blue print 426" what do you think? #3255710
09/04/24 12:45 AM
09/04/24 12:45 AM
British Columbia
chrisf Offline OP
chrisf  Offline OP
British Columbia
would love to hear some opinions on the new-ish blue print engines 6.2 based 426 stroker w/ 3.0 whipple 872hp with a 30 month 50k warranty for 25k i know the initial sticker shock is a bit much but if the quality is there thats a way better option than a mopar crate engine.
would like to hear some thoughts.
https://blueprintengines.com/collections/chrysler-compatible-hemis-426-c-i/products/ps426sct
Re: blue print 426" what do you think? [Re: chrisf] #3255726
09/04/24 06:13 AM
09/04/24 06:13 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
No experience with them but they have a great reputation. That seems like a pretty good deal considering it comes with the fuel injection computer. I wonder if the ECU allows user input or if it is "locked" for warranty?
68 Barracuda Formula S 340
Re: blue print 426" what do you think? [Re: Bad340fish] #3255767
09/04/24 11:40 AM
09/04/24 11:40 AM
Bowling Green, KY
cudaboy Offline
cudaboy  Offline
Bowling Green, KY
I don’t think a Terminator can be locked.
Dennis
Re: blue print 426" what do you think? [Re: cudaboy] #3255826
09/04/24 04:00 PM
09/04/24 04:00 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Dennis
I wasn't sure. I would imagine they have something in place for the warranty that prevents the purchaser from adding a bunch of timing and melting it down, then crying warranty lol.
Re: blue print 426" what do you think? [Re: Bad340fish] #3256154
09/06/24 11:49 AM
09/06/24 11:49 AM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
I have seen a lot of issues with their engines. I had to redo one I put in a customer truck for high oil consumpition a couple times (5.7 eagle ) I had to fix a rear main seal leak on a 4.6 ferd right after installing it, on a 318magnum it was way down on power another shop had installed it and it had 4 valve relief pistons even farther down the hole than stock and thicker than stock head gaskets making for very low compression and the chinesium cam was severely retarded I don't know if it was the cam itself or the timing set or crank but I advanced it several degrees with an offset key and put in single layer steel shim head gaskets and it ran much better. The latest one I messed with was 4 years ago so maybe they have improved their quality...
Re: blue print 426" what do you think? [Re: HotRodDave] #3256241
09/06/24 03:47 PM
09/06/24 03:47 PM
British Columbia
chrisf Offline OP
chrisf  Offline OP
British Columbia
thanks Dave. good info to have. i guess i should just price everything out and see if there is any benefit to using their stuff. for the same money maybe i could get better parts as they dont list who's rotating assemby it is. i like the semi turn key idea and not trying to figure out computer stuff.
Re: blue print 426" what do you think? [Re: chrisf] #3256255
09/06/24 04:27 PM
09/06/24 04:27 PM
Wichita
GY3 Online content
GY3  Online Content
Wichita
I have a friend that parts out SRT8 and Hellcat stuff. He usually has engines/drivetrains in stock with some them low mileage.
'63 Dodge 330
11.19 @ 121 mph
9.92 @ 135mph with a 350 shot of nitrous and 93 octane pump. 1.43 60 ft. 3,750 lbs.
Re: blue print 426" what do you think? [Re: GY3] #3256283
09/06/24 06:33 PM
09/06/24 06:33 PM
BDW Offline
BDW  Offline
Some more details here:
https://moparconnectionmagazine.com...mpatible-engines-from-blueprint-engines/
The BluePrint Gen III engine is a significant advancement in the automotive business, matching the legendary Gen II 426 displacement. BluePrint Engines starts with a brand-new Hellcat block acquired from Stellantis. Each block is filled with a BluePrint rotating assembly, which includes a quality-designed forged crankshaft, rods, and pistons, creating a powerplant that revolutionizes the industry. Each Gen III Hemi-compatible engine built is a testament to BluePrint’s commitment to quality
Re: blue print 426" what do you think? [Re: chrisf] #3256346
09/07/24 06:13 AM
09/07/24 06:13 AM
Greenville, PA
redraptor Offline
redraptor  Offline
Greenville, PA
For the same money.
https://clevelandpap.com/worlds-first-hellcat-turnkey-pallet/
Re: blue print 426" what do you think? [Re: redraptor] #3256368
09/07/24 10:26 AM
09/07/24 10:26 AM
British Columbia
chrisf Offline OP
chrisf  Offline OP
British Columbia
For the same money.
i can buy insurance stuff locally if i wanted to go that route. i dont want 707hp i want more. a 2019 hellcat just sold a couple days ago here for 32g (canadian peso's) (24k US) so part out what you dont need and it would be an ok deal but still a used motor that ran into a tree.
Re: blue print 426" what do you think? [Re: chrisf] #3256706
09/09/24 02:09 AM
09/09/24 02:09 AM
Will your car handle that much torque and power? work work
Re: blue print 426" what do you think? [Re: chrisf] #3256751
09/09/24 11:19 AM
09/09/24 11:19 AM
Wichita
GY3 Online content
GY3  Online Content
Wichita
For the same money.
He had a Redeye with computer, trans and everything for $15k.
'63 Dodge 330
11.19 @ 121 mph
Re: blue print 426" what do you think? [Re: GY3] #3257092
09/10/24 11:53 PM
09/10/24 11:53 PM
Nor here, Nor there
Dart 500 Offline
Dart 500  Offline
Nor here, Nor there
You could build it yourself or gather all the parts yourself and have a local engine builder assemble it for less. Its just a stock BGE block + 392 heads and the 4" stroker crank + the blower. The 2017+ 392's also used the BGE/Hellcat block, so get one of those and start there
Re: blue print 426" what do you think? [Re: chrisf] #3257335
09/12/24 09:22 AM
09/12/24 09:22 AM
Quakertown PA
Tay Offline
Tay  Offline
Quakertown PA
I can say this, We've used a few of their Ford 427 SBF long blocks , and they were spot on .
