Best New Fuel Tank For 1971 Charger?
#3257084
09/10/24 11:20 PM
09/10/24 11:20 PM
Posts: 8,451 Highland, MI.
Sunroofcuda
Highland, MI.
Who makes the best tank? Best price?
Re: Best New Fuel Tank For 1971 Charger?
[Re: Ramrod39]
#3257093
09/10/24 11:54 PM
09/10/24 11:54 PM
Sunroofcuda
Highland, MI.
All they have for a '71 B-Body is a fuel injection tank.
[Re: Sunroofcuda]
#3257102
09/11/24 12:43 AM
09/11/24 12:43 AM
Posts: 305 NW Illinois
MoonshineMattK
NW Illinois
All they have for a '71 B-Body is a fuel injection tank. Call them. All their fuel tanks are built the same. There is a different sender that goes in place of the fuel injection pump/sending unit if you are using a standard mechanical fuel pump or an external electric pump. They are friendly and will get you the correct sender and fuel level sensor.
[Re: Sunroofcuda]
#3257112
09/11/24 05:38 AM
09/11/24 05:38 AM
Posts: 4,824 Holland MI Ottawa
2boltmain
Holland MI Ottawa
Rock Auto lists the usual but also a stainless-steel tank. https://www.rockauto.com/en/catalog/dodge,1971,charger,7.2l+440cid+v8,1079265,fuel+&+air,fuel+tank,6268
Keep old mopars alive.
[Re: 2boltmain]
#3257125
09/11/24 08:39 AM
09/11/24 08:39 AM
Sunroofcuda
Highland, MI.
I don't need to get fancy with a $400.00 stainless tank, but Dorman & a couple other galvanized tanks are listed. I always thought AMD was the standard for sheetmetal & tanks with our old stuff?? I need to know what fits & functions the best here - & doesn't leak. I've heard of some reproduction tanks leaking.
[Re: MoonshineMattK]
#3257307
09/11/24 11:50 PM
09/11/24 11:50 PM
Sunroofcuda
Highland, MI.
Thanks for the replies. I ordered a Spectra tank from Rock Auto today. I looked for a dealer on Spectra's website & called a parts store near me that I use, but they looked it up & said they couldn't get one from the local distributor. Spectra looks like good tanks - they are an OEM supplier.
[Re: Sunroofcuda]
#3257334
09/12/24 09:20 AM
09/12/24 09:20 AM
Posts: 2,375 Wheatfield, NY
Cuda340
Wheatfield, NY
Thanks for the replies. I ordered a Spectra tank from Rock Auto today. I looked for a dealer on Spectra's website & called a parts store near me that I use, but they looked it up & said they couldn't get one from the local distributor. Spectra looks like good tanks - they are an OEM supplier. You will be happy, they are good tanks.
[Re: Cuda340]
#3257359
09/12/24 11:30 AM
09/12/24 11:30 AM
Posts: 20,221 north of coder
moparx
several years ago, i replaced the original tank on my 69 charger. i was torn between a spectra tank from rock auto, and a stainless tank from van's auto. at that time, there was only a few dollars difference between the two tanks [$25-$30.00 ?], so i went with the stainless tank from van's. got a new stainless fill neck from them as well. the only issue i had was with the fill neck to tank grommet. i had several new ones on hand to choose from, including a couple of OEM mopar, generic replacements, and the one that came with the tank. the new mopar ones didn't fit the tank and fill neck together, although they fit each individually. i used one of the generic ones, as it seemed to fit the tank and fill neck the best, and luckily, there has been no leaks. [knock on wood. ]
