Re: Neutral Safety Switch issues??
[Re: MI_Custumz]
#3259287
09/22/24 06:32 AM
09/22/24 06:32 AM
Posts: 6,519 ohio
ruderunner
ohio
Ammeter wires are disconnected under the hood.
____ ok good.
I will keep investigating for sure. I realize every little bit of voltage drop adds up and want to fix it fully. But if it comes time for storage for winter, I may have to take (as we say at work) a tactical pause.
____ everyone has priorities.
Thanks for explaining the fusible link.
A coworker mentioned putting an inline fuse instead of a fusible link. I'm not so sure about that.
____ You're correct to be skeptical. While both fuses and links are for circuit protection, they operate very differently and serve different purposes. A fuse is designed to blow if there's any overloading of a circuit. A link is designed to carry current until an overloading situation lasts too long. Basically a very slow blow fuse.
But what amp fuse would be suitable if that's a viable route? I can only cut so much more off the positive cable pigtail before I run out of wire if it blows the fusible link and needs another one added.
____ not a big deal. You can crimp a terminal to the wire and attach it to the bolt on the clamp. Note also that the link can attach either to the battery or the junction, as long as it's between those 2 points it doesn't really matter.
Hoping the fusible link will be good since they had one in the ammeter wiring and it never blew from what I can tell, but will check those when I inspect the wires when I pull them all the way out. A little elaboration on the difference between a fuse and a link. After starting a car, the battery has suffered a significant drain and needs to be recharged. Once running the vehicle makes that a priority and the charging system starts pumping electrons into the battery. This could flow at a rate exceeding 40 amps. Technically a 10ga wire is only good for 30. A correctly sized fuse for 10ga is 30 amps. The fuse will blow almost immediately and you get no charging. A link will handle the overloading for a few minutes and that's OK since the wire isn't suffering a direct short to ground. The overloading takes a couple minutes to heat the wire to the point of failure. By then the charging system has settled down, as the rate of charging falls off the closer to full charge you get. Say after 30 seconds, you're only pumping 20 amps to the battery, after a minute it might be 10 etc. The battery has been topped off and the world is a happy place. Neither the charging wire nor the link have suffered. NOTE the above numbers are only for illustration. It's too early to do the math.
Angry white pureblood male
[Re: MI_Custumz]
#3259654
09/23/24 04:57 PM
09/23/24 04:57 PM
Posts: 6,519 ohio
ruderunner
ohio
You can just put a longer bolt on the top style clamp. I recommend stainless.
And, for side terminal, I use 3/8 coarse thread bolts and nuts. Thread the bolt all the way in by hand, then tighten the nut down on the cable.
[Re: ruderunner]
#3259762
09/24/24 10:21 AM
09/24/24 10:21 AM
Posts: 20,740 north of coder
moparx
And, for side terminal, I use 3/8 coarse thread bolts and nuts. Thread the bolt all the way in by hand, then tighten the nut down on the cable. when using side terminal batteries, i like to use a stainless stud, [allen set screw] and a stainless nut, slathering the set screw with copper high temperature anti-seize. using the set screw allows the use of the proper size allen hex key [cut down in length on the short side if needed for clearance] to hold the stud from turning, while the nut is loosened. use of the anti-seize is necessary to prevent the stainless threads from galling, thus preventing the nut and stud from coming apart cleanly when necessary.
[Re: MI_Custumz]
#3259843
09/24/24 05:54 PM
09/24/24 05:54 PM
Posts: 6,519 ohio
ruderunner
ohio
I added those notes to my sheet I have saved with other notes. Good info to know. Thanks.
I was able to test a few things tonight.
Voltage drop test
Junction block left (fusible link) key on run 13mV and cranking 50mV
Junction block right (main harness power) key on run 14mV and cranking 50mV
____ dramatic improvements there. Good!
Solenoid 1269mV with test lead from battery positive to wire ran to solenoid
____ still sketchy here.
Solenoid 9.55V when cranking
NSS in 549mV when cranking
____ indicates problem between battery and nss
NSS out 578mV when cranking
____ negligible drop through switch. Good.
Tested with ground for voltage
Ignition tab in fuse box is 12.21V
Battery was 12.3V
____ battery needs charged.
Looks like I picked up voltage to the ignition tab as well. I will remove the wiring that was going to the ammeter at a later date and check it for any issues. It is still under the hood, but disconnected and secured.
_____ it seems you're losing voltage to the solenoid and about half of the drop is before the NSS and half after. 1269-578=about 600. Power gets to the NSS through the bulkhead. Power gets to the solenoid through the bulkhead. I'd be looking really closely at that.
[Re: MI_Custumz]
#3259846
09/24/24 06:03 PM
09/24/24 06:03 PM
Posts: 6,519 ohio
ruderunner
ohio
Was thinking today about voltage drop. When the car wouldn't start with either the key or bypass it was obviously because it wasn't getting enough voltage to the solenoid. It would start when jumped with cables or the plug in charger/jumper at home every time and most times with the jump box. I am guessing the jumper cables (14.5V or so from the other car) and the plug in charger/jumper would put out at least that so with voltage drop, it was enough to the solenoid. If the jump box puts out the same as a battery (12.6V or so) it would work sometimes like the battery. I see now how the voltage drop can really mess with you. In theory, if I put a jumper wire from the battery and touch it to the wire inside the car that goes to the solenoid, it would work every time as it is direct voltage. I'm not going to do anything crazy with wiring, but was just thinking and wanted to make sure I was absorbing the concepts. I have not paid attention if it fires right back up when shut off with the key since the battery voltage is slightly higher at that point versus when it's been sitting for a few days and at "rest". You haven't sunk the battleship yet, but you're finding more of the fleet. That's exactly what was happening, the solenoid wasn't getting enough juice to engage. The PO installed push button was able to provide a bit more juice than the factory wiring but still not enough. This plug in jumper box, plugs into the lighter? If so, it probably bypassed whatever is ailing the wiring. Powering the solenoid directly from the battery will work. It basically bypassing all the factory stuff. People do stuff like this all the time but often spend more time and energy than a proper fix.
[Re: MI_Custumz]
#3260064
09/25/24 04:39 PM
09/25/24 04:39 PM
Posts: 6,519 ohio
ruderunner
ohio
Ok, u said plug in jumper box and I was thinking one of the newfangled ones that plug into a lighter socket. Either way, it gives enough bump to system voltage to overcome the drop to the solenoid.
Assuming you're test wire is large enough gauge, you can use it as a bypass. I think you said it was 10, that's plenty big.
[Re: MI_Custumz]
#3260282
09/26/24 05:09 PM
09/26/24 05:09 PM
Posts: 6,519 ohio
ruderunner
ohio
Considering how much shorter the run is, 12 should work ok.
[Re: MI_Custumz]
#3261308
10/01/24 06:20 PM
10/01/24 06:20 PM
Posts: 6,519 ohio
ruderunner
ohio
Is the car inaccessible?
I'm just thinking you could disassemble the bulkhead connector for inspection. No need to start it, just taking things apart and looking for burnt terminals or cooked wires.
Or previous owner modified wiring.
