Re: Standard vs. metric thread question
[Re: CMcAllister]
#3255769
09/04/24 11:49 AM
09/04/24 11:49 AM
Posts: 20,230 north of coder
moparx
i agree with CM's reply with one exception. depending on one's too "assortment", i have found at times, using a particular tool of the opposing fastener type can fit better/tighter on the fastener being removed/tightened. this depends entirely on the brand, whether snap-on, crapsman, s-k, or other brand, and the only way one can determine this is to try what you have, and use the tool that has the TIGHTEST fit on the fastener you are working on. i have been doing this for many, many [and many more] years, and there are times when even new fasteners fit better in the opposing tool "size" category. just my personal life experience using my personal very extensive tool collection. your mileage will vary.
[Re: A12]
#3256528
09/08/24 12:35 AM
09/08/24 12:35 AM
Posts: 12,286 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Today the common complaint and frustration, especially with motorcycle mechanics, is the disappearing, forever getting misplaced is the 10mm wrench or socket but back in the day it was............. That would be wrong. It was the 9/16".
[Re: moparx]
#3256530
09/08/24 12:42 AM
09/08/24 12:42 AM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
i agree with CM's reply with one exception. depending on one's too "assortment", i have found at times, using a particular tool of the opposing fastener type can fit better/tighter on the fastener being removed/tightened. this depends entirely on the brand, whether snap-on, crapsman, s-k, or other brand, and the only way one can determine this is to try what you have, and use the tool that has the TIGHTEST fit on the fastener you are working on. i have been doing this for many, many [and many more] years, and there are times when even new fasteners fit better in the opposing tool "size" category. just my personal life experience using my personal very extensive tool collection. your mileage will vary. That can be true, if the fastener, or the tool is junk. For example, I had a guy trick me into using a Amazon AN hose kit. $50 for what would be about $1000 worth of good stuff. It was ridiculous trash, fake, useless, garbage. Neither metric or standard tools would fit the hose ends properly and I had to use the hilljack's favorite tool, an adjustable wrench, to force it together. Never again.
[Re: CMcAllister]
#3256579
09/08/24 11:08 AM
09/08/24 11:08 AM
moparx
i agree with CM's reply with one exception. depending on one's tool "assortment", i have found at times, using a particular tool of the opposing fastener type can fit better/tighter on the fastener being removed/tightened. this depends entirely on the brand, whether snap-on, crapsman, s-k, or other brand, and the only way one can determine this is to try what you have, and use the tool that has the TIGHTEST fit on the fastener you are working on. i have been doing this for many, many [and many more] years, and there are times when even new fasteners fit better in the opposing tool "size" category. just my personal life experience using my personal very extensive tool collection. your mileage will vary. That can be true, if the fastener, or the tool is junk. For example, I had a guy trick me into using a Amazon AN hose kit. $50 for what would be about $1000 worth of good stuff. It was ridiculous trash, fake, useless, garbage. Neither metric or standard tools would fit the hose ends properly and I had to use the hilljack's favorite tool, an adjustable wrench, to force it together. Never again. ah, yes..........the "quality" parts people choose to use today, and the "quality" of a lot of aftermarket good name parts that have gone downhill over the last few years, coupled with the rise in counterfeit trusted brands.
[Re: moparx]
#3256607
09/08/24 12:42 PM
09/08/24 12:42 PM
Posts: 21,688 N.E. OHIO, USA
A12
N.E. OHIO, USA
