E brake spring inside housing ? #3255594
09/03/24 03:16 PM
09/03/24 03:16 PM
NORTHERN VA
THESHAKERPROJECT Offline OP
NORTHERN VA
1969 A12 CAR missing a spring inside the e brake housing ( not the pull release rod spring ) does anyone have a pick of the spring so I can search a replacement ?? Thanks !!
Re: E brake spring inside housing ? [Re: THESHAKERPROJECT] #3255642
09/03/24 06:53 PM
09/03/24 06:53 PM
NORTHERN VA
NORTHERN VA
........I found it MOPAR part number 1556693 spring. I saw it available at MEGA PARTS .
Re: E brake spring inside housing ? [Re: THESHAKERPROJECT] #3256000
09/05/24 03:32 PM
09/05/24 03:32 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Hmmm, is that in the e-brake pedal assy ?? I was just installing mine today and thinking a spring must be missing because the pedal doesn't stay all the way up.
Re: E brake spring inside housing ? [Re: Stanton] #3256161
09/06/24 12:07 PM
09/06/24 12:07 PM
moparx Offline
moparx  Offline
i had trouble getting my e-brake working correctly on my 69 charger when i installed replacement cables because the originals were completely rust frozen due to not being used.
as it turned out, i had to add a small section of spring to the driver's side cable where it is inside the drum, attached to the apply lever.
also, i had to re-rout the passenger side cable because routed in the factory location, it bound up and wouldn't release.
and finally, as a "help", i installed a return spring at the cable mounting point on the driver's side frame rail, which attaches to the main cable bracket that hooks both cables together at the adjustment screw end of the main cable.
the e-brake works as it should now, smooth to apply and release, as well as holding the car stationary on a sloped surface without being in park.
dorman was the cable brand i used, so i don't know if my "fixes" only apply to this brand or not.
just my personal life experience fixing my e-brake.
your mileage will vary.
beer
