Re: Maximum Compression ratio [Re: Al_Alguire] #3258012
09/15/24 06:52 PM
09/15/24 06:52 PM
Melbourne , Australia
LA360 Offline
LA360  Offline
17-18:1 is pretty common on smaller comp eliminator engines
From memory, Pro Stock engines are supposed to be around 15-16:1
Alan Jones
Re: Maximum Compression ratio [Re: LA360] #3258037
09/15/24 08:58 PM
09/15/24 08:58 PM
gregsdart Offline
gregsdart  Offline
These are the pistons in my 982 hp, 572-13 headed 549. Best timing is 34.5 degrees, methanol fuel. 4.50 bore, 4.315 stroke. The dome was custom designed at Diamond pistons. Compression ratio 15.25. Max power at 7600 rpm
8.582, 160.18 mph best, 2905 lbs 549, indy 572-13, alky
Re: Maximum Compression ratio [Re: gregsdart] #3258047
09/15/24 09:29 PM
09/15/24 09:29 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
A pic of my non fancy 15-1 piston. Rounded the sharp edges and deburred.Doug
Re: Maximum Compression ratio [Re: dvw] #3258247
09/16/24 06:19 PM
09/16/24 06:19 PM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
A long time ago we had a 16.5 to 1 small block Mopar.
It ran great but it split the cylinder walls on two poured, but stock blocks.
The most I have since been able to get out of R3W9 engines has been about 13 to 1.
Much larger cams that require much larger valve reliefs.
