Door mirror joystick hole location #3256619
09/08/24 02:22 PM
09/08/24 02:22 PM
montreal,quebec,canada
buzz440 Offline OP
buzz440  Offline OP
Hi all, I have a 69 Superbee and installed a remote driver door mirror ( with the joystick control lever) now the car had the standard (manual) mirror when I bought the car. I need to make/drill the hole in the inner door panel for the joystick.... can someone please give me the location either by picture or measurement or both as to where I need to make this hole. Thanks in advance.
Later, BUZZ
Re: Door mirror joystick hole location [Re: buzz440] #3256676
09/08/24 08:52 PM
09/08/24 08:52 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
From a quick Google search:
https://www.forbbodiesonly.com/moparforum/threads/remote-mirror-location-69-roadrunner.87282/
Images show centerline of hole 2 5/8" from top of door, and 4 1/2 " rearward of the pivot for vent wing lever.
A different reply said 2 1/4" above door trim retainer molding, and 4" forward of the small adjustment hole.
Re: Door mirror joystick hole location [Re: topside] #3256689
09/08/24 09:59 PM
09/08/24 09:59 PM
buzz440 Offline OP
buzz440  Offline OP
Well, Thank-you very much for the pics. that's exactly what I needed.
Later, BUZZ
