Re: B Body - Cars/ Parts Wanted - 4th Quarter
[Re: Sunroofcuda]
#3272862
11/28/24 01:25 AM
11/28/24 01:25 AM
Posts: 8,620 Highland, MI.
Sunroofcuda
Highland, MI.
WANTED:
For a 1971-4 Charger: Looking for a small patch panel area in front of each rear wheel. Obviously, no rust, so someone from the SW US with a car with damaged quarters. I need these patches basically cut up to the lower body line & about 12" forward of the wheel opening, with a little bit of the outer wheel tub. My car is a '71. Multiple contours down there including the lip at the wheel opening would be difficult to shape - I'd rather have some good OE patches.
Re: WANTED: 65 poly 318 throttle bracket
[Re: 62maxxx]
#3275508
12/11/24 03:36 PM
12/11/24 03:36 PM
Posts: 3,415 cheshire, ct
davesmopars
cheshire, ct
Wanted 65 poly 318 throttle bracket with automatic transmission Thanks
Keeper of the 440 M code Cuda registry mcodecuda@yahoo.com
[Re: moparts]
#3277811
12/23/24 06:38 PM
12/23/24 06:38 PM
Posts: 2 Newcomerstown
Ratvon
Newcomerstown
Wanted....63 to 65 small block motor mounts
[Re: moparts]
#3279244
12/30/24 11:12 PM
12/30/24 11:12 PM
Posts: 50 Burnsville MN
ClassicIronman
Burnsville MN
Looking for a good 72 Charger Big block radiator, not sure of the part number It was built in Dec of 71 Needs to have good non dented tanks for a re-core if needed. If you know the part number it would be appreciated.
John Chaney Johnmn420@ol.com 952-239-6883
