push button transmission #3257275
09/11/24 08:02 PM
09/11/24 08:02 PM
Shelby, Ohio
2
2abodymcodes Offline OP
Shelby, Ohio
Is there a company that one can send the automatic push button controls out to get it restored?
Re: push button transmission [Re: 2abodymcodes] #3257279
09/11/24 08:21 PM
09/11/24 08:21 PM
A727Tflite Offline
A727Tflite  Offline
I have never seen a reason to do much more than stick the control unit in Evaporust, clean and then lube the unit up.
If the unit worked ok in your car this is usually all that is needed. There are a few adjustments for park and such on the unit but that’s all in the service manual and rarely have to be messed with.
If you need the adjustment procedure for the quadrant I can send them to you.
Re: push button transmission [Re: A727Tflite] #3257413
09/12/24 02:00 PM
09/12/24 02:00 PM
Shelby, Ohio
2
Shelby, Ohio
Mine needs totally restored. The lenses are broke and letters are gone.
Re: push button transmission [Re: 2abodymcodes] #3257486
09/12/24 08:56 PM
09/12/24 08:56 PM
The buttons vary for year and brand, they are not all the same. Which year and vehicle body style do you need them for?
Re: push button transmission [Re: 2abodymcodes] #3257620
09/13/24 02:30 PM
09/13/24 02:30 PM
A727Tflite Offline
A727Tflite  Offline
So you need the buttons and dash lens, not the quadrant restored?
Post the year you need.
Re: push button transmission [Re: 2abodymcodes] #3257761
09/14/24 01:23 PM
09/14/24 01:23 PM
Rio Linda, CA
John_Kunkel Offline
The Erection Connection
John_Kunkel  Offline
Rio Linda, CA
Over on the forward look forum, there was as guy making some new buttons with a 3D printer.
http://www.forwardlook.net/forums/category-view.asp
