interesting video on the projector headlights.
as my 1933 dodge "humpback" panel project will utilize an unknown make of old, 10" bulb/reflector/fluted glass lens headlights, i an planning to modify the reflector part to accept a modern style headlight bulb socket.
these headlights will also be installed low, on the center line of the front spindle/wheel assembly.
with that said, i know this low placement is far from anything of an ideal headlight location for the best lighting possible, but it will be done just for "character purposes" of the truck. this will be more in line with a fog light location of most modern vehicles.
the truck will see very limited night driving, if any, but after seeing the video, i an unsure just what kind of bulb to install in the original big light's reflector, as the reflector is entirely smooth.
i guess i will have to experiment with different bulb types to see what will work the best with what i'm going to use as headlights. hopefully, the original bulb socket hole will be big enough to allow several possibilities of bulb selection to be tried.
