71 Charger $1800 #3257681
09/14/24 12:23 AM
09/14/24 12:23 AM
Colorado
dssaa Offline OP
dssaa  Offline OP
Colorado
https://www.facebook.com/marketplace/item/519342523904271
Saw this on FB awhile ago, price keeps dropping. I know its rough...but if it comes with the custom hood holder downer? Gotta be worth $1800 right?
Re: 71 Charger $1800 [Re: dssaa] #3257693
09/14/24 06:53 AM
09/14/24 06:53 AM
new berlin wisconsin
Mr T2U Offline
Mr T2U  Offline
for someone in the rust belt it looks to be a solid enough car to build the way you want. pics show rust in lower 1/4 but the rest seems solid. close inspection would be required before purchase.
it might be a small $$ maker parting it out. the interior color kills parts value for most. it does have the desired hidden headlights.
the hood closed holder is required because the hood is not bolted on. i see hood hinges with springs on them yet the hinges are down. i don't remember seeing that before.
perception is 90% of reality
Re: 71 Charger $1800 [Re: Mr T2U] #3257695
09/14/24 07:01 AM
09/14/24 07:01 AM
Central Michigan
N
nuthinbutmopar Offline
N
Central Michigan
I always thought putting the hinges down after removing the hood for easier access was standard procedure, I've been doing it that way for 40 years. Just be careful putting them back UP to reinstall the hood, there's a TON of tension there...
Re: 71 Charger $1800 [Re: nuthinbutmopar] #3257737
09/14/24 11:21 AM
09/14/24 11:21 AM
RI Deep in the rust belt
chargervert Offline
chargervert  Offline
The grille is worth a grand by itself. I gave away a 71 Charger with a running 318 engine and working trans in it last weekend. I would rather see someone do something with it,than cut up another one for parts.
70 Charger R/T SE 472 Hemi 70 Charger R/T convertible 70 Charger R/T V Code Sixpack 69 Charger R/T SE Sunroofcar 68 Charger 383 68 Charger 318 71 Charger R/T 70 Challenger convertible 71 Challenger convertible 71 Cuda 340 09 Challenger R/T Classic
Re: 71 Charger $1800 [Re: chargervert] #3257790
09/14/24 04:14 PM
09/14/24 04:14 PM
Mr T2U Offline
Mr T2U  Offline
after looking at the pics again.
i see the special SE chrome trim on the back of the hood and fenders is still there. the special A/C heater control valve is there also along with a few A/C lines.
it has to be a low option SE. it has A/C yet it has manual brakes and hand cranked windows.
