Re: Looking For Mr. Six Pack Cam Information
#32598
12/25/06 11:07 PM
12/25/06 11:07 PM
BradH
I'm curious what people believe the specs are for the original A12 cam or the comparable 4-bbl version that supposedly was the same specs (other than the lobe taper). All I know for sure is one version of what looks like a repro cam is 214/225 @ .050", .449"/.464", 115 LSA. Has anyone measured the MP repro cam and can compare it with those #s? Also, if you contacted the tech people for the Pure Stock Muscle Car Drags and asked them what the original cam specs are for the purpose of Certification, what would they say? ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif)
[Re: RoadRunnerJD]
#32600
12/26/06 12:15 PM
12/26/06 12:15 PM
Posts: 5,160 Texas
dannysbee
Texas
I believe forged pistons and more cam were on the drawing board for the A12 cars but I was under the impression neither made production. JD I would be courious as to the spec's of your cam, please let us know.
Getting old just means you were smarter than some and luckier than others.
[Re: BradH]
#32602
12/26/06 11:33 PM
12/26/06 11:33 PM
fast68plymouth
So. Burlington, Vt.
sounds like JD needs to get his OE cam over to Brad so he can put it in a block and measure it up.
[Re: fast68plymouth]
#32603
12/28/06 03:49 PM
12/28/06 03:49 PM
BradH
Yep... 'cept I need to have a block w/a crank in it where I can actually measure it. But the measuring part is a "no brainer".
Here's some other stuff to on the original A12 camshaft... seems like the factory couldn't quite decide what to tell people when the cars were introduced. Here are a bunch of quotes from various "at the time" articles linked from the A12 Registry, including the links to the articles themselves, plus some of Ro McGonegal's after-the-fact comments published many years later:
http://sixpacksixbbl.homestead.com/a12roadtestspage3.html "Compression is a moderate 10.0:1... Intake... 268 duration, Exhaust... duration is 284... Lift is .450"-inch on the intake and .465-inch on the exhaust."
http://sixpacksixbbl.homestead.com/a12roadtestpage2.html "Compression ratio... 10.5-to-1 Camshaft... Hydraulic, .450-465-inch lift"
http://sixpacksixbbl.homestead.com/a12roadtestspage6.html "Compression ratio... 10.1:1 cam timing... duration, int.exh.... 268/284"
http://www.homestead.com/sixpacksixbbl/a12roadtestspage7.html Plymouth's original 440 Six BBL Road Runner ad: "Special low-taper 276-292-54 camshaft..."
http://sixpacksixbbl.homestead.com/a12roadtestspage8.html "Cam Duration... Intake 276... Exhaust 292... Overlap 54 Lift at 0-in. Lash... Intake .450 in.... Exhaust .465 in."
http://www.homestead.com/sixpacksixbbl/a12roadtestspage10.html "The camshaft intake side has 276* duration and .450" lift. The exhaust side uses 292* duration at a higher .465" lift. Overlap is 54*."
http://www.homestead.com/sixpacksixbbl/a12roadtestspage11.html Ro McGonegal's comments a couple of decades after the Cecil County test: "The production cam had 268/284-degrees duration, .450/.465-inch lift and 46 degrees of overlap, but the one in our mule kicked a little harder. This cam was reportedly phased with stock lift, 276/292 degrees of intake and exhaust duration, and 54 degrees of overlap. We suspect, too, that the 10.5:1 forged pistons originally proposed for this limited-production 440 were inside the engine of our special test car. Though early print ads specified the higher-than-standard compression ratio, the naked truth was cast-aluminum pistons and a nominal static compression ratio of 10.1:1."
[Re: BradH]
#32604
12/28/06 05:55 PM
12/28/06 05:55 PM
BradH
... one version of what looks like a repro cam is 214/225 @ .050", .449"/.464", 115 LSA. Has anyone measured the MP repro cam and can compare it with those #s?
I bring this up, again, because I found an article in an older issue of Mopar Muscle where Bob K. discussed the details of both his Super Bee and his Hemi 'Cuda. In it he mentioned the MP repro cam, but said the duration at .050" #s were 208/220, which is smaller than I expected. ![](/ubbthreads/images/graemlins/confused.gif)
[Re: BradH]
#32605
12/29/06 12:26 PM
12/29/06 12:26 PM
BradH
RoadRunnerJD and I will be making arrangements to measure his OEM A12 cam at some point to have a legit point of reference from which to compare other cam options. I can't say how soon we'll get this done, but it will happen. BTW, the cam I had ground for my A12 RR, what I refer to as the "Mr. Snack Pack" grind" ![](/ubbthreads/images/graemlins/laugh2.gif) is... Adv duration - 272/280 .050" duration - 223/232 Lift (1.5) - .503"/.513" LSA - 115 The intended use is a for 9.5:1 CR, 906 heads w/ stock-size valves and some bowl porting, OEM exhaust manifolds, a high-flow replacement 2.5" exhaust system, 4.10 gears, 4-speed, and a custom-curved distributor from FBO. If I was running an automatic instead of a 4-speed, I'd either drop the duration down a size on both intake & exhaust, or have the same lobes ground on a tighter LSA... maybe 112-113.
[Re: BradH]
#32606
12/29/06 04:23 PM
12/29/06 04:23 PM
Posts: 5,160 Texas
dannysbee
Texas
Brad I used a Hughes 223-230 504I 515E with good results. It seemed to be a good exhaust manifold cam as it pushed a 3860 lbs Bee 110+ in the quarter with a cast iron intake and AVS carb. With 451 cubic inches you could hear the cam in the exhaust just slightly.
[Re: BradH]
#32611
06/10/09 11:32 AM
06/10/09 11:32 AM
Posts: 15,134 Kelowna, B.C. Canada
DPelletier
Holy crap; another TFTD (Thread From The Dead)! ![](/ubbthreads/images/graemlins/laugh2.gif) ....It's even got B body Bob in it! Dave
1970 Super Bee 440 Six Pack
1974 'Cuda
2008 Ram 3500 Diesel
2006 Ram 3500 Diesel
2004.5 Ram 2500 Diesel
2003 Ram 3500 Diesel
2006 Durango Limited
[url] http://1970superbee.piczo.com [/url]
[Re: DPelletier]
#32612
06/10/09 12:40 PM
06/10/09 12:40 PM
Posts: 3,905 Minnesota
3twos
Minnesota
Does anyone know approximtely how much manifold vacumn you will have with this cam?
Al & Sheila
[Re: PJ68RT]
#32615
06/10/09 01:53 PM
06/10/09 01:53 PM
BradH
Thanks for the info BradH. Interesting seat-to-seat numbers for the duration.
It's virtually identical to the Speed Pro CS661, which specs out as adv. duration 292 intake/ 309 exhaust, duration @ .050 of 214 intake and 225 exhaust, Vavle lift of .449 intake and .464 exhaust, Lobe C/L is 115. Erson also has one that's virtually the same w/ the exception of a 1-degree tighter LSA, IIRC.
[Re: sg333e]
#32617
04/25/12 04:36 AM
04/25/12 04:36 AM
Posts: 466 Keminmaa
ArcticCuda
Keminmaa
Blast from the past...
Are these cams still available?
1970 Plymouth GTX 440-6 1970 Plymouth PPR Cuda 489-4 1971 Plymouth Duster Bad Romance 408-W2-8bbl
