Re: Ultra low sulfur diesel question. [Re: 69 Road Runner] #325908
05/25/09 11:00 AM
05/25/09 11:00 AM
Mopar Lane,Mississippi
67HEMI Offline
67HEMI  Offline
All on highway diesel is ULSD now. I am selfemployed and work on Cummins and Pwrstrokes. All of my customers have started using Diesel Kleen by Power Service. You can buy it at Advanced,Autozone etc. It comes in a silver quart bottle that is around 8.00.It has a lubricant in it called slick diesel and also raises the Cetaine value as much as 6 points(like octane in gasoline). All of my customers have picked up from 1 to 2 miles per gallon by using it.If your tank is around 35 gallons pour 1/2 quart in it everytime you fill up. The lubrication alone is worth the extra 4.00 per fillup plus the added fuel mileage. Since ULSD has come on the market I have been swamped with injector wear and failures in powerstrokes and lift pump/injection pump failures in cummins.Not to mention fuel leaks caused by oring deteriation from the low sulfur.
'33 Plymouth 5 Window Coupe Blown Aluminum HEMI w/bolt ons (under construction) '69 Chrysler 300 Convertible 375 HP 440 '71 Plymouth Duster 360 W/EFI (Wife's Ride) '12 Ram MegaCab Dually 6.7 Cummins
Re: Ultra low sulfur diesel question. [Re: 67HEMI] #325909
05/25/09 12:48 PM
05/25/09 12:48 PM
Not2farfromNashville, TN
Rug_Trucker Offline
Rug_Trucker  Offline
Pouring in ATF will help lubricity? I have a bunch of Honda fluid. Lots of Honda gear lube too.
Running untaxed diesel is hazardous to your wallet if the DOT dips your tank!
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
Re: Ultra low sulfur diesel question. [Re: 67HEMI] #325910
05/25/09 12:58 PM
05/25/09 12:58 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
That has been my impression, but I haven't been everywhere to know for sure. ULSD was in the ground here at least 12 months before it was law. It was all you could get, clear(taxed)diesel for at least a year before like I said.
