Re: Progress update [Re: BloFish] #3258861
09/19/24 03:45 PM
09/19/24 03:45 PM
Loudoun County, VA
Brad_Haak Offline OP
Loudoun County, VA
Picked it up this morning from the shop that did the front-end alignment, filled the tank, and proceeded to burn off 1/2 tank of fuel driving "here and there" getting used the car again. In no particular order...
- Loud... wow, this thing is loud... as in my oldest son who drives a WRX asked if it has any mufflers, to which I replied "Two"... and his response was "It needs two more"
- Good thing I have fairly strong legs (not counting my ACL injuries) cuz these manual disc / drum brakes need serious pedal pressure to slow the pig down... nothing different than before, but today was a reminder of what the old car is really like to drive
- Steers like a barge, but at least it goes straight at speed... typical Mopar manual steering box w/ that has an "always loose" feel
- Mechanical oil pressure gauge is very sensitive, but also seems to fluctuate significantly even at steady throttle; under WOT it doesn't exactly "drop", but it sure does move all over the place
- Cold oil pressure is 60-80 PSI, but hot oil pressure is 25 PSI at 1200 RPM idle and 50-ish at 3000+ cruise RPM
- On the engine dyno it was a steady 60+ at WOT, but I'm not sure what it has at high RPM under load in the car... may need to see if I can video something while I'm driving
- The weather has been in the low 80s today; during the drive the water temp was generally 180-190* and the oil temp was close to the same, although way slower to warm up; I thought I put a 160 'stat in it, but it runs like it has a 180 instead
- 15 year-old M/T ET Street Radials don't hook for sh!t... and don't even squeal when they spin... but they still smoke
- We swapped to a new Mallory 140 dead-head pump cuz I remembered the old Mallory 140 was making some serious noise when it got hot before the car was taken off the road... but the new pump started howling like a kicked kitty after going thru stop and go traffic where the pump wasn't getting any airflow to cool it... not confidence inspiring, as in I'm thinking I should keep the old one in the car along w/ tools needed to make a roadside pump swap "just in case" it locks up
- Even though I added a .140" front clutch passage restrictor when the trans was out, the 2-3 shift is still pretty harsh at less than about 4K RPM under acceleration... not much difference IIRC
- The Dynamic 9.5" converter is still the one spec'd out for the car when it was about 100 HP slower... and I'm thinking it may not work well for the new engine... will be curious what the flash stall and slippage are when it goes back to the track, cuz it feels kind a "slushy" to me now
- Doesn't feel that fast, but getting into it on the street with limited traction isn't a great indicator of how strong it really is, nor was there an opportunity to run it up thru the gears anywhere
- Won't idle consistently... tried to set it for about 1200, which it will do sometimes while other times it keeps dropping below 1000 and I have to keep blipping the throttle to keep it from dying
- Shifter linkage needs to be readjusted cuz I noticed when I pulled into my driveway after the test drive that it won't engage cleanly in Park now
Probably post more later, but that's what's going thru my head right now work
2021 Challenger 6.4L Scat Pack 1320
100% stock: 1.680, 11.894 at 113.75 (DA 175 ft)
weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008]
pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
Re: Progress update [Re: Brad_Haak] #3258865
09/19/24 04:05 PM
09/19/24 04:05 PM
AndyF Offline
AndyF  Offline
Yep, that is exactly what an old muscle car feels like after driving some modern muscle for a few years!
If you are willing to put more money into the car I'd suggest switching over to a Holley Sniper. A high pressure fuel pump inside the gas tank is quiet and it stays col. You won't have any vapor lock problems with high pressure fuel lines, the digital timing control will give you start retard, vacuum advance for freeway driving, rev limiter, adjustable timing curves, etc., plus you'll gain an onboard data logger which will be useful for problem solving.
EFI is main upgrade that keeps my old car drivable. That and power steering. I added a PS setup to my Coronet and it solved a bunch of the issues that I had with steering effort as well as driving comfort.
Re: Progress update [Re: AndyF] #3258872
09/19/24 04:53 PM
09/19/24 04:53 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
Brad ,
same oil pressure as mine .
Pedal pressure well you can fit a smaller diameter master .
More ya drive it the better it gets .
Glad its out and about .
Tex
New best ET 10.259@129.65 .
New best MPH 130.94
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: Progress update [Re: tex013] #3258914
09/19/24 07:33 PM
09/19/24 07:33 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
It takes a while to get them dialed. I drove mine to work 3 days last week before we took it to the track Friday night and it was really enjoyable.
You've cleared that initial big hurdle, though!
'63 Dodge 330
11.19 @ 121 mph
9.92 @ 135mph with a 350 shot of nitrous and 93 octane pump. 1.43 60 ft. 3,750 lbs.
Re: Progress update [Re: GY3] #3259015
09/20/24 11:33 AM
09/20/24 11:33 AM
Loudoun County, VA
Loudoun County, VA
Yeah, gonna take some more hammer & wrench to get it dialed in, for sure
A couple of "beauty shots" I took while letting the fuel pump cool down a bit. Amazing how photos can "fix" all the paint & body issues which are so obvious up close in person. rolleyes
Screenshot 2024-09-20 at 12.27.08 PM.pngScreenshot 2024-09-20 at 12.26.46 PM.png
Re: Progress update [Re: Brad_Haak] #3259085
09/20/24 07:28 PM
09/20/24 07:28 PM
Mo.
racerx Offline
racerx  Offline
Mo.
Was this taken at 20' scope laugh2
Re: Progress update [Re: Brad_Haak] #3259118
09/21/24 12:57 AM
09/21/24 12:57 AM
AndyF Offline
AndyF  Offline
Has a serious "street racer" vibe to it. Looks mean.
Re: Progress update [Re: AndyF] #3259121
09/21/24 02:32 AM
09/21/24 02:32 AM
Brisbane Australia
572B1 Offline
572B1  Offline
Brisbane Australia
Looks great Brad.
Re: Progress update [Re: AndyF] #3259241
09/21/24 07:07 PM
09/21/24 07:07 PM
Loudoun County, VA
Loudoun County, VA
smoke
Re: Progress update [Re: 572B1] #3259297
09/22/24 08:03 AM
09/22/24 08:03 AM
Loudoun County, VA
Loudoun County, VA
So... on Thursday's test drive there was one "interesting" moment wink
I pulled onto a section of the Loudoun County Parkway just past the Washington Commanders practice field... no significant traffic behind me... clear road ahead of me... and drive thru the gears -- lots of tire spin -- up to about 90 MPH... and when I let out of it I saw a little farther up the road was a LC Sheriff's motorcycle officer setting up a radar trap... $hit eek
Backed out of it and braked hard to scrub off speed... in my head I'm already rehearsing the "Yes, Officer, I am aware the posted speed limit is 45 MPH... "
Fully expected to get waived over, or flashing lights, or something... but he was still getting set up and didn't bother... no way he didn't hear me... guess Christmas came early for me this year luck
Re: Progress update [Re: Brad_Haak] #3259308
09/22/24 08:42 AM
09/22/24 08:42 AM
MD
RTSE4ME Online content
RTSE4ME  Online Content
MD
I drive Loudoun County Parkway when I go into the office(rarely). I always see cops on Loudoun County Parkway.
Sounds like you are almost ready to hit the track. Car looks great!
Re: Progress update [Re: Brad_Haak] #3259373
09/22/24 03:15 PM
09/22/24 03:15 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Great to hear it’s on the road again!! up
Re: Progress update [Re: fast68plymouth] #3260159
09/26/24 08:35 AM
09/26/24 08:35 AM
Plymouth, MI
Blusmbl Offline
Blusmbl  Offline
Plymouth, MI
Awesome. You may call it a 20 footer but it really looks great and presentable in the photos. The list to iron out seems pretty minor, gonna attempt to get it to the track this year?
Re: Progress update [Re: Blusmbl] #3260191
09/26/24 10:59 AM
09/26/24 10:59 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Looking good keep plugging away. Next spring will be here before you know it.
Re: Progress update [Re: Al_Alguire] #3260391
09/27/24 10:22 AM
09/27/24 10:22 AM
moparx Offline
moparx  Offline
years ago, my best friend made the comment : "did ya ever notice it's friday AGAIN already ?"
and guess what ? it's FRIDAY AGAIN ALREADY ? panic biggrin
i could kick his a$$ every time he says that ! .............. [provided i could reach that high. laugh2]
beer
Re: Progress update [Re: Al_Alguire] #3260879
09/30/24 10:40 AM
09/30/24 10:40 AM
Loudoun County, VA
Loudoun County, VA
There "should" be an opportunity or two to get to the track before everything closes this fall as long as I can finish off a few things. However, if it doesn't stop raining around here, I'll have to switch to drag-racing Jet Ski's to get any track time.
