Re: Standard vs. metric thread question
[Re: A12]
#3255259
09/02/24 01:41 AM
09/02/24 01:41 AM
Posts: 20,326 Park Forest, IL
slantzilla
Park Forest, IL
Loctite the adapter into the ball and use a thin locknut on the handle.
[Re: earlymopar]
#3255285
09/02/24 08:27 AM
09/02/24 08:27 AM
Posts: 6,224 ohio
ruderunner
ohio
This.
But, you'd think a knobs made for a shifter would have the correct threads to begin with.
Angry white pureblood male
[Re: ruderunner]
#3255289
09/02/24 09:11 AM
09/02/24 09:11 AM
Posts: 1,128 rust belt
Moparite
rust belt
Not it they are made in China. Not sure what kind of ball you are looking at but you can get different ones with the thread you need here.
[Re: Moparite]
#3255318
09/02/24 11:35 AM
09/02/24 11:35 AM
Posts: 20,224 north of coder
moparx
if the ball you are wanting can't be sourced in the link Moparite posted, using the helicoil fix posted above would be my choice, instead of trying to cob together a metric insert that will eventually fail, most likely sooner than later. also, the thin "jam nut" is an excellent suggestion, as it will secure the ball in the position you want, as well as allowing for easy removal if needed, as opposed to using the green or red loctite. just my personal life experience "playing with full size cars" for almost 60 years. your mileage will vary.
[Re: volaredon]
#3255363
09/02/24 02:27 PM
09/02/24 02:27 PM
Posts: 21,907 Kirkland, Washington
Pacnorthcuda
No... The REAL question is why in the hell did everyone have to bastardize everything and convert to metric to begin with Actually, in the big picture, Metric was first. And if you think about it, it makes more sense.
[Re: Pacnorthcuda]
#3255367
09/02/24 02:57 PM
09/02/24 02:57 PM
Posts: 6,493 nowhere
Sniper
nowhere
No... The REAL question is why in the hell did everyone have to bastardize everything and convert to metric to begin with Actually, in the big picture, Metric was first. And if you think about it, it makes more sense. Well, USS standards predated Metric standards by 34 years, I'd say no metric wasn't first.
[Re: Sniper]
#3255394
09/02/24 05:07 PM
09/02/24 05:07 PM
Posts: 21,685 N.E. OHIO, USA
A12
N.E. OHIO, USA
No... The REAL question is why in the hell did everyone have to bastardize everything and convert to metric to begin with Actually, in the big picture, Metric was first. And if you think about it, it makes more sense. Well, USS standards predated Metric standards by 34 years, I'd say no metric wasn't first. Are we talking in the USA or in general world history? Don't know if the following is true or correct but "I found it on the internet so it MUST BE TRUE. 1832United States customary units form a system of measurement units commonly used in the United States and most U.S. territories, since being standardized and adopted in 1832. The United States customary system developed from English units that were in use in the British Empire before the U.S. became an independent country. 30 March 1791The metric system was officially invented on 30 March 1791 when the French Assembly accepted a proposal for a uniform standard of weights and measures. It was passed into French Law on 7 April 1795. The metric system is an international decimal system of weights and measures. It was officially adopted in France on December 10, 1793. The metric system succeeded the decimalized system based on the meter introduced in France in the 1790.
[Re: A12]
#3255507
09/03/24 07:39 AM
09/03/24 07:39 AM
Sniper
nowhere
No... The REAL question is why in the hell did everyone have to bastardize everything and convert to metric to begin with Actually, in the big picture, Metric was first. And if you think about it, it makes more sense. Well, USS standards predated Metric standards by 34 years, I'd say no metric wasn't first. Are we talking in the USA or in general world history? Don't know if the following is true or correct but "I found it on the internet so it MUST BE TRUE. 1832United States customary units form a system of measurement units commonly used in the United States and most U.S. territories, since being standardized and adopted in 1832. The United States customary system developed from English units that were in use in the British Empire before the U.S. became an independent country. 30 March 1791The metric system was officially invented on 30 March 1791 when the French Assembly accepted a proposal for a uniform standard of weights and measures. It was passed into French Law on 7 April 1795. The metric system is an international decimal system of weights and measures. It was officially adopted in France on December 10, 1793. The metric system succeeded the decimalized system based on the meter introduced in France in the 1790. We were talking about metric vs SAE threads, Inches/feet/yards/miles have been around for longer than there was the country called France, much less a metric system.
[Re: Sniper]
#3255522
09/03/24 09:52 AM
09/03/24 09:52 AM
A12
N.E. OHIO, USA
https://en.wikipedia.org/wiki/United_States_Standard_thread United States Standard thread (USS thread), also known as Sellers Standard thread,[1] Franklin Institute thread[1] and American Standard thread,[2] is a standard for inch based threaded fasteners and washers.[3] The USS standard is no longer supported. It, together with the SAE fastener standard, was incorporated into the Unified Thread Standard. However, the term, USS, continues to be used occasionally today to describe inch based threaded fasteners with a coarse thread pitch and inch based washers that are a little bit larger than the corresponding SAE washer. The Unified Thread Standard uses the term UNC (Unified Coarse) to describe a fastener that previously would have been designated USS and UNF (Unified Fine) to describe a fastener that would have previously been designated SAE.
[Re: GomangoCuda]
#3255713
09/04/24 12:49 AM
09/04/24 12:49 AM
Posts: 12,286 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Trying to jam metric threads onto standard threads, or vice versa, is a recipe to tear up everything.
Same with metric tools on standard fasteners, or vice versa.
Don't be a hilljack who doesn't understand what the numbers mean, and uses the "close enough" and/or "well, it fit" system.
