 360 & 5.9 Magnum Mopar engines. All parts are new high-quality parts. Final cubic inches will be 408”.
The assembly includes the following parts.
• SCAT forged 4.000” crankshaft part # 4-360-4000-6123
• SCAT forged H-beam connecting rods with APR 2000 bolts part # 2-360-6123-2124A
• Diamond Forged flattop 4.030” bore pistons (0.030” oversize) part # 51026
• Trend wrist pins - 0.984” part # TPD-G9842750155
• Diamond wrist pin locks
• Mahle file fit ring set with Moly ductile iron top rings part # MAH4035MS
• Speed Pro Tri metal Competition Series rod bearings part # 8-7125CH
• Clevite P-Series full groove main bearings part # MS-1266P
If you are looking for a 360 stroker with lower compression, I can substitute the pistons and connecting rods for new SRP 4.030” dished pistons part # 220156 (16.9 cc piston head volume) and new Eagle H-beam rods part # CRS6123C3D (360 stroker assembly only).
These rotating assemblies will need balancing.
The price for this complete kit with the Diamond flat top pistons and SCAT rods is $2,750 plus shipping cost.
The price for this complete kit with the SRP dished pistons and the Eagle H-beam rods is $2,600 plus shipping cost.
I also have a similar stroker assembly for a 340 with new Diamond 4.060” (0.020” overbore) flat top pistons, Perfect Circle file fit ring set with Moly ductile iron top rings part # 315-0036.065
and Speed Pro Tri metal Competition Series rod bearings part # 8-7125CH. Displacement would be 414 ci. This rotating assembly will need balancing.
The price for the complete 340 kit is $2,750 plus shipping cost.
I can also meet in CT.
Email me at procketrichard@hotmail.com with any questions or for more pictures.
New 340 Stroker Assembly-414” [Re: Rocket] #3262293
10/06/24 11:45 AM
10/06/24 11:45 AM
CT
Rocket Offline
Rocket  Offline
CT
I have a new forged rotating assembly for 340 Mopar engines. All parts are new high-quality parts. Final cubic inches will be 414”.
• SCAT forged 4.000” crankshaft part # 4-340-4000-6123
• Diamond Forged flattop 4.060” bore pistons (0.020” oversize) part # 51028
• Trend wrist pins part # TPD-G9842750155
• Perfect Circle file fit ring set with Moly ductile iron top rings part # 315-0036.065
• Clevite P-Series full groove main bearings part # MS-1344P
Price for this complete kit is $2,750 plus shipping cost.
Small Block Solid Roller Lifters - New [Re: Rocket] #3262295
10/06/24 11:49 AM
10/06/24 11:49 AM
CT
Rocket Offline
Rocket  Offline
CT
I have 11 pairs (one complete engine set plus 3 spare pairs) of new Mopar Performance solid roller lifters for small block still in their packages. I took one pair to photograph. Part number is P5249584. See the included picture from the 1997 Mopar Performance catalogue for the description. The roller wheel size is ~ 0.80”.
I fit these into my stock 340 block and they fit in nicely. On my block, the block required very minor grinding to a very small spot in the raised section of the valley to allow two of the eight lifter pairs to slide in. Contact was in the center of the link bar.
The price for the 11 pairs is $650 shipped in the lower 48 States. I will ship internationally for the additional cost.
R Block Lifters 1.jpg (739 downloads)
R Block Lifters 5.jpg (741 downloads)
R Block Lifters 8.jpg (741 downloads)
R Block Lifters 9.jpeg (738 downloads)
Small Block Roller Rocker Kit 1.6 Ratio - New [Re: Rocket] #3262296
10/06/24 11:51 AM
10/06/24 11:51 AM
CT
Rocket Offline
Rocket  Offline
CT
I have a new PRW 1.6 ratio roller rocker arm kit containing all parts needed to install these rocker arms including steel bushed rocker arms, rocker arm shafts, spacers, shims, adjusters, steel shaft hold downs and hold down hardware. This kit is new in the box and is PRW part # 3231812.
Price is $500 shipped in the lower 48 states.
I will ship internationally for the additional shipping cost.
PRW 1.6 Pic 4.jpg (738 downloads)
PRW 1.6 Pic 5.jpg (739 downloads)
PRW 1.6 Pic 8.jpg (736 downloads)
PRW 1.6 Pic 3.jpg (735 downloads)
Forged Pistons & pins for 3.79" Stoke Crankshaft [Re: Rocket] #3262298
10/06/24 11:53 AM
10/06/24 11:53 AM
CT
Rocket Offline
Rocket  Offline
CT
I have a set of New BRC 4.030" forged flat top pistons and pins for a 3.79" stroke small block crankshaft. Compression height is ~ 1.57" and the ring lands are 1/16, 1/16 and 3/16. Pins are 0.984”. Approximately 6cc valve reliefs.
These pistons can be used in aftermarket race blocks or stock 360/5.9 magnum engine blocks with 4.030” finished bores.
Price is $475 shipped in the lower 48 states. I will ship elsewhere for the added cost.
BRC 3.79 P1.JPG (787 downloads)
BRC 3.79 P2.JPG (788 downloads)
BRC 3.79 P3.JPG (786 downloads)
BRC 3.79 P4.JPG (786 downloads)
Small Block Forged 4.060” Pistons for 3.454” Stroke - New [Re: Rocket] #3262301
10/06/24 12:03 PM
10/06/24 12:03 PM
CT
Rocket Offline
Rocket  Offline
CT
I have a new set of 8 Mopar Performance pistons and wrist pins Mopar part# P4876973 for a 3.454” stroke crankshaft. Specs are 4.060” bore, 1/16, 1/16, 3/16 ring set, 0.984” wrist pin, flat top with ~ 5 cc eyebrows, listed by Mopar as 10.5 compression ratio. Compression height is ~ 1.72” per my measurement.
Price for the set is $480 shipped in the lower 48 states. I will ship internationally for the extra cost.
Six Pack Center Carb - Refurbished [Re: Rocket] #3262329
10/06/24 02:46 PM
10/06/24 02:46 PM
CT
Rocket Offline
Rocket  Offline
CT
I have a 440 six pack center carb part # 4144-1 that was factory reconditioned by Holley. Has not been run since reconditioned. Can also be used on 340 six pack engines but may require a jet change.
$750 shipped in the lower 48 states. I will ship internationally for the added cost.
Email me at procketrichard@hotmail.com for more pictures or any questions.
polished RPM intake. SOLD [Re: Rocket] #3263147
10/09/24 11:05 PM
10/09/24 11:05 PM
CA.
RAY1969CARS Offline
RAY1969CARS  Offline
CA.
small block polished RPM intake 350+ actual shipping will show receipt located in southern California San Fernando Valley brand new never ported never installed
SOLD
Custom Small Block 3,4 Speed Throttle Cable Bracket [Re: moparts] #3263781
10/13/24 02:21 AM
10/13/24 02:21 AM
Fenton, MI
Memongo Offline
Parts peddler
Memongo  Offline
Parts peddler
Fenton, MI
Custom Small Block 3,4 Speed Throttle Cable Bracket. Used, $25 + Shipping. Payment via US Postal Money Order Only! Shipping: US Address Only!
Call Steve 810-629-1097
Note: Works with any high rise intake or carburetor spacer
W-2 Small Block Throttle Cable Bracket [Re: Memongo] #3263782
10/13/24 02:22 AM
10/13/24 02:22 AM
Fenton, MI
Memongo Offline
Parts peddler
Memongo  Offline
Parts peddler
Fenton, MI
W-2 Small Block Throttle Cable Bracket. New, $15 + Shipping. Payment via US Postal Money Order Only! Shipping: US Address Only!
Small Block Carburetor Throttle Return Spring Brackets [Re: Memongo] #3263783
10/13/24 02:23 AM
10/13/24 02:23 AM
Fenton, MI
Memongo Offline
Parts peddler
Memongo  Offline
Parts peddler
Fenton, MI
Small Block Carburetor Throttle Return Spring Brackets. Used, $15 each + Shipping. Payment via US Postal Money Order Only! Shipping: US Address Only!
Factory Small Block Valve Covers 318,340,360 [Re: Memongo] #3263784
10/13/24 02:24 AM
10/13/24 02:24 AM
Fenton, MI
Memongo Offline
Parts peddler
Memongo  Offline
Parts peddler
Fenton, MI
Factory Small Block Valve Covers 318,340,360, Used, $50 + Shipping. Payment via US Postal Money Order Only! Shipping: US Address Only!
Note: All Harness, Wire Brackets Intact!
Factory Small Block Valve Cover Breather [Re: Memongo] #3263786
10/13/24 02:25 AM
10/13/24 02:25 AM
Fenton, MI
Memongo Offline
Parts peddler
Memongo  Offline
Parts peddler
Fenton, MI
Factory Small Block Valve Cover Breather. Used, $15 + Shipping. Payment via US Postal Money Order Only! Shipping: US Address Only!
Valve Cover Oil Fill Caps [Re: Memongo] #3263787
10/13/24 02:26 AM
10/13/24 02:26 AM
Fenton, MI
Memongo Offline
Parts peddler
Memongo  Offline
Parts peddler
Fenton, MI
Valve Cover Oil Fill Caps. Used, $10 Each + Shipping. Payment via US Postal Money Order Only! Shipping: US Address Only!
1. Not sure!
2. 73-74 model (came of my 73 Cuda)
3. Mopar Preformance Chrome New!
Note: Pick the one you want by photo 1-3
Oil Cap 2.jpg (592 downloads)
Oil Cap 3.jpg (591 downloads)
Oil Cap Chrome.jpg (588 downloads)
Page 1 of 3 1 2 3
